Shifted to N stop vehicle to shift to P
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Davabgaryan, Oct 22, 2020.
  1. Davabgaryan
    Davabgaryan New Member
    Armenia
    Hi there,
    As no research helped me to fix my problem I just want to post this here so you know it when running into this issue.
    If your Prius 2016 says "Shifted to N stop vehicle to shift to P" when starting it, most likely it's time to change your 12V battery.
    Other signs I had:
    The parking button light came up late.
    The car was working perfectly after starting.
    The message appeared in 50% of cases when starting the car.
    Have a good day.
    ihatenoise, bisco and krmcg like this.
    52,337
    welcome, thanks man!(y)
    krmcg likes this.
  3. ihatenoise
    ihatenoise Junior Member
    Toronto
    Thank you for this tip. My car was doing the exact same symptoms as you described. Replaced 12V battery and the message has not appeared since.
    The initial hint for me was the two rapid high-pitched beeps when starting the car (corresponding to the warning message). I had to use the slow-mo video function on my phone to grab the actual message, as it only appears for a split second before the Prius car animation is played.
  4. ihatenoise
    Toronto
    Here's the message displayed while the car is starting
  5. Paul Gregory
    Paul Gregory Senior Member
    2,223
    591
    Alberta
    2024 Prius Prime
    XSE
    Glad I didn't buy a Gen 4.
  6. Mendel Leisk
    41,850
    Toyota needs some editorial oversight, or less; they need something. A message like that is unintelligible.
    davecook89t likes this.
  7. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    C'mon man! It means, the car/computer thought it was necessary to disconnect the hybrid synergy drive, hence shifted to N. And now since there is no drive, it wants you to pull to the side, stop and place in P.
    If this happened while you were driving, you'd sense loss of drive, no reaction to the "gas pedal" and instinctively look for a way to coast to a stop off the road. Then you might notice the message and put it in P.
  8. ChapmanF
    18,486
    I think I would not read it the same way FuelMiser does—which I suppose supports Mendel's contention that it doesn't communicate well.
    If you showed me that message with no context, I would assume that you got it by pushing the P button while the car was moving, and the car reacted by shifting to N instead to avoid mangling the parking pawl, and explained to you that you should come to a stop first before shifting to P.
    Now, if that message came up when I was positive I had not just pushed the P button while in motion, I would next explore whether there might be any electrical cause for the car to think I had just pushed P while in motion.
  9. Mendel Leisk
    41,850
    Written by engineers, for engineers?
  10. ChapmanF
    18,486
    Well, I still suspect that message was intended for the case where you push P but you're moving, and it goes to N instead, and says "I went to N, stop the car first to shift to P".
    And I'm thinking if you were driving in that situation, and you had just pushed P but the car was moving and it went to N and a message appeared saying "went to N, stop the car first to shift to P", you'd think oh yeah, right, I get it.
    But in an odd situation where the message spuriously appears, probably because the ECU thought you pressed P but you don't think you did, it'd be puzzling.
    AzWxGuy and Mendel Leisk like this.
  11. ihatenoise
    Toronto
    To further clarify, the car worked just fine and didn’t have problems starting. I only investigated because of those extra two beeps, and the message flashing on the screen. And it was not every time the car started, although it did have a higher chance of happening if the car was left parked for few more days.
    my hunch — the lowered bus voltage caused the voltage levels of the some sensor to flutter and made the car think it’s moving or something. Certainly a puzzling message.
