P0420 Catalyst System Bellow Threshold Bank 1?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by KitsuneVoss, Jan 25, 2025.
  1. MCCOHENS
    MCCOHENS Active Member
    252
    101
    Chalfont, PA
    ok, first off be very careful on "cheap" parts as sometimes they are crap. On O2 sensors, buy name brand with the plug attached. Sometimes the instructions are wrong which can lead to killing the ECU. BTDT. I would try the cat additive and also consider pulling the MAF and cleaning it with MAF spray cleaner. It is easy, may require a torx bit but worth having as the MAF cleaning should be an annual thing. Also, if it the O2 sensor does turn out to need replacement proceed carefully. They can be rather tough to break loose and have been known to strip out the threads in the pipe.
    On oil consumption, with your mileage if the car was not well maintained it may just be a worn out motor. Some will try an oil ring cleaning procedure, which is cheap but time consuming. You can find lots of BTDT on this forum.
    Hope this helps more than some of the other posts!
  2. rjparker
    10,553
    6,622
    I did not say it has to be welded. Reread.
    None of the cat or oil burning additives work. However a clogged cat can cause engine failure and fires.
    #22 rjparker, Jan 27, 2025
  3. saneesh8
    saneesh8 Member
    214
    53
    Allen, TX
    Catalytic converter on ebay is ~$100 with 5 year warranty. Rock auto have it for ~$250.
    Does any one tried any of these after market brands?
  4. KitsuneVoss
    KitsuneVoss Member
    371
    55
    Virginia
    A minor update. My oil was low when I checked the dipstick a little while back, likely at least two weeks back although maybe even three weeks. I did not check afterwards but likely added about two quarts. Likely driven anywhere between 700 and 1050 miles between then and now. Checked it just now and the oil level is still pretty high so I don't think the engine is burning excess oil.
    Have not interrogated the computer yet. Have so many things on my plate that I often lose track of things.
  5. KitsuneVoss
    KitsuneVoss Member
    371
    55
    Virginia
    Some minor updates and questions. I have a new catalytic converter I got from Rock Auto. Figured more trustworthy than eBay and decided to order it before tariffs make prices go insane.
    I do know of an old man who used to work on exhaust systems. He was cheap but did a good job. He is a short "Prius" distance from home even though I moved. Figure check if his shop is still where it was. If I can get him to weld it, should I?
    Also, if I remove it myself, I know someone who welds. In such a case, would I be better off getting it welded by him or better off clamping it? Concerned that if the fitting is not perfect and welded, might not fit?
    Also, if I end up doing it myself, I have a grinder. Would that work for cutting the pipe or would I be better off getting a reciprocating saw as is used in this video at the 7:00 mark?
    Also, I want to clean the intake system a bit. I was thinking about spraying to down at least real well with throttle body cleaner. I have removed throttle bodies in other cars to clean them but would prefer to wait on that. There is a video where the person did not want to push on the throttle body to get the underside. Is that an actual concern?
  6. KitsuneVoss
    KitsuneVoss Member
    371
    55
    Virginia
    Update: I ended up going to a shop to get the catalytic converter replaced. Ed's Muffler Shop if interested.
    It is the older person I mentioned last post and has been around for I think decades.
    Charged me $100, so not bad.
    #26 KitsuneVoss, May 5, 2025
    saneesh8 likes this.
  7. rjparker
    10,553
    6,622
    That is a reasonable price. The next question - will the P0420 stay off?
  8. KitsuneVoss
    KitsuneVoss Member
    371
    55
    Virginia
    I don't know but will post an update in a little bit (few days to a few weeks.)
    At the shop, Ed's Muffler shops in Chesapeake VA, Ed did say that the O2 sensor in the cat looks good. he said that usually bad ones look black and/or scorched . Doesn't sound like he works on hybrids often but has DECADES of experience. I went to his shop for repairs first likely 20 years ago and I think he was long there already. He likely has more experience with O2 sensors than almost everyone on this board combined.
    Edit: One local shop quoted me that it could be up to around $300.
    #28 KitsuneVoss, May 5, 2025
  9. rjparker
    10,553
    6,622
    What model cat did you buy from Rock Auto?
