DTCs for simultaneous, solid ABS, BRAKE, and Slip Indicator dash lights
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kehyler, Jan 11, 2025.
  1. kehyler
    kehyler Member
    84
    31
    blah
    Hi Guys,
    On a morning commute I got a solid ABS, BRAKE, and Slip Indicator dash lights for about half the commute. Evening commute back home had no lights on. No firm observable on the brake system so far, all appears normal.
    Here are the DTCs as read out by the jumper wire method:
    • Slip Indicator Light -> 43
    • ABS warning Light-> 33 & 38
    • Brake system warning light -> 36
    Just last week, I did swap in snow tires & rims for the first time. Lights appeared about 1 week later.
    Could someone point me to where in the repair manual the real DTCs are stored? Other ideas as too root cause?
    Thanks,
    -kehyler
  2. rjparker
    10,106
    6,267
    I normally recommend 94 year olds from blah seek qualified help or maybe stop driving. Can't contribute to possible injuries caused by diy in a critical system.
    I would get a capable scanner (usually Techstream) that read the actual dtcs and info codes.
    Several at once usually means one is causing the others
    "When 2 or more DTCs are detected, perform circuit inspections one by one until the problem is identified."
    In most cases on gen3s, the brake booster fails.
  3. kehyler
    kehyler Member
    84
    31
    blah
    ^I thought the flashing lights indicated specific DTCs? I just don't know where in the repair manual that lookup table is.
  4. ChapmanF
    18,101
    You thought right. Our page about the blink codes already tells you about the VSC 43 and ECB 36 blinks, which both just mean "hey, there are real codes on the ABS light, go look at those."
    Blink (a/k/a Flash) Codes – How to. | PriusChat
    As for the 33 and 38 on the ABS, you're also right that you'll find the corresponding DTCs in the repair manual. The blink code page linked above shows you how.
  5. kehyler
    kehyler Member
    84
    31
    blah
    Okay, so I guess the DTC codes are C0210 and C1238.
    C0210, "Rear Speed Sensor RH Circuit"
    While driving at 10 km/h (6 mph) or more, speed sensor output from one or two wheels is lower than that from other wheels for 15 seconds or more.
    C1238, "Foreign Object is Attached on Tip of Rear Speed Sensor RH"
    Either of the following is detected:
    1. When driving at 20 km/h (12 mph) or more, noise occurs on the speed sensor or signal waveform for 5 seconds or more.
    2. When driving at 10 km/h (6 mph) or more, noise occurs once per wheel revolution for 15 seconds or more.
    Maybe this line of attack, working from easy to hard.
    1. Clear codes & demonstrate repeatability of problem.
    2. Swap non-studded tires back on for a week or two, comment about noise made me think this could be worth a try.
    3. Unplug replug wiring harness @ both ends.
    4. Replace right rear wheel bearing to get new sensor
    5. Replace wiring harness.
    6. Cry & bring it to someone with more intelligence than me.
    #5 kehyler, Jan 11, 2025
  6. Brian1954
    Brian1954 Senior Member
    2,167
    843
    South Central PA, USA
    Code C1238 is not for the "Front Speed sensor RH", it is for the "Rear Speed Sensor RH". I am guessing that you made a typo.
    kehyler likes this.
  7. kehyler
    kehyler Member
    84
    31
    blah
    Oops, edited in-case someone gets looks this thread up in the future.
    Brian1954 likes this.
  8. kehyler
    kehyler Member
    84
    31
    blah
    Did #1 yesterday, and did not get the codes back after ~15 miles of driving. I'll keep this thread updated.
    Just for my personal knowledge, is this part of the repair manual the "troubleshooting information"? From the repair manual, C0210/33 lists the following under Trouble Area for INF code 521
    Open or short in speed sensor
    Improperly installed speed sensor, or
    abnormal clearance between sensor and rotor
    Open or short in wire harness
    Improperly connected connector, deformation or corrosion of terminals
    Rear speed sensor RH
    Brake booster with master cylinder (Skid control ECU)
    What I'm asking is, for example let's say I do in fact have an open or short in the wire harness. Is there further troubleshooting information on how to detect that in the repair manual somewhere? Some section like, "Use a volt meter between pin X of wheel harness and pin Z of skid control ECU. If open circuit, replace wiring harness." Or am I supposed to do my best troubleshooting given "Open or short in wire harness" as my start.
    The is the first time I've cracked open the repair manual, so I'm unfamiliar with how detailed they get & if I've found the right place.
  9. kehyler
    kehyler Member
    84
    31
    blah
    Well, a few days of commuting and still no repeat of the lights. Maybe it was a one off issue...
  10. vvillovv
    vvillovv Senior Member
    4,321
    1,509
    NY
    Ah ha ! Yes ! But you need some way of getting the INF codes that go along with any one DTC code.
    Techstream systems is what Toyota uses coupled with the Repair Manuals DTC and INF code descriptions and troubleshooting instructions.
    There are cheaper alternatives some of which have been show to include INF s too. One of those is the Autel AP200 which is an - OBD2 bluetooth adapter - that connects to a smartphone that runs the Autel App. When coupled with a $25 standard two day subscription to the Repair Manual can be an effective way to learn way more than you may have ever wanted to know about a Prius.
    Here is a thread that reviews many of the available tools
    started by @mr_guy_mann with emphasis on Gen 2, but also addresses a few other models.
    Gen2 OBD2 app review | PriusChat
  11. ChapmanF
    18,101
    There are two places in the repair manual where you can find a list like that. The first is just the "diagnostic trouble code chart" at the front of the brake section, just a big table of trouble codes one after another, shown with their fortune cookies and trouble areas. That place doesn't help you very much.
    The "troubleshooting information" for C0210 is the section that starts with a page like this and goes on for thirteen more pages of steps you can follow to troubleshoot the problem:
