Prius Gen 3 2009 Engine stops after 10 Seconds
Discussion in 'Gen 3 Prius Technical Discussion' started by MDN, Nov 4, 2024.
  1. MDN
    MDN Junior Member
    Brisbane
    Hi
    Prius 2009 Gen 3 (ZVW30R)
    My engine stops after 10s. Same happened in maintenance mode too.
    Car got the "Check Hybrid System" error and stops after 10s. Checked the battery capacity and its only 10%.
    Wanted to troubleshot the error. Whether engine stops due to poor hybrid battery charge capacity or engine issue?
    Found the below error codes after the "Check Hybrid System" and stops the engine.
    P3190
    P0A0D
    P0A0F
    Thank you in advance.
  2. Tombukt2
    13,712
    2,482
    Yeah you'll find the work ups for all three of those codes here repeated about I don't know I'd guess maybe 400 times pretty much the engine won't start and so on you'll be troubleshooting this for that code at least like a regular ice engine car without the hybrid so for some reason you're not starting fuel ignition compression something but yes sir it is a pain.
    MDN likes this.
  3. Eddie25
    Eddie25 Active Member
    503
    212
    MI
    It's not really that the engine is stopping after 10 seconds, it's that the engine is failing to start. It uses the HV battery to spin the engine for a bit and when the engine fails to 'catch' with gas it shuts itself down and throws the P3190 and the P0A0F.
    The problem then becomes that the HV battery drains itself (with no way to charge) on every start attempt until it becomes a new problem which may be where you're at, if not very close.
    Ultimately you'll have to find a way to charge the HV battery, then begin a typical "no start" diagnosis. It's probably difficult to find a shop with charging capabilities (or desire), so you might be up a creek. Building a charger and hooking it up isn't all that difficult, but requires a decent amount of DIY knowledge and ability. If that's not in the picture you may want to search for a hybrid specialist in your area to see if they can do it.
    Do you for sure have gas? DO NOT trust the gas gauge. Are you POSITIVE you have gas?
    I'm ignoring the P0A0D because that's the code for the interlock (safety connector) on the HV battery and I'm assuming you have that sorted because I don't think it would even attempt to start without that properly connected. I could be wrong.
    #3 Eddie25, Nov 4, 2024
    Mendel Leisk and MDN like this.
  4. MDN
    MDN Junior Member
    Brisbane
    First thank you for the comments Tombukt2 and Eddie25
    Yesterday I filed the tank with 98 Octane petrol
    And tried to start in maintenance mode and got the same result. Engine stops after 10s
    I am thinking now checking the fuel line and engine related stuffs. Because if the Hybrid battery goes to 0% ill be in big trouble. Now its around 10% capacity. Car is at my home and I have another vehicle for my daily use. So I can try different approaches and have time. I will try to build a hybrid battery charger or purchase. It would be great if I can find a way to build a charger or purchase one. If you have some knowledge, please share Eddie25.
    I am planning on start with fuel pump. I got a Mid range ODB scanner too. It allows me to "On" the fuel pump while IG-on.
    Is there any viable Ideas? From where should I start the troubleshooting of the engine?
    Thanks for your time and thoughts regarding this.
  5. Mendel Leisk
    42,119
    For starters, stop trying to start the engine.
    Was there any recent maintenance?
    little things can do it, disconnected PCV hose for example.
    #5 Mendel Leisk, Nov 5, 2024
  6. Tombukt2
    13,712
    2,482
    Yes check you're fuel pump . See if it pumps . Maybe a few seconds then stops delivering fuel . Stops pumping etc .
  7. Eddie25
    503
    212
    MI
    If you weren't in Australia I'd offer to sell you my charger.
    You need a Meanwell HLG-80H-C350A, you don't need most the stuff in this diagram for a basic charge. Really just the charger, D1 and R1, a digital multi-meter, and a fuse if you want to be safe. You can use "fork test lead" connectors to carefully slide the + and - into the respective battery connectors without having to mess with them. As long as you don't over-charge you don't need to worry about a fan.
    As for the diagnosis, you could remove the air box (keep the MAF connected) and spray brake cleaner in the throttle body while the car attempts to start to see if it affects it. If it stays running while doing this then you know you have a fueling issue.
    As Mendel suggested I would strongly consider no more attempts until you have it charged in order to avoid any damage to the HV battery. Also the charger I suggested needs a certain sitting voltage (128) to even start charging the battery, as far as I can tell.
    And as always verify any advice you receive for yourself.
    #7 Eddie25, Nov 5, 2024
  8. Tombukt2
    13,712
    2,482
    Yes I have the Venice hybrid charger It's get set on the second stage I think it's 300 volts and generally when I connect it to the battery side of the relays It rarely runs for about maybe an hour maybe two and the pack starts noticeably warming up and then by the instructions from Venice hybrid when the display on the charger makes no changes for five solid minutes remove the charger That's basically your resting charge you're going to hold to keep on pumping juice into it is just going to heat it up and do nothing I've watched this go on seems to work pretty well I've only had to do this once and it wasn't because I was keeping starting the car it was just I had a battery I wanted to charge and see what would happen The Venice charger charges at 2.4 amps on the 300 volt setting or 2400 milliamps seems to work very well but you don't want to be heating things up
  9. MDN
    MDN Junior Member
    Brisbane
    Hi All
    Thanks all for your valuable input.
    I swap the throttle body and fuel pump from a similar Prius car (friends car) and tried to start it and got the same result. Car does not starts. Only the 10 seconds run.
    After, my cars fuel pump and throttle body put in to the friends car and started it. Friends car was running fine. Therefore, we can eliminate the probability of faulty throttle body and the fuel pump. The friends car gonna be with me for another week time. So I can swap anything.
    Any ideas?
    Thanks guys
  10. Tombukt2
    13,712
    2,482
    This model at this stage of the game should be reporting something back to the computer to trigger a light or codes especially a no start condition I can't remember what the code is but it's pretty common and usually everybody here gets it very quickly if the engine's not starting so is your OBD2 port working when you plug in a scanner does it actually connect to the car is the scanner capable of reading the Prius these are things.
  11. Tombukt2
    13,712
    2,482
    Freeze frame data capable scanner Will be your friend for this type of analysis The manual if you could put your hands on it has probably 40 pages to troubleshoot an engine no start or no run which is what you have even though it turns on for 10 seconds I don't think it's turning on I think that's just electric motor spinning the engine over and it's not starting It's not starting for 10 seconds that's the just like in your car with a starter like your Corolla when you crank the starter that's not the car starting The car starts after you let go of the key It's the same and the Prius when the motor generator spins the engine or locks up the shaft to spin the engine and make the engine go around and around and it doesn't start that means the computer didn't turn on the coils turn on the fuel something because it's not starting what's needed to start fuel spark and air
  12. MDN
    MDN Junior Member
    Brisbane
    I thought the same. Was planning on checking all possible issues as per the Prius manual. Will have some time on weekend and will update you with results. Already Intake/ Throttle/fuel pressure/ Engine/ out of fuel eliminated. Gonna focus on rest of the issues.
  13. Tombukt2
    13,712
    2,482
    And most of those things in that list have their own Prius codes or own codes for the OBD2 can bus system that you're working with so there's always that so I'm wondering if there's some underlying issues with your car's computer systems or the communication system in the car between all the other systems
  14. ChapmanF
    18,838
    One risk if the only place you look up the trouble code is in the summary table of codes like that is you just get the naked bullet list of all things that could ever have anything to do with it, and that's a lot less help than if you flip the rest of the way to the troubleshooting section for the specific code and look at the suggested troubleshooting steps there.
