Wheel spec and limitation
Discussion in 'Gen 5 Prius Main Forum' started by Emiri Rizuna, Dec 12, 2024.
  1. Emiri Rizuna
    Emiri Rizuna New Member
    japan
    2024 Prius Prime
    SE
    Hello. I am interested in taking wheels from a 210/220系 Crown (G-Executive/Athlete/Majesta), which all have a base sizes of 215/55R17 , 7 or 8J with offset ET40
    With the 2024 Prius SE being 195, would that even fit? Some of my friends have did a XW50 Prius with wheels off a 2017 RS Crown. I might have to use spacers? I included a link reference for photo [​IMG] [​IMG]
    What should i expect from rubbing, clearance and turning hinderance? I understand that it will decrease fuel economy
    Sorry for any confusion, i am new to wheels and my english is not very good.
  2. Eddie F
    Eddie F Junior Member
    Windsor, Canada
    2024 Prius Prime
    SE
    Emiri, as long as your center bore and bolt pattern are identical, width of the rim and offset are not too critical.
    195 looks a bit weird on an 8" wide rims:
    I'm using 7J x 17 with offset 50 off of Scion iM 2016. The wheels are a few LBs heavier than the stock ones.
    No rubbing noticed. Use wheel calculator to understand more:
    Rim & Tire Size Calculator. Custom Offsets - Wheel-Size.com
  3. jacobjoseph
    jacobjoseph New Member
    new york
    Can not see the pic
  4. KMO
    KMO Senior Member
    2,011
    734
    Finland
    2023 Prius Prime
    That's not compatible per tyre specs - you can't put a 195/60R17 tyre on an 17x8 rim. But you could go to 215/55R17, which is a more common size.
    (That's from the same site - and those icons do appear to be looking up the valid fittings from a table in the tyre standards manual)
  5. Johnny Lam
    Johnny Lam New Member
    2024 Prius Prime
    XSE Premium
    will 16" wheel size fit my 2024 Prius Prime which original comes with 195/50/19?
    need to put on winter tires but not many options in 195/50/19. tire shop recommended 205/65/16.
  6. Mendel Leisk
    41,901
  7. Johnny Lam
    2024 Prius Prime
    XSE Premium
    they recommend 205/60/17 if go with 17" but again, not many tire selection.
  8. thetoys
    thetoys Member
    28
    Toronto, ON
    2024 Prius Prime
    XSE Premium
    OEM size 195/50R 19
    Michelin X-ice
    Toyo GSi-6 available in Canada.
    You should read the reviews on these tires.
    They are both top tier tires.
    I’m currently running the Toyo GSi-6 on OEM 19 in Toronto
