130k miles !
Discussion in 'Gen 3 Prius Main Forum' started by H.S., Oct 15, 2024.
  1. H.S.
    H.S. Member
    113
    26
    Venice, ca
    Hey all
    my Prius 3 is coming up in 130k miles. I have no flashing lights or alert lights on. Is there anything specific I need to do for maintenance at that point ? Or any part or spark plugs changes ?
    trying to avoid scammers
  2. ColoradoBoo
    ColoradoBoo Senior Member
    1,240
    827
    Monument, Colorado USA
    Will need more info. What's already been done? (Coolant, Transmission??)
  3. ForestBeekeeper
    ForestBeekeeper Active Member
    772
    304
    Maine
    Just keep doing as you have been doing.
  4. bisco
    51,901
    if you did the 120k major service, oil change, rotate tyres, inspections.
    if you didn't get a maintenance schedule, go to toyota.com/owners for one.
    think about a tranny fluid change if you are going to keep it a long while, and clean the egr circuit asap!
  5. H.S.
    H.S. Member
    113
    26
    Venice, ca
    I haven’t done the transmission fluid . What is egr circuit ? And do I need to change spark plugs ?
  6. bisco
    51,901
    plugs should have been done at 120k
    egr circuit:
    watch
  7. Mendel Leisk
    41,425
    Exhaust Gas Recirculation (EGR) system has proven reliably prone to clog up with carbon, and there's a nebulous, unproven, speculative (is that enough disclaimer adjectives for all?) connection, between neglect of the carbon build-up, and head gasket failure. Around the miles you're at is when they start failing.
    Get on it right away, but at your current miles it is late in the day; every 50K miles would be optimum. You want to thoroughly/completely clean the EGR components, including the EGR passages in the intake manifold.
    This is a "moderate" maintenance item; especially first time around, DIY'ing it, I would budget a weekend: get it mostly done Saturday, wrap up Sunday. In advance you can remove the nut on the lower bracket of the EGR cooler (and ideally the stud there as well), and just leave it off.
    See top two links in my signature; on a phone turn it landscape to see signatures.
    #7 Mendel Leisk, Oct 16, 2024
  8. BiomedO1
    3,585
    1,856
    SacTown, Ca
    Did you ignore the coolant change too. Just because it doesn't freeze in Venice, isn't a good reason to ignore the coolant change. Over time, coolant turns acidic and rots your mechanical components from the inside out. You can do a litmus test make sure it's OK; but OEM maintenance manual stated the both cooling system coolant should've been changed by now.
    Hope this helps....
  9. H.S.
    H.S. Member
    113
    26
    Venice, ca
    Coolant
    Oil
    EGR
    Transmission Fluid
    Spark Plugs?
    since im getting various recs, can someone please, in simple terms for a non experienced person write me a small list based on manual of what exactly I need to do at 130K miles? I would really appreciate it <3
  10. bisco
    51,901
    tough to do a list without knowing the service history.
    there is very little to be done at 130k, if 120k maintenance was performed.
    egr circuit is not in toyota recs, it's a priuschat experience thing. same with tranny fluid.
  11. BiomedO1
    3,585
    1,856
    SacTown, Ca
  12. Mendel Leisk
    41,425
    IIRC the Toyota USA schedule stops at 120k miles? I’m just tapping on a phone at the moment; going from memory. I’ll update tomorrow. Pretty sure it’s 120k, which has the spark plugs, plus it one of “every 30k” in-depth brake inspections.
    That schedule (if paper booklet is missing, or even if not) is also available in pdf format, at Toyota Tech Info website (just Google, likely first result).
    anyway, it’s event-by-event, humanly impossible to see the underlying patterns/frequencies for various services. For that reason I created a table format translation, nothing added or deleted, to see the aforementioned patterns/frequencies.
    Need my computer to upload, will do that tomorrow, both a (table format) schedule per Toyota, and a second, extrapolated to 240k IIRC. To directly answer your question, 130k mile service is likely is just the basics, that’s tire rotation with visual inspection of brakes, and oil/filter change. But again, 120k was more, and maybe not all addressed?
    H.S. likes this.
  13. H.S.
    H.S. Member
    113
    26
    Venice, ca
    I do all my maintenance regularly every 5 k. I don’t remember needing based on last check that I need new spark plugs
  14. Mendel Leisk
    41,425
    Screen grab of the 2 pdf versions, the one extrapolated to 240K miles just extending the patterns:
    #14 Mendel Leisk, Oct 19, 2024
  15. rjparker
    10,139
    6,300
    Some people think changing the oil, engine oil filter and rotating the tires every 5k-10k miles is good enough.
    But Toyota USA recommends all filters an every 30k miles, coolant systems (two) at 100k miles and spark plugs every 120k. If you missed any you need them now. Coolants are then every 50k miles.
    In Europe they recommend updated ecu computer software to help prevent head gasket failures.
    Toyota recommends changing the transaxle fluid every 60k miles IF you tow, use a car top carrier or heavily load the vehicle.
    Toyota does not require egr cleaning or replacement unless an egr specific code exists. This is an expensive job at a dealer so most on Priuschat do it themselves.
  16. Mendel Leisk
    41,425
    The "3" footnote in the above, points to this, a couple of pages forward:
    Also, you might have this sticker on the side of the inverter coolant reservoir:
    FWIW, the above pic is even on my Canadiant spec 2010. That said, Toyota Canada recommends to change both engine and inverter coolant, at (roughly) 100k miles or 10 years, whichever comes first.
  17. H.S.
    H.S. Member
    113
    26
    Venice, ca
    I spoke with hybrid fix in LA they recommended based on footnote in Toyotas manual to do those at 150k not 130k. Does that resonate with you ?
  18. bisco
    51,901
    with the head gasket concerns, i'd do the coolant now and more often than the recommendation. just to be on the safe side.
    or at least test the ph
  19. Mendel Leisk
    41,425
    One of the elephants in my room: there's both a month and miles component to this, whichever comes first. The other, that Toyota Canada says to do both at the earlier interval. I even emailed them about the sticker; they said to ignore it. Anyway, at the 120 month mark (aka 10 years) I dutifully changed both. The odo was at 88k, kms. About 55k miles. The drained stuff looked pretty good. I'll do it again at year 15 I think.
  20. rjparker
    10,139
    6,300
    You do it at 100k miles and again every 50k miles.
