VSC indicator on dry pavement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dipstick22, Nov 23, 2024.
  1. dipstick22
    dipstick22 Junior Member
    17
    Delaware
    My 2008 Prius is a few hundred miles from 300,000. Last night, driving on dry pavement at about 55 mph, perfect driving conditions, the car started vibrating, VSC light came on for 2-3 seconds, then went off, but the vibration continued for another few seconds (maybe 10 at most). Then back to normal. My son-in-law had the car for a few months and reported that it had happened to him, but this is the first time I've seen it myself.
    1. What is causing this?
    2. What is the correction?
    3. Is it dangerous to continue driving the car?
    Thanks.
  2. Tombukt2
    13,198
    2,386
    He'd probably have to look at the freeze frame data and see what the skid control mechanism is reporting He probably have to have the scanner hooked up while this was happening or try to make the problem repeat itself a bad hub which would think would have a code. A bad wheel bearing vibrating enough causing the sensor inside the wheel to report poorly when it's vibrating something along those lines.
    MAX2 likes this.
  3. ChapmanF
    18,398
    Freeze frames usually go with trouble codes; if the VSC just thought it was doing what it's built to do and didn't set a trouble code, there probably isn't a freeze frame in that sense.
    Gen 3, I know, has an "ABS History" screen you can look at in Techstream, shows what all the sensor inputs were the most recent 4 times either ABS or VSC was active. Kind of like freeze frames but for normal operation instead of a trouble code.
    But I don't remember if gen 2 had that.
  4. dipstick22
    17
    Delaware
    I forgot to mention that I did NOT get a check engine light. We have talked about giving this car to our daughter who drives 2 children in booster seats in the rear. I know that a 300,000 mile car is, by definition, a bit of a reliability risk. My biggest concern is safety. The car did not swerve or become unsteerable. The whole episode lasted about 10-15 seconds. I doubt that I can recreate it at will. Any suggestions? Frankly, I have low confidence that the Toyota dealer would be of any use.
  5. dipstick22
    17
    Delaware
    ChapmanF - you and I have chatted before in this forum. I am trying to decide if the Prius is worth trying to "save" or just let it go. Is there an opportunity for a direct chat?
  6. dipstick22
    17
    Delaware
    Re-opening this after some time away for family matters. I rolled the Prius over 300,000. It is not generating any check engine codes, but the gas engine is definitely running rough. A while back, I saw a code for a misfire on cylinder 1 (that is from memory). The other day, the VSC light came on briefly, right in the middle of what felt like several misfires in a row on the gas engine. Then the misfires stopped and VSC light went off. No engine check light.
    Based on this, I'm planning on doing a tune-up soon. I'm pretty sure it is way overdue (like 150,000 miles overdue).
    QUESTION: Would using some fuel injector cleaner be a good idea before the tune-up? If so, what kind?
  7. ChapmanF
    18,398
    Some years ago we had a thing going where we would send a set of injectors for restoration, to a facility that would clean them on a bench (piping in a strong injector cleaner and operating the injectors in an ultrasonic bath) and restore them with new caps and O rings and such, and report their before-and-after test performance. Then we could send the restored ones to someone who had old ones to send to the restorer to keep the thing going.
    Often people would have tried running in-tank injector cleaning products before trying this, and the overall impression from the way the before-after-test results came out seemed to suggest that the bench restoration was very effective but the in-tank products didn't seem to do much, at least not to improve injectors that were bad. Maybe they're more effective at keeping good ones from going bad.
    But another thing we found was that something like two out of three sets sent in for restoration were not bad at all on the before-test. It seems to be quite possible for these injectors to go lots of miles without problems.
  8. Tombukt2
    13,198
    2,386
    It was probably the multiple misfires that fooled the VSC and the activating and then as soon as the misfiring was over obviously the VSC light went out I had my VSC light come on on solid dry pavement just hitting a few small pebbles but apparently the pebbles were enough so that the skid control computer believed the car could become not well stuck to the road
  9. dipstick22
    17
    Delaware
    Sounds like I should skip the cleaner and go straight to the tune-up. Thanks for the advice.
  10. dipstick22
    17
    Delaware
    I'm back with an update on my 300,000 mile 2008 Prius. I changed the spark plugs. Pictures attached. Quite a difference! Immediate difference resulting in a smooth-running engine. Reset the MPG but not seeing any difference (yet). I have not been driving it very far or very fast so it's possible that I'm not seeing the real impact on net MPG. With the smooth-running, I have had no VSC indicators, so my conclusion is that the rough-running engine was triggering the VSC flashes. Today, it coded P0420 - O2 sensor on Bank 1. I'm not surprised by that.
    With all this, I would greatly appreciate any confirmation and/or commentary before I close out this thread. I think the biggest learning for me was that engine misfires can trigger VSC indicators. I did not pick that up in my forum searches.
    Thanks, everyone.
  11. Tombukt2
    13,198
    2,386
    Yeah I could see where a lot of engine bounce could generally make that condition .
  12. dolj
    dolj Senior Member
    8,490
    4,308
    Wellington, New Zealand
    Those plugs were well overdue for replacement. Just eyeballing from the photo, the gap looks to be twice (or more) the gap the new plug has.
    I would hold off doing anything on the P0420 for now. Keep clearing the P0420 until you have a couple of hundred miles with the new plugs. If you still get the P0420 after that, then look more into it.
    BTW, P0420 does not mean O2 sensor on bank 1. It means the catalyst system's efficiency (bank 1) is below the threshold. Give the system a chance to get back up to par now that the engine is running better with the new spark plugs.
  13. dipstick22
    17
    Delaware
    DOLJ - Thanks for the advice on the P0420. I'll watch it for the next month. After the first 100 miles, the mpg is up to 50.2 which is a good sign.
  14. dipstick22
    17
    Delaware
    Final update on this topic. I've now driven about 400 miles since replacing the plugs. I've had no more P0420 codes and my mpg is up the 50.5.
    dolj likes this.
