1. Ajmarganski
    Ajmarganski New Member
    Oregon
    Sorry I’m a new gen 3 owner and I’m curious why there hasn’t been a mod (besides emission compliance) to chop the pipe coming from the exhaust to to the egr, cap the exhaust to egr cut part and the route another pipe connect it to the EGR. Either plumb it into the bottom of the air box below the filter or somewhere else using another filter to draw in fresh air rather than exhaust gas.
  2. Tombukt2
    13,110
    2,352
    And what do you think's going to happen when you do that let's just go with that first?. What do you think the car computer and systems are going to think about that? I'm not trying to be smart I'm interested in knowing what you might think about that We used to do mods like this over on the Toyota modification server years ago The guys in Australia and New Zealand are experts at this stuff not on a Prius mind you but I'm thinking that that's not going to work on the flood EGR type system that is on the Prius somehow the Prius uses that EGR as much as it uses fuel from the gas tank practically that thing runs the two Z runs on its own puke like a bird feeds it's young it's disgusting but hey that's what you got to do to get 5% more gas mileage over the generation too or whatever and that just gets fouled up clogged up and turns into a jigga mess.
  3. ChapmanF
    18,301
    That would certainly change things!
    The EGR system uses exhaust gas because it will not chemically combine with fuel the way fresh air will, so it can be used for dilution without leaning the mixture.
    Fresh air would have ... different ... effects.
    Mendel Leisk and Brian1954 like this.
  4. Ajmarganski
    Oregon
    Gotcha that makes sense, so it’s cooling the already present air without changing the Air fuel ratio. You think the ECU could compensate for more oxygen?
  5. ChapmanF
    18,301
    The point is it spreads the air and fuel molecules farther apart without being air or fuel itself, so the combustion in the cylinder happens more smoothly over more of the power stroke, instead of having a quick temperature/pressure spike near the top.
    Bringing more air in just wouldn't do that, whether the "ECU could compensate" or not.
  6. misterduck
    misterduck Junior Member
    Earth
    Exhaust Gas Recirculation deliberately reintroduces inert exhaust gases—lacking oxygen—into the engine's intake. Because these gases do not support combustion, they dilute the incoming air, lowering the overall oxygen concentration and peak combustion temperatures.
    This reduction in temperature is crucial for minimizing nitrogen oxide emissions and helps protect downstream components—such as the catalytic converter—from heat-related damage. Introducing fresh air into an EGR system would defeat the purpose, because fresh air contains oxygen that promotes combustion rather than mitigating it.
    tl;dr if you want to try this, I'd just remove the EGR system entirely. It will likely have serious consequences.
  7. Mendel Leisk
    41,628
    Just let the EGR clog up with carbon, and you've accomplished the same thing...
    What's the miles on your '10?
    2015V-BadHG and misterduck like this.
  8. frodoz737
    frodoz737 Top Wrench
    4,711
    2,513
    33
    ...because no one has cracked the SW so it will pass inspections.
  9. hermie
    hermie New Member
    thailanf
    i m not sure bout emission because i m not in us but i had done it more than 5 yr ago. for performance it should be used with airflow wire hack to rich up fuel but it work without too. u do need to drill the egr to connect fresh air line to egr or check engine light will light up. no ecu reprogram needed.
  10. Tombukt2
    13,110
    2,352
    Alrighty then
  11. Mendel Leisk
    41,628
    So whenever the car thinks it's feeding exhaust gas, you're in-fact feeding regular, oxygen-rich air? How many miles on it now?
  12. hermie
    hermie New Member
    thailanf
    i trick airflow wire with resister wire to think air temp is lower than actual. mine drove everyday but short distance it only 99000km but there r other that did the samething with over 100000 km. i did mine when it was 50000km
  13. hermie
    hermie New Member
    thailanf
    i dont remeber why would engine couldnt run without egr? and i dont think without egr would create enough heat to damage engine
  14. Mendel Leisk
    41,628
    My sense is that the engine is designed, and programmed, to run lean, in order to achieve better fuel economy. A lean running engine is prone to overheat, but this tendency is reduced by a properly functioning EGR, which introduces exhaust gas to the combustion chambers, effectively damping the explosions. When the EGR system is clogged (or bypassed), the propensity to overheat returns.
    It's been argued that in certain markets the 3rd gen Prius has no EGR system, but runs ok. I would counter that Toyota has likely revised the car's programming, and possibly some mechanical components, to compensate, run the engine richer, and cooler.
    misterduck likes this.
  15. rjparker
    10,227
    6,386
    The gen3 egr system is primarily to reduce emissions with a lower cost catalytic converter. Gen2 had no egr but required a very expensive cat to achieve near zero emissions.
    There are people in the US who have blocked their gen3 egrs for many thousands of miles. My concern is that causes a check engine light that will mask other potential problems down the road.
    There is no doubt Toyota has modified the gen3 logic for places like Brazil where no egrs are used and emissions are not a concern. They almost had to for competive pricing reasons.
  16. hermie
    hermie New Member
    thailanf
    i dont think egr will cause engine overheat since there r cooling system and as far as i understand without egr ecu still read af from o2 sensor and adjust fuel to not running lean. i mention that without airflow wire hack there is no knock occurr which should indicate that it s not too lean but i use airflow wire hack to rich up fuel anyway.
    i havent had any cel at all. only hybrid battery cel when once which is its time to replace battery never have any engine cel. also no coolant lost ever happen too.
    ps: i m not talking about emission which i think what i did will absolutely effected else safety factor in ecu will do the job without problem
    #16 hermie, Sep 3, 2025
  17. hermie
    hermie New Member
    thailanf
    i guess for brazil (which i had no clue about) with no egr but i m sure there r o2 sensor that ecu used to compensate fueling.
  18. misterduck
    Earth
    Multiple sensors, possibly. There's the "upstream" Air Fuel Ratio (AFR) sensor in the exhaust manifold, a "downstream" O2 sensor after the catalytic convertor, knock sensor, mass-airflow (MAF) sensor, coolant temperature sensors, etc. It's entirely possible (probable, even?) Toyota engineers programmed priuses without an EGR to behave differently based on data from all of these sensors.
