Immobilizer Code Reset Failed (Smart Key Reset)
Discussion in 'Gen 2 Prius Technical Discussion' started by Kris_Parker, Jun 29, 2024.
  1. Kris_Parker
    Kris_Parker Member
    107
    17
    Chicago, IL
    Long story short, I have 2005 prius with SKS and I lost the last fob, after a little research I decided to reset the immobilizer (to delete all connected keys to this car) and register a different used key from another prius. I found a third party with pass-code calculator (5 tokens for 25$) but my problem is whenever I try to start this 16 minute reset process I have a fail. This happens because I don't have any keys and I can't start the car (OG - On, one click to the push button) and because of that I can't connect to the immobilizer and reset anything. Does anyone have any suggestions?
  2. PriusCamper
    PriusCamper Senior Member
    13,139
    5,321
    Pacific Northwest, USA
    Sounds like the reseeding process after the wiping clean of the system is where it's failing. Assuming you're doing this with Techstream? Maybe try a different Windows computer? Or maybe ask an electronic locksmith who does this work?
    Seems there should be a process during the wipe & reseed where the new FOBs are registered into the system? Is it failing before you get to that step?
    Meg&Bear likes this.
  3. Kris_Parker
    Kris_Parker Member
    107
    17
    Chicago, IL
    Yes, I'm doing this via a Techstream. I don't think a Window is the problem. Unfortunately I'm don't know any locksmith who works with Toyota's or Techstream. It fails right after I put the passcode and press next, there is a notification about that resetting can take about 16 minutes and when I press 'OK' I have the same thing as on a picture. The Driver door is open, the immobilizer is flashing (so it works) but because the power is not ON i can't procced forward.
    Prius Lost All Keys SKS Smart Reset (Program Used Fob) I was following after this instruction.
  4. DashingDave
    DashingDave Junior Member
    39
    Monterey
    Hi Kris,
    Since you haven't followed up in many moons, I'm assuming you have it running.
    Any hints on what process to follow - as I'm in exactly the same stuck you were.
    Thanks,
    David
  5. Kris_Parker
    Kris_Parker Member
    107
    17
    Chicago, IL
    David. Unfortunately for you I have found that key (it was laying on the ground) and didn't proceed with reseting. The best you can do is to find someone who makes keys, or look more into advanced tools for this job. I remember looking at scanners for $1000-2000 + other devices, that can do this job, but unless you're planning you continue working with making keys, you're best way is to pay that $300 for a new key one. Techstream didn't worked for me and I still have that 5 tokens.
  6. ChapmanF
    18,637
    ... and the found old key still works, so I guess the reseeding never did ...
  7. Kris_Parker
    Kris_Parker Member
    107
    17
    Chicago, IL
    Correct. That car got into an accident + ABS module failed (bleeding or calibration didn't help, it was to late). So I just sold it because didn't want to invest into it anymore.
  8. DashingDave
    39
    Monterey
    Thanks Kris,
    I did halfway get Techstream to work: Immobilizer reset, but new SKS FOBs not yet registered.
    Sending you a PM
  9. YETi89
    YETi89 New Member
    Kansas
    Dave,
    How did you get the immobilizer reset?
    Techstream V18.00.008 immobiliser code reset fails because I cannot get IG-ON with new key fob in the slot. Pressing the button doesn’t do anything. Mine is without SKS but reseting part should be the same process?
    Thanks
  10. Kris_Parker
    Kris_Parker Member
    107
    17
    Chicago, IL
    I got stuck at the same place. I bought tokens, everything works but after short moment immobilizer code reset fails. I didn't found a way and just wanted to pay for that key.
  11. forumoto
    forumoto Junior Member
    USa
    2002 Prius
    I
    I can help you fix that problem.
  12. forumoto
    USa
    2002 Prius
    I
    Message me on TG: wannapreg
  13. forumoto
    USa
    2002 Prius
    I
    Do you still have the token available … do you mind to gift me( smile ), TG me on wannapreg
