Radio Upgrade to Pioneer DMH-WT3800NEX
Discussion in 'Gen 3 Prius Audio and Electronics' started by amarino, Oct 21, 2024.
  1. amarino
    amarino Active Member
    141
    103
    99
    My car is a 2015 Prius Two with the basic touchscreen radio and backup camera. No Apps/GPS/Navigation/JBL/etc.
    Finally pulled the trigger a few weeks ago when there was a sale on the Pioneer DMH-WT3800NEX radio at Crutchfield. Installation was super easy, everything was plug and play except for 1 wire I had to crimp between the Antenna adapter harness amplifier (blue) to the iDatalink harness Amp turn on (blue/white). Technically different type of amp but it works for this purpose. None of the cars stock wiring was cut or modified.
    Install probably took 20 minutes to undo the dash, remove the old radio, and plug in the new one enough to test. Then spent another 1-2 hours doing cable management and making it look nice. Radio's GPS antenna and microphone were routed down behind the dash then back up the A pillar (same path as my dashcam wires) to get it up to the roof above the map light area.
    All of the car settings that you can change from the stock radio (light timeouts, lock settings, Smart Key enable/disable, etc) are retained with the module. The only thing you don't have is the fancy Energy Flow diagram (but still have the basic one on the instrument cluster) and the last 30 min MPG. But if you do plug in the OBD2 cable with the Maestro harness you can get stuff like RPM, Coolant Temp, Intake Air Temp, and other OBD2 stuff on a dashboard screen. However I don't think you can do custom PIDs or whatever like Torque to get the hybrid specific stuff.
    Stock backup camera also works and was plug and play into the iDatalink harness. Quality wasn't really improved. It's just the same stock camera signal but on a bigger and better resolution screen. There is the option to add in the parking guidelines but need to find a sufficient flat space and time with a tape measure to calibrate it.
    List of everything used:
    Some notes:
    Crutchfield bundles all the installation harness and steering wheel control module (iDatalink Maestro), but they only included the older Maestro RR on the website. I wanted to RR2 that lets you use Bluetooth to reprogram the steering wheel controls. For that I had to call into Crutchfield and they were able to send me a link to a custom cart with the RR2 module in a bundle to save the $50. Otherwise with the RR module if you want to change the steering wheel controls you have to plug it into a computer, which is hard to do when it is installed behind the dash.
    Another thing about the steering wheel controls that caught me off guard at first was they seemed backwards. On the Prius stock radio you're used to navigating Up and Down on the presets. But on the Pioneer radio at least the Radio presets are numbered 1 - 6. So if you want to go from preset 1 > 2, you would think it would be Down, but actually have to hit Up on the steering wheel. But thanks to the Maestro RR2 it was easy to re-program with Bluetooth from my phone and now it works as expected.
    Also another nice thing about the Maestro RR2 (and RR) is that you can have them totally custom mapped, and every button has a secondary function for holding the button. For example my Prius doesn't have the Voice Command button on the steering wheel, but I just mapped the new radio's Voice Control to when you hold the the Phone answer button on the steering wheel. Here is a sample of what that programming looks like from the initial setup on the computer:
    Some pictures of the install:
    I also went a bit more custom install for the microphone, instead of having the black mic clipped to the sun visor. I got a 2.5mm mono 12ft extension cable and ran that from the radio up to the map light location. Then I took out the stock prius mic and just wrapped the radio's one in there. For the radio's mic cable I just wrapped it up and shoved it in the space between the light and sunglasses holder in the picture below. The reason for getting an extension cable is so I can remove the map light panel and unplug the mic without it having to hang by the cable. I also left the stock Prius microphone plugged in just in case there were any errors or messages that would pop up.
    #1 amarino, Oct 21, 2024
  2. tweedle99
    tweedle99 Member
    123
    68
    Round Rock, TX
    Does the screen block the central vents? I went cheap route w/ my son's car and got the Boss. 9"
    If I mount the unit on the top slot, it will block airflow so I ended up moving to the bottom slot.
    The mic idea is very cool!!
    amarino likes this.
