Tire Size and Calibration Puzzle ?
Discussion in 'Gen 5 Prius Main Forum' started by Templeton, Nov 18, 2024.
  1. darkstar3274
    darkstar3274 Junior Member
    46
    2022 Prius Prime
    Reported on this or another thread: In similar weather (it is much colder now where I live), in full HV mode always, I got 55-62 mpg on full tanks versus 44-50 (at best) with the stock 19s (horrible especially for me coming from a Gen4 PP where I was consistently getting 62-67; averaged 62-63mpg over 18K miles) To note: I am not an aggressive driver and drive about 5 below speed limits on freeways (just keep away from the crowds) but on a A to B basis, this is what I have found so far. Inexact of course but a significant trend is there in the switch I made.
    My latest tank run yielded 51.7 (so there has been a drop from the relatively warmer weather of October (just have had the car since mid-September).
    Templeton likes this.
  2. KMO
    KMO Senior Member
    2,029
    751
    Finland
    2023 Prius Prime
    It doesn't know what size it's fitted with now, sure, if the owner's fitted something different.
    But it knows what it came with and what it's specced pressure is, and that's all it offers you as the preset. It doesn't offer you choices for different sizes. It only offers you the original pressure(s) for one size. So the pressure choices on your actual tyre label. Not for the other tyre size.
    The only choice you get is the normal or high speed pressure for the 17", if that's what you car came with, or no choice for the 19, if that's what your car came with.
    Hoping I've said it enough for the point to be grasped. Which is that there is not a single programming of the dash for both sizes. Increasing the chance that it uses this knowledge for the speedo and odo.
    It's possible the US UI is different, I guess.
  3. Gokhan
    Gokhan Senior Member
    6,708
    2,659
    Paramount CA
    Of course the car does not know what tires the car came with, but the assembly workers do. They set the TPMS accordingly when they assemble the car. I am pretty sure they use the same TPMS transmitters for all tire sizes. Likewise, the speedometer is set accordingly when it is assembled in the factory. I am sure somewhere in the speedometer firmware there is a parameter to set the tire’s revolutions per mile, which is done during or before assembly.
    #63 Gokhan, Nov 23, 2024
  4. Gokhan
    6,708
    2,659
    Paramount CA
    #64 Gokhan, Nov 23, 2024
  5. Trollbait
    12,816
    And I'm saying that having a selection for the TPMS is not evidence as to whether there are such settings for the meters, cause there is no need to tie the TPMS software to speedometer or over displays.
    All the car's computers need to know for the TPMS is a pressure set point to compare the sensor readings to. Toyota could have used car trim or pressure value instead of tire size on that display.
  6. Gokhan
    6,708
    2,659
    Paramount CA
    If that is the case, then perhaps Toyota calibrated the speedometer for the 17” tires for all trims, resulting in the LE/SE showing a higher speed on the speedometer for a given actual speed, which is normal behavior for Toyota speedometers.
  7. Johnny Lam
    Johnny Lam New Member
    2024 Prius Prime
    XSE Premium
    wonder if anyone ever use 16" wheel on a 2024 Prius Prime?
    just took my delivery last week and need to put on winter tires. 195/50/19 is the original set and some tire shop recommend 205/65/16 which have more selection in tire.
    the shop try on the 16" wheel and have roughly 1" space from the disk and brake pad vs 2"
    What will you do in this case?
  8. Mendel Leisk
    42,302
    Some are using 16" rims with snow tires.
    That's optimistic: one poster here got aforementioned 16" snow tire rims, and while they eventually worked, the hidden wheel weights (typically around 1/8" or 3mm high) needed to be shifted; they were brushing the caliper.
    It'll depend on the rim, but it's tight. Also, IS a miss as good as a mile, say if a pebble kicks up from the road, jams in there?
  9. Winston Smith
    Winston Smith Active Member
    456
    329
    OH
    2024 Prius
    LE AWD-e
    I wanted to put on some Prius V 16" wheels.
    When I pulled the covers off my 17" wheels, at the front I found almost exactly a half inch from the caliper to the wheel. If it would work, it would be extremely close. On my car (not a prime), 16" wheels would be a gamble.
    Some people win that gamble. Several people here have 16 wheels that work well.
    #69 Winston Smith, Dec 18, 2024
  10. Johnny Lam
    2024 Prius Prime
    XSE Premium
    thanks for the heads up.
