Prius CVT vs conventional CVT - details
Discussion in 'Prius v Main Forum' started by Kubosz, Apr 3, 2017.
  1. Kubosz
    Kubosz New Member
    Poland
    Hello everyone,
    I am writing my engineering thesis about transmissions, and I really need to compare pros and cons between Prius CVT and conventional CVT with belt. All I can find is how they work, and I do know that already.
    I also know that Prius CVT has less parts = is easier to create, is more reliable - no problems with belt, no friction. Looks like Prius CVT is much better, but it surely has some cons in comparison to conventional CVT and I can't find any... Could someone please help me with that?
    And what about size and weight of these CVTs? Which one is heavier, bigger? What about transmitted torque?
    Also any data about effciency would be great.
    If you guys have any knowledge on this topic, please share it with me.
    Thanks
    Purrius likes this.
  2. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    You pretty much answered your own question there, but isn't an engineer supposed to know all this stuff? ;)
    The hybrid synergy drive isn't a transmission, its a "power split" device, basically a differential drive. So efficiency (as such) is no different than any differential. It has several planetary gears (latest model) and a gear drive to the front axle. I'm sure it all weighs a good bit, probably more than a belt drive CVT. There's a lot of stuff around online including videos, do some searches.
    GregC1979 likes this.
  3. DonDNH
    DonDNH Senior Member
    1,711
    655
    Nashua, NH
    Four Touring
    I would suggest that a couple of drawbacks for the HSD are:
    • the complexity of computer(s) needed to control it
    • the expense and weight of motor/generators that are integral to its function
    Some of the advantages might be:
    • the low friction losses
    • low wear and tear on internals (as evidenced by Toyota's maintenance requirements fluid changes)
    • relatively high efficiency for integration for flow of power from ICE and EV as well as for regeneration
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    The Volt gains some efficiency at higher speeds by having more than one gear.
    Gen 1 and 2 Prius tended to want to over rev Motor/Generator 1, Toyota added a second planetary gear set in Gen 3 to avoid that.
  5. Mendel Leisk
    42,347
    Gen 4 takes it further: has two side-by-side arrays of gears. And a much higher electrtic-only limit. Still can't stomach the styling though. :cautious:
    frodoz737 and Aaron Vitolins like this.
  6. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Gen 2
    Gen 3
    Cone and belt CVT
    All the same guy
  7. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    @JimboPalmer, thanks for putting those all together like that. I've only ever seen the gen 2 version before. Definitely going to look at the others asap. Gotta go use my cvt now. ;)
  8. DonDNH
    1,711
    655
    Nashua, NH
    Four Touring
  9. Emcguy
    Emcguy Member
    177
    29
    Australia
    Cons;
    -Some electrical efficiency ie: if the motor is running and you want the wheels still, the 'splitter' motor needs to spin backwards to compensate
    -You don't get any of the torque multiplication of a large cog driving a small cog like a conventional CVT. For this you need to analyse like a single gear drive.
    The pro's vastly outway the con's. Just think about the complexity of the PHEV IONIQ. A normal engine, driving through a clutched flywheel electric motor, directed through a DSG, and made in Korea...ouch
  10. Air_Boss
    Air_Boss Senior Member
    4,259
    1,197
    New Yawk
    The electric motor's peak torque from a standstill compensates for lack of torque multiplication in an ICE-powered CVT.
  11. kevinwhite
    kevinwhite Active Member
    333
    200
    Los Gatos Ca
    That doesn't really change things - it was just a different way to achieve the gear reduction. In high-end Lexus versions they do have a two speed selectable gear ratio but not the Prius.
    Over the evolution of the various generations Toyota has gradually increased the rated speed of the motor generators to make them smaller. I see that MG2 is now rated up to 17,000RPM. Up from 13,500 RPM on gen3.
    They have gone away from the planetary reduction as used in gen3 and gone to a parallel shaft reduction gear. In the gen2 it used a chain drive!
    kevin
    pilotgrrl and telmo744 like this.
  12. Fred_H
    Fred_H Misoversimplifier
    562
    488
    28
    Germany
    Hi Kubosz, welcome to PriusChat!
    Prius CVT disadvantages vs belt CVT:
    • Maximum torque when driving in reverse is less than when driving forwards. (could easily be fixed by adding a reverse gear just like on a belt CVT, but Toyota chose to keep it simple)
    • The Prius CVT is more suited to hybrid vehicles than to ICE vehicles. The Prius CVT is so deeply integrated in the hybrid system that it is almost just a byproduct of electrification. That is an advantage for a hybrid vehicle, but, in my estimation, in a non-hybrid vehicle it would be more complicated and expensive than a belt CVT due to the peripheral electronics. (would be interesting to calculate if the efficiency gains outweigh the manufacturing costs for a non-hybrid)
    Here are some of my favorite studies of the Prius drivetrain. The first one even has a direct comparison of simulated efficiency with the Honda belt CVT:
    A fundamental case study on the Prius and IMA drivetrain concepts
    Publication: A fundamental case study on the Prius and IMA drivetrain concepts
    Evaluation of the 2010 Toyota Prius Hybrid Synergy Drive System
    http://info.ornl.gov/sites/publications/files/pub26762.pdf
    Comparative Assessment of Hybrid Vehicle Power Split Transmissions
    http://john2211.nl/Hybride_links_files/Miller_W04.pdf
    Dxta likes this.
  13. Kubosz
    Kubosz New Member
    Poland
    Thank you guys for your help! I really appreciate it. I found a lot of useful material among your answers.
    + Fred_H these articles are great! :)
  14. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Fred! You did a wonderful job on those research papers. Have checked and downloaded, waiting for a day to study everything.
    Please just in case you've other stuff, I'd be happy to read em.
    Thanks for the links again.
  15. Fred_H
    562
    488
    28
    Germany
    Hi Dxta, I do have a few more, but I need to sift through my files a bit. Here's another from Uncle Sam to start with:
    EVALUATION OF THE 2007 TOYOTA CAMRY HYBRID SYNERGY DRIVE SYSTEM
    https://www.osti.gov/scitech/servlets/purl/928684
  16. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Followed the link, but couldn't download it.
    Would try again.
    Thanks!
  17. Prodigyplace
    12,713
    11,848
    Central Virginia
    The link loads a pdf.
  18. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    As a former Gen 2 owner, I liked this chart of 2004 Prius M/G2 HP and Torque.
  19. padroo
    padroo Senior Member
    2,763
    2,253
    John Kelly at Weber University in Utah is the resident expert in my opinion on all the Prius CVT gearboxes.
    He also has worked on every type of CVT out there.
    They buy new cars and dissect then and see what makes them tick. His videos are addictive if you have ever watched one.
  20. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    OK, thanks Sir! Checking it again.