  3. amarino
    141
    103
    99
    The top/middle vents are not blocked to blow air up to your face / upper body. But may be blocked when angled down. I also mounted this one as low as possible to not block the vents. And also why I went with the 9" version instead of the 10" version.
    Sorry my picture was a bit angled down low. I will try to get one from eye level that shows it better.
    tweedle99 likes this.
  4. amarino
    141
    103
    99
  5. tweedle99
    tweedle99 Member
    123
    68
    Round Rock, TX
    amarino likes this.
  6. write2toonces
    write2toonces Junior Member
    Thanks for posting this. I’ve been thinking about replacing my head unit for a while to add a back up camera to my 2010. This looks complicated and intimidating but I think I can figure it out. How did you know what to do? Did Crutchfield provide video guides?
    amarino likes this.
  7. amarino
    141
    103
    99
    No video guides from Crutchfield, they just provided a PDF of how to remove the trim panels and original radio, but you can find videos for how to do that online. When I did call Crutchfield support for a question they were quick to answer and help out, even on a weekend. I only bought from Crutchfield because it is easy and they bundle everything together. You can buy the same stuff from other places and piece it together as well.
    It is a bit complicated but if you break it down into smaller steps / components it's easy to manage.
    1. Programming the iDatalink Maestro RR2 module: This is where you configure the steering wheel controls and program the module to your specific radio. Need to do this at a computer. You can install their software to program called Weblink and play with it in a Demo Mode to see what it's like: Weblink Desktop
    -- If you do order from Crutchfield I recommend to call them and get a "custom cart" with the RR2 module instead of the RR module. Yes it costs a bit more but the RR2 module has Bluetooth and is easier to reprogram from your phone/tablet once installed in the car. Other option is to drag your laptop out to your car and disassemble the dash to access the USB port on the RR module if you need to reprogram it, see my notes above about the steering wheel controls for why that was good to have for me.)
    2. iDatalink wiring diagrams. You can find them here for the radio specific and they even give you a shopping list: iDatalink Maestro
    -- For my 2015 Two with basic radio (no JBL) it starts on page 212 here: https://images.idatalink.com/corporate/Content/Manuals/RR-TOY/ADS-HRR(SR)-TOY01-DS-IG-EN_20230331.pdf
    Their harness really does make it 99% plug and play. Like I mentioned above I only needed to make 1 crimp connection for the blue wire to antenna signal amplifier. Everything else was plugging in connectors. The "iDatalink HRN-HRR-TO1 Vehicle-specific Harness" on the Crutchfield website shows an example picture of what it looks like:
    And on the iDatalink wiring diagram PDF it tells you what to plug in for your specific car:
    3. Backup camera selection and wiring, this might be the hardest part. My car came with a original backup camera, so I didn't have to do any wiring to the rear hatch or installing a camera to the outside. Example from YouTube:
  8. jr33zy
    jr33zy Junior Member
    24
    25
    Los Angeles
    Solid Post. Thanks
    amarino likes this.
  9. tweedle99
    tweedle99 Member
    123
    68
    Round Rock, TX
    amarino likes this.
  10. johnwbyrd
    johnwbyrd Junior Member
    Good day gentlemen; I just created this account and signed in tell you all how awesome you are. I will probably be doing a similar install shortly, and you have saved me a great deal of heartache. Thank you all.
    amarino likes this.
  11. tweedle99
    tweedle99 Member
    123
    68
    Round Rock, TX
    Finally got around to post the pix of my rear camera setup. Backup guidelines are adjustable thru my HU.
    This was the rear camera that I used, https://tinyurl.com/ytfnephy
    amarino likes this.
  12. Hal Boyles
    Hal Boyles New Member
    Kansas City
    I am doing the same install on a 2010 Prius with JBL system and wanted to thank you for the great write-up! I have the Maestro RR2 and their wiring adaptors. I have everything connected but don't see any harness for these three connectors. Does anyone know what these are for? Also, I have the instructions for both JBL and non-JBL system but don't see any difference between them yet my audio doesn't seem to work. Thank you for any help.
    BTW, we have two of the 2010 Prius' since 2009/10 and have spent less than $1500 in repairs on each of them over the last 15 years!
    Kromis likes this.
  13. amarino
    141
    103
    99
