Where is this massive oil leak coming from?!
Discussion in 'Gen 3 Prius Main Forum' started by preeeuss, Oct 15, 2024.
  1. preeeuss
    preeeuss Junior Member
    Sacramento
    I’m in need of help please! I smelled burning oil after driving my Prius so I looked under and found a puddle of oil under the engine dripping onto the passenger transaxle and even further back behind it would stream out once engine stopped.
    Tried getting some pics but it’s dark out; maybe you guys are familiar with this and could point me in the right direction!
    Car is a 2011 has about 230k miles on it everything else is bone dry including oil pan and filter housing.
  2. rjparker
    10,117
    6,279
    Obviously I would check the drain plug bolt. Most likely the oil filter if it just suddenly started. After that it could be the low oil pressure sensor which sometimes blows through the sensor. If it was slow it could be one of those or a timing cover seep, very common.
    I would check the oil filter first and get your under cover put back on to protect it.
    Brian1954 likes this.
  3. preeeuss
    Sacramento
    I checked and the oil pan/housing is completely dry. I can’t see where the leak is coming from it’s in a crowded spot and leaks a little at a time
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    The color looks more like it's an axle CV joint boot that's leaking lubricant. The joint by the transaxle looks totally dry. What about the joint at the front suspension? I'm just going by the first photo, the other two are messing my brain up. May not make sense with your other symptoms, like dripping on the transaxle and leaking after the engine is stopped, but weird things happen sometimes.
    #4 TMR-JWAP, Oct 15, 2024
  5. Mendel Leisk
    41,384
    Just easier to view:
    If I'm not mistaken, they're all at the left end, as you stand at front of engine bay? This zone is technically known as the "front" of the engine.
    Timing chain tensioner, oil pressure sensor, or timing chain cover?
    Higgins909 and BiomedO1 like this.
  6. BiomedO1
    3,548
    1,838
    SacTown, Ca
    That sounds about right. Front of engine towards the firewall.
    You'll need to hose down the area with degreaser and get a couple cans of brake cleaner too. Put the car up on ramps, clean it off to track down the leak. My money's on the timing cover where the head meets the lower engine block. Use the cans of brake clean to spot clean the questionable areas you couldn't get to with the water hose.
    Hope this helps.....
  7. preeeuss
    Sacramento
    Thanks!!
    Found out the oil pressure sensor is the culprit! Leaks right at the connector! Is that a normal fail connector?
    What could happen if the switch completely fails? Also is it just a 24mm unscrew and swap out?
  8. BiomedO1
    3,548
    1,838
    SacTown, Ca
    No, not normally. The plastic bit of the sensor probably had a hair line defect or it was dropped before being installed. It just so happens that all those hot & cold cycles allowed the oil pressure to finally push through that small defect. Replace it and move on. DO NOT over-tighten or cross thread it - it's soft aluminum..
  9. preeeuss
    Sacramento
    Thanks! Picking one up now!
    I was worried trying to figure out the problem and what could happen if it fails
  10. rjparker
    10,117
    6,279
    It has failed. You see the result. It is not an oil pressure transducer. It is just a switch which turns on a light when someone has no pressure. Usually because the engine burned all the oil. The engine will continue to run until it ruins itself.
  11. douglasjre
    douglasjre Senior Member
    2,177
    717
    Null, NL
    Usu cause is 15W-50 oil. 27mm wrench. Chinese replacement will fail too no matter what oil used. U guys don't get over 75F there. Which oil did u use?
  12. Mendel Leisk
    41,384
    Torque info attached.
    Where it calls for “Toyota Genuine Adhesive 1344, Three Bond 1344 or equivalent”, I’ve sub’d Permatex Threadlocker Blue, Insensitive (more effective in oily conditions) on PCV valve threads, seems similar efficacy.
    #12 Mendel Leisk, Oct 16, 2024
  13. preeeuss
    Sacramento
    I used 0w20 it does get in 110-115 degrees in the summer time!
    Seems to work well since I installed it thanks everyone!
  14. Mendel Leisk
    41,384
    Wow. Checked my atlas: all of Ireland (and England) is north of the 50'th latitude, apart from the extreme southern tip of Cornwall. For context, most of the Canada/US border is 49th latitude.
