Transaxle/Transmission Fluid Change - Dark Brown and Overfilled(?)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Purrius, Dec 2, 2024.
  1. Purrius
    Purrius Member
    164
    48
    Northeastern US
    I did my first transaxle fluid change last night, and I'm not proud to admit that took me hours to accomplish. The car has 208,xxx miles on it, and I've only just started doing my own maintenance on 'er. I can honestly say... I don't know when it has the last transmission fluid change was, but judging by the color, it's been a some time.
    After getting the car up and level, I opened the fill (top) plug and an absolute torrent of fluid came out. A comedy of errors ensued.
    Since I wasn't ready for the fluid to shoot out nearly horizontally at my face, I dropped the plug into the basin. Once I fished it out of the miniature BP oil spill I was cultivating under the car with me, I quickly plugged the drain again. No easy feat when I have only inches between my mug and the rusty underbelly of the car.
    Currently I only have access to low jacks/jack stands, so my personal protective equipment did some seriously heavy lifting last night.
    After cleaning up, I decided it must be because the car wasn't actually level, despite all other factors arguing against it.
    I opened the drain (bottom) plug, two catch basins ready, and let everything drain out. That's when my utter confusion has set in.
    I let the car drain until the fluid slowed to a minute dribble. I measured what was in the basin, and not even taking into account the transmission fluid lakes forming around the garage, I took out over 4.5 quarts. :eek:
    I closed the bottom plug and pumped in fluid through the top using the manual's recommended 3.6(ish) quarts.
    I don't even know how it's possible to over fill it by that much. How could someone have filled it with so much extra fluid without it erupting back out of the filler plug? :confused:
  2. JC91006
    JC91006 Senior Member
    16,799
    8,589
    It seems odd to have 4.5+ quarts come out of the drain. I normally put in 4 quarts and that's about all that would go in. 3.6ish quarts won't hurt anything, it just might be your car is not completely leveled.
  3. ASRDogman
    ASRDogman Senior Member
    7,704
    3,955
    It's likely that whoever changed it last time did not have the car level. It was
    probably angled with the passenger side higher. That's why it's important to
    have it level.
    But if YOU got the car level, or close to it, and put in 3.6qts before it started
    dripping out, you should be fine.
    The cheap kitty litter from walfart works really well for soaking up the oil.
    After it soaks for a while, you can sweep it up, then put more down, then take your shoe/boot
    and rub it into the concrete. That will clean it right up.
    If you were on dirt/grass.... Don't know what to tell you.
  4. Purrius
    Purrius Member
    164
    48
    Northeastern US
    Welp, that does make perfect sense, and I feel silly for not considering they may have filled it at an angle!
    I realize cleaning up today that previously I was a bit conservative with the amount that came out, it was easily closer to five quarts, but likely more. In addition to the basin, it had filled nearly two 30oz Taco Bell cups (1.9qt). (Talk about a forbidden Cherry Pepsi).
    Once I got the entire entire car drained including feeding a hose at the bottom to see if anything else could be siphoned out I poured in between 3.6 and 4 quarts. It didn't flow back out, but at least I know I got nearly everything out and put the correct amount in via measurements!
    As for the mess, yeah, I usually keep a bin of dollar store cat litter on hand. Recently my parents have me a bag of Yesterday's News paper cat litter because their cats didn't like it. It works pretty well, although discontinued and similar products are far too expensive to normally be used practically.
    ASRDogman likes this.
  5. ASRDogman
    7,704
    3,955
    You don't want to overfill or underfill. That's why it's important to get the car level.
    You fill until it drains out of the fill hole. That's the procedure.
  6. Mendel Leisk
    41,743
    3.6 quarts sounds about right. Someone must have managed to overfill, or it somehow happened at the factory, much more likely the former.
    4.5 drained (plus spillage) is way too much. IIRC there’s a third plug on the transaxle, way up at the top, maybe? Perhaps someone filled through that??
    there’s a link on transaxle fluid change in my signature FWIW (on a phone turn it landscape to see signature).
    BTW, if that’s your picture, you seem very professional. If it was me it’d be two mismatched jars from the recycling, against a background of random clutter, lol.
  7. Purrius
    Purrius Member
    164
    48
    Northeastern US
    I believe that may be part of how it ended up so overfilled. Like you said, if the place that did it originally had it cocked to the side, that meant they filled it until it came out (this overfilling it).
    My Toyota manual specified 3.6 quarts specifically, and unfortunately I can't for sure say the car didn't settle and tilt. I'm personally confident having measured it before pouring it in that I should be good to go. There's no way I overfilled it, and little reason to believe I underfilled it either. :)
    I bounced off ideas of how it happened with my roommate, and we remembered we had service done while stopping through Oregon. I recall the shop doing a bunch of extra work I didn't approve of, and then demanding I pay for it or they'd call the police and.keep my car. I ended up just paying it. It's not very charitable of me, but the impression we got was they knew we needed to get back on the road and thus didn't have time to make a big deal out of it. :/ (I planned to dig through my records now that this has reminded me and see if I can find the services they did, and whether this was part of it.)
    As for the little vials, I've actually been collecting them as I go along working on my first cars. I kind of chalk it up to my specific brand of autism™, haha. :D
  8. Mendel Leisk
    41,743
    The funny thing is: Toyota never says anything about the car needing to be level. I suppose they’re picturing the car on a dealership lift, never occurs to them somone would run the front end up on ramps, or employ floor jack and safety stands.
  9. ASRDogman
    7,704
    3,955
    If you drained it, and filled with 3.5 qts, you're fine.
