Coolant going down - no idea of cause
Discussion in 'Gen 4 Prius Main Forum' started by Steelerfan2018, Jan 4, 2025.
  1. Prodigyplace
    12,462
    11,703
    Central Virginia
    I had a 2017 Prius Two for 57K miles with no issue, but much of my driving was at highway speeds. I have seen people here doing a lot of city driving having the issue. Perhaps that relates. i only stopped driving my Prius due to a collision with a 4Runner.
    amos likes this.
  2. Mendel Leisk
    40,974
    From what I've read (mostly here) it's due to a defective batch of the Exhaust Heat Recovery components: it has an internal radiator with coolant running through it during warm-up, and it's been leak prone, presumably due to defective welds.
    Later model years I think don't have the problem, though I think it dragged on a while, till Toyota "woke up". To date owners are having problems getting it fixed, due to dealerships, either due to ignorance or avarice, that misdiagnose as head gasket failure, and/or bill owners when Toyota would pay.
    I suppose Toyota's fine with that (Toyota and the dealerships conveniently enable each other), and as well seems to be dragging their feet on production of the (expensive) replacement component, which includes catalytic converter.
    And yeah, it does technically defeat a pollution control when owners do a bypass, and I'm sure both Toyota and the dealership would love to say it voids warranty.
    #42 Mendel Leisk, Jan 9, 2025
    BiomedO1 and amos like this.
  3. BiomedO1
    3,130
    1,660
    SacTown, Ca
    2016 & 2017 cars seems to be the ones failing. I think the issue was resolved in the 2018 model year.
    You technically aren't allowed to bypass it, because under CARB rules - that's defeating a "smog device component". If they catch you, you'll automatically fail smog and forced to go to a referee station for 'tampering' with a smog device.
    I wouldn't preemptively bypass it, because of what's stated above and denying coolant flow to the heat exchanger will probably hasten it's demise. No coolant to prevent the hot exhaust gases from melting the welded joints.
    Just pop the hood at every fill-up and take a glance at the coolant jar, probably check the oil too. It's a good habit to get into and will probably save you money in the long run - you'll catch potential issues early.
    Hope this helps....
    amos likes this.
  4. Prodigyplace
    12,462
    11,703
    Central Virginia
    Fortunately, many of us are not in a CARB state where that would apply, As always, YMMV.
    amos likes this.
  5. rjparker
    9,878
    6,089
    Maybe an extra 2 minutes
    Does not matter as the flow is always going through the exhaust gas heat exchanger.
    amos likes this.
  6. FuelMiser
    FuelMiser Senior Member
    1,349
    928
    Monument, CO
    I can't see how the coolant bypass is "defeating a pollution control device" since you are not altering the CAT or the flow of exhaust gases in any way. That said, if this leak happens to me, I will likely just replace the CAT on my $ and call it a day. It takes long enough to get heat in the cabin on cold mornings as it is.
    amos likes this.
  7. a2058
    a2058 Junior Member
    52
    Westchester, NY
    2019 Prius
    XLE AWD-e
    Just a data point, but I have a 2019 Awde, and was losing coolant. I kept adding coolant everyday for about 3 months, used about two gallons, no codes, temperature was in the normal range as monitored by Bluetooth dongle and a phone app. Finally got crazy with white smokes while accelerating, especially up hills. Got the bottom side bypass done a few days ago, I used a silicone hose since it’s so close to the cat. Also secured the flap to the straight flow through position on the exhaust. No more white smokes, coolant holding at the correct level, and the temperatures are not bad, it does run a bit cooler and takes a while longer to get warmed up, but it’s all good here.
  8. BiomedO1
    3,130
    1,660
    SacTown, Ca
    The faster heating of the engine coolant allows the ECU to lean out the mixture sooner - reducing greenhouse gases. Toyota considers that assembly part of the CAT, therefore emissions control device.
    The smog police failed one of my cars because of a patched hole in the air box. I think the previous owner was injecting propane or N2O through it. I had to get another air box from the junk yard. Just glad he didn't brand the car. This would've required me to go to a referee smog station at twice the cost and more in-depth look at EVERYTHING..
    YMMV
    MAX2 and Prodigyplace like this.
  9. rjparker
    9,878
    6,089
    Most states do not care if you bypass the exhaust heat exchanger or even the cat. In Texas this year they have abolished inspections. Safe, no. Good politics, yes.
  10. Ultimate_Combination
    65
    48
    Durham, NC
    Dear Lord I am so blessed I don't live in CA because this would drive me to walk up a tree.....
  11. 1980s_john
    1980s_john Junior Member
    42
    England
    Business Ed. Plus
    I'm another Gen 4 owner (in UK) with the same issue (slow coolant leak, no other problems). I took the car to Toyota service centre who did diagnostics (£180) and reported failed defective heat exchanger, leaking coolant into exhaust which burns off - smell and smoke (which I had not noticed). Booked in for replacement at further £1617. Car is 2016 and covered 135k (trouble free - except TPMS) miles, last Toyota service was 100k since then used independents so no warranty. Any UK owners had any luck with getting Toyota to pay a contribution?
    Regards,
    John
    PS - whilst coolant was low (ie before I topped up the engine coolant) I noticed a couple of issues. As it is warm the A/C is on every day. As you know when switched on the system always also switches on the air recirculation. I found that I could not switch off the air recirculation. I also noticed that once warmed up the car would not go into EV mode automatically (as per the vehicle hybrid mode display). Are both of these known symptoms of coolant / over heating issues?
  12. BiomedO1
    3,130
    1,660
    SacTown, Ca
    I don't know how the emissions standards and laws are structured in the UK; but it might be worth researching. Federal laws on this side of the pond is 8 years or 100K miles on all smog equipment. Some states has tighter standards, which has saved consumers a lot of money on these mandated smog devices. Check you year's make and model warranty booklet; it might be online. Also check for TSB, we had one here - that will sometimes extend the warranty on that particular problem.
    I believe the 2016 Prius is equipped with a heat pump ac system. What's the difference between a Heat Pump and Air Conditioning? You can turn-off your compressor by switching your HVAC system over to manual mode. The default is automatic climate control. They are not related to your exhaust gas heat exchanger issue. I don't know how the UK systems are programmed, but here in the states, I can turn my recirculate on or off at will. Some American cars you can't, HVAC system will over-ride you.
    Hope this helps....
    #52 BiomedO1, Aug 5, 2025
  13. Prodigyplace
    12,462
    11,703
    Central Virginia
    In the US it is an electric AC compressor. Only the Prime PHEV got the heat pump.
    BiomedO1 likes this.
  14. UN4GTBL
    UN4GTBL Junior Member
    Technology
    Just providing a Canadian data point: our 2017 Prius with ~127,XXXkm had this happen last week, and it was fixed under our 8 year emissions warranty, and the updated part was available in the Toronto PDC for next day delivery to our dealer.
  15. Mendel Leisk
    40,974
    Just curious: what do you mean by PDC? I did search, got nowhere.
  16. BiomedO1
    3,130
    1,660
    SacTown, Ca
    I'm assuming PDC = parts distribution center
    UN4GTBL and Mendel Leisk like this.
  17. UN4GTBL
    Technology
    Sorry, this is what I meant