  10. KitsuneVoss
    KitsuneVoss Member
    371
    55
    Virginia
    Walker 16337
  11. KitsuneVoss
    KitsuneVoss Member
    371
    55
    Virginia
    I drove likely about 100 miles today as well as a couple of quick trips and coming home from Chesapeake after the cat was installed, so I have likely driven 170 miles without and codes. Don't know if it will stay that way but at least looks good at the moment.
    #31 KitsuneVoss, May 8, 2025
  12. KitsuneVoss
    KitsuneVoss Member
    371
    55
    Virginia
    Updates since that response. No codes in the 10 days since replacing the Cat and my MPG is not at 44.6 mpg. I don't resent my mpg at fill ups but instead let it change slowly. Win the new fuel injectors and cat, I am seeing a lot of 50+ mpg on the bar graphs as well so likely will go up more.
  13. Mr.Vanvandenburg
    1,358
    596
    2020 Prius Prime
    It also only takes an air leak in the intake after the MAF sensor. So many good O2 sensors go in the trash.
  14. douglasjre
    douglasjre Senior Member
    2,205
    736
    Null, NL
    Would another career mechanic like to provide the laborious explanation to kitsunvoss why he's wrong? SMH I have no choice but to block you man. You should probably block me too. Don't bash career mechanics. The full answer about how it goes when a customer brings his own parts is one you can't appreciate. Your accusations about career mechanics lying to you was uncalled for. Now go away
    #34 douglasjre, Jun 9, 2025
  15. mr_guy_mann
    mr_guy_mann Senior Member
    4,098
    2,000
    NJ-USA
    Not really. You can't change beliefs with a few words.
    I said what I needed to in post 3. That and I've wasted too much time to use crap AM parts.
  16. ChapmanF
    18,569
    I had to click the ↑ in that quote in order to learn what post KitsuneVoss had been replying to. It wasn't my post about how the catalyst effectiveness gets tested.
  17. KitsuneVoss
    KitsuneVoss Member
    371
    55
    Virginia
    If it was going to just be a pile on Kitsune, I did not consider any need to respond.
    In my defense, if you google "repair shops doubling cost of parts," you get substantial support for my argument that they do so. Some sources state "Double or more." Maybe they have to charge that to stay in business. I am not too bad at math and the numbers, especially with a labor rate of $105 an hour (recent one I was quoted) don't seem to work but maybe I am forgetting something. If they have to charge that, I cannot afford their labor+cost. I am still forced to do it myself. I also have in the past bought parts and had mechanics put them on.
    People who said it was the cat, not the sensor I listened to. Those that suggested that if I end up buying a new O2 sensor, I should get Denso, I also listened to. In the end I end up replacing the cat and ran great for a while until something serious happened with the engine, which honestly just seems bad luck, since I think I checked the oil within the last few days before it happened.
    #37 KitsuneVoss, Jun 9, 2025
  18. ChapmanF
    18,569
    I've pretty much all my life understood dealer parts markups to be somewhere in the neighborhood of 100%.
    In my early years when the cars I was driving kept me going in for a lot of parts, it happened at more than one dealership that somebody at the parts counter would start recognizing the kid who kept coming in all the time, and would start quietly giving me to-the-trade pricing without me ever asking, and that was often nearly 50% less than the list, and I suspect even their to-the-trade prices do not lose them money.
    Since I bought my first Prius, I've pretty much lost that special treatment everywhere I buy parts. The darned cars just don't need enough work.
  19. KitsuneVoss
    KitsuneVoss Member
    371
    55
    Virginia
    I am currently driving the older 2003. Looks more like a Camry or something, not a Prius. The local Toyota dealer wants 300 and change, maybe 360 but might be misremembering the exact amount, for a new battery. They would have to special order it however. There is also no "Out in the world" equivalent. Called another dealer and they want 400 and change. Also have to special order it. I do remember that it was over $100 more than my local wanted. All Toyota dealers seem to charge their own prices. Ended up using a lawn mower battery Hey, it works.
  20. ChapmanF
    18,569
    Yeah, somewhere around pandemic time, my local dealer started a new game where they print out parts quotes where the Toyota list price is the number they show in the "discounted" column, and what they show in the "list" column they further mark up above that.,