    You should have let them call the police. The police would have told the shop they cannot kidnap
    your car. They must let you take it. Or it would be theft and would have arrested the owner or
    shop manager.
    You should contact a lawyer and sue them. You will win. Get your money back and a few million extra
    for stressing you out.
    That's why you shouldn't just sign that form, ALWAYS require and estimate.
    And since they would do shaddy crap like that, did they actually DO the work? Maybe they just added the fluid
    without draining it first.
  10. Purrius
    Purrius Member
    164
    48
    Northeastern US
    Oh yeah, make no mistake, I was only there for an oil change out of desperation. (I had an extremely important appointment to attend, and without a lengthy rambling story, we ended up at this shop.) I in no way signed off for the rest of that work, but calling the police and getting the law involved would have prevented me from getting to my destination on time, which weighing my options I forewent the $200. :(
    In Oregon (at least at the time) they could put an auto mechanic's lien on my car and hold it as collateral until I paid. So if the cops did show up, I'd be SOL and it would have become a big legal fiasco involving small claims court. (This was years ago, so I the statute is up anyway.) It came down to choosing between being "right" and being efficient, and the latter was the smarter choice in this scenario.
    I'll let y'all know what I find when I crack open the filing cabinet and spelunk for the invoice though!:eek:
  11. Mendel Leisk
    41,743
    Yes but how?
  12. ASRDogman
    7,704
    3,955
    ??? :confused: This happened years ago???? It's too confusing...
  13. Purrius
    Purrius Member
    164
    48
    Northeastern US
    I'm unsure, aside from what you mentioned, the car might have been at an angle? (More to follow regarding this.)
    (Yeah I didn't do a super great job explaining it, got a little rambling!)
    I looked through my files and found a receipt for tires I bought on the same trip, but not the one from that shop which is a bit odd.
    I just spoke with my regular mechanics and it appears they're the ones that did the last change on it. I trust them, so I'm certain it was nothing intentional.
    One of the guys up front likes to work on a hobby car, so he insisted I take it with a grain of salt, but he had a theory. Whomever worked on it a couple may not have been completely familiar with the Prius, and didn't recognize there being a difference between the CVT, and just use the regular procedure for it.
    Is the "normal" procedure for a transmission fluid change different than for the Prius? He said some cars you'll pour fluid in and then run the car for a little bit turn the car off and then add more until it drips out. Once the drip steadily falls back that's when it's good. (I have no idea how accurate that is though, I'm merely the messenger.)
    However I mentioned thinking there was something different about the Prius CVT, but at the time I couldn't really recall. Then I second guessed myself and couldn't figure out whether or not it was a just false memory.:LOL: Found this thread and it seems to point towards yes? (Although still a bit out of my comprehension).
  14. ASRDogman
    7,704
    3,955
    "One of the guys up front likes to work on a hobby car, so he insisted I take it with a grain of salt,"
    And you trust these people??????
    Would they have paid for a new transmission and the labor to install it when it failed?
    And any other damage to the hybrid system it could have caused?
    And pay for your down time?
    A 5 minutes, or less, search on youtube could have found the procedure for changing the fluid.
    This is why I do my own work. I worked at different dealerships and independent shops and saw
    crap like that. And lost a few jobs because I wouldn't do that.
  15. Purrius
    Purrius Member
    164
    48
    Northeastern US
    (The guy up front doesn't work on the cars at the shop, he schedules appointments. That's why he insisted it was just hobby car guy musings, not end-all be-all facts.)
    Personally I don't believe the guy that did the change originally is at the shop anymore. They probably would have asked him about it. (They did add a note in their system though to be safe.)
    I'm fairly certain they would have done those things had it actually caused any issues for me (during the recommended interval, of course. I waited far too long when I just did it myself. That's on me). They've easily done hundreds of dollars of work for me pro bono throughout the years, and that's another reason I really like them. ฅ^•ﻌ•^ฅ
  16. johnHRP
    johnHRP Active Member
    645
    189
    KA, DE
    Excel
    I don't worry too much about the Transmission fluid overfill since it is like differential without any crankshaft that will cause foaming. Underfilling is more problematic. The color changes right away even if it is just 1 week used. That's just the dye that got oxidized. The ATF-WS or Dexron VI itself are very stable and the additives too. It is fine even after 20y unlike engine oil.
  17. ASRDogman
    7,704
    3,955
    ???????????????? :confused::confused::eek::eek::eek:o_Oo_Oo_O(n)(n)(n)
    Grit likes this.
  18. johnHRP
    645
    189
    KA, DE
    Excel
    Toyota said it is lifetime fluid you know;):D. Of course, 20y in the bottle is fine. In the car 10y/100k miles is more than enough. Unlike regular torque converter type auto transmission, the temperature and wear in E-CVT is much lower. Prius have no clutch, all gears, magnets, and coil winding in the transmission. I personally changed every 60k miles and the fluid has the same smell as the new one. No burn smell like in my old Camry or Altima 2002.
    The factory fill was too low, about 3L came out. I doubt it is from vent. I add it up until full for about 3.8L or 4 quarts. I used the used ATF to clean my internal gears Shimano Alfine 8 speed cleaning. It works really well.
  19. Mendel Leisk
    41,743
    Not really, they just say nothing.
    johnHRP likes this.
  20. johnHRP
    645
    189
    KA, DE
    Excel
    I am very curious about ATF since they never said how long we can use it after keep in the botle. For engine oil, 5 years is the selflife of the additives in the oil (especially the antioxidant). It seems the additives type is mostly antiwear and detergent in ATF, and the type of additives is different. Almost sealed environment without exposure to radicals gas.
