CAN bus settings.
Discussion in 'Gen 2 Prius Audio and Electronics' started by ALCRO, Nov 22, 2023.
  1. ALCRO
    ALCRO Junior Member
    31
    Croatia
    Hello,
    Few days ago i buy 9inch android head unit that goes on MFD place.
    And i have trouble connecting can bus box to work so that i can have climate control on my Prius 2 gen.
    Is there any solution for this?
    I place the resistor between 9 and 10 pin.
    But still no fan control for climate.
    Here are few pictures.
    I have no more idea. I like the screen but its pain to play with heating only in steering wheel.
  2. ALCRO
    ALCRO Junior Member
    31
    Croatia
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,086
    1,997
    NJ-USA
    I don't know your Android unit at all, but the Gen2 Prius doesn't use CAN network for the MFD or climate control.
  4. ALCRO
    ALCRO Junior Member
    31
    Croatia
    Its aftermarket Head Unit. I'm not sure how can i get climate control to work. I see in few posts that people need to put resistor and that climate works but it works on a navigation OEM screen and my Head Unit is replacing the OEM navigation so i don't have heating controls.
    Any suggestion how to wire it or what to check?
    Thanks in advance.
  5. black_jmyntrn
    black_jmyntrn Senior Member
    1,728
    409
    2013 Prius Plug-in
    Which radio did you purchase?
    I am planning on getting this one, it says and shows the a/c screen and HV battery screen.
    https://s.click.aliexpress.com/e/_DBcwp5p
    Can you link to the one you purchased?
  6. ALCRO
    ALCRO Junior Member
    31
    Croatia
    Sorry for late replay, ill link radio later this evening when i come from home.
    After around 6 months i still dont have AC controls and HV battery screen. But i think seller sold me wrong cable. because from original navigation screen i have 2 connectors and on wiring harnest from android headunit i have only one connector that i can use. And if my android head unit is connected and working, i can connect original navigation screen and i can control AC only with one connector plug in. So i guess i get wrong wiring. But didnt have time to dissasamble it for the 25th time.
  7. ALCRO
    ALCRO Junior Member
    31
    Croatia
    Here is the screen shoot from seller, dont order from him. He didnt help at all just stall, a eventualy issue a refund and i get 60euros of refund.
    And i order those cales and i think they are wrong, on the label it said RAV4 and Camry
    If anyone have right cable for prius 2 gen il be happy to know :D
  8. black_jmyntrn
    1,728
    409
    2013 Prius Plug-in
    just reading this today... where I am at is i pulled the headunit from my Gen 3... looks like two connectors are the same and trying to track down either two connectors and i make a harness to go from the Gen 2 to the Gen 3 plugs or I find a Gen 2 harness for this radio... thing is, I have the canbus box and after lots of reaseasrch and findout out which other Toyota shares the same connectors to then finding out they have Tesla style screens with the climate control... I am not trying to hunt down these details as it sounds like i should be able to have a/c controls using the headunit I have. Ill post more when i have those detaqils.
  9. black_jmyntrn
    1,728
    409
    2013 Prius Plug-in
    ohhhh.. you have to change the canbus settings... uhm. I need to find the exact settings through my notes... also, can you post a picture of the sticker on your canbus module?
    you see here.. if not mistaken, this is your problem. i cant wait to get another tablet, these days my notes have been horrible and all without mine.
  10. vvillovv
    vvillovv Senior Member
    4,324
    1,512
    NY
    I thought of this post while I was writing out this text exposed in a binary file inside a virtual filesysystem and trying to figure out where the spaces belonged. This thing has gotten crazy with 3 completely different ways to setup and use.
    What I know so far about it saved me for a hard crash / reboot situation around midnight in this session I'm writing this in.
    While trying to grab the text from the binary file to post it here, I figured out how to put the text into a line separated list. But this is what it looks like as one line with all spaces removed like in the binary
    zcomp_paramsdict_szzcomp_ctxzcomp_strmzcomp_reqzcomp_opscreate_ctxdestroy_ctxsetup_paramsrelease_paramszcompzstrmzram_pageflagsZRAM_SAMEZRAM_WBZRAM_PP_SLOTZRAM_HUGEZRAM_IDLEZRAM_INCOMPRESSIBLEZRAM_COMP_PRIORITY_BIT1ZRAM_COMP_PRIORITY_BIT2__NR_ZRAM_PAGEFLAGSzram_table_entryac_timezram_statscompr_data_sizefailed_readsfailed_writesnotify_freesame_pageshuge_pageshuge_pages_sincepages_storedmax_used_pageswritestallmiss_freebd_countbd_readsbd_writeszrammem_poolinit_locklimit_pagesdisksizecomp_algsnum_active_compsclaimbacking_devwb_limit_lockwb_limit_enablebd_wb_limitpp_in_progresszram_pp_slotzram_pp_ctlpp_bucketszram_workblk_idxcurrentOffsetinitCheckbufferStartLZ4_stream_t_internalLZ4_stream_tlz4_ctxdstrmcstrmLZ4HC_CCtx_internal
    LZ4_streamHC_tlz4hc_ctxzstd_ctxcctx_memdctx_memzstd_paramsdeflate_ctxalgorithm_params_storebacking_dev_showbacking_dev_storebd_stat_showcomp_algorithm_showcomp_algorithm_storedebug_stat_showdeflate_compressdeflate_createdeflate_decompressdeflate_destroydeflate_release_paramsdeflate_setup_paramsdestroy_devicesdisksize_showdisksize_storefree_block_bdevhot_add_showhot_remove_storeidle_storeinitstate_showio_stat_showlz4_compresslz4_createlz4_decompresslz4_destroylz4_release_paramslz4_setup_paramslz4hc_compresslz4hc_createlz4hc_decompresslz4hc_destroylz4hc_release_paramslz4hc_setup_paramsmax_comp_streams_showmax_comp_streams_storemem_limit_storemem_used_max_storemm_stat_showread_block_staterelease_pp_slotwriteback_limit_enable_showwriteback_limit_enable_storewriteback_limit_showwriteback_limit_storewriteback_storezcomp_available_algorithmzcomp_available_showzcomp_compresszcomp_cpu_deadzcomp_cpu_up_preparezcomp_createzcomp_decompresszcomp_destroyzcomp_stream_getzcomp_stream_putzram_addzram_destroy_compszram_exitzram_free_pagezram_initzram_openzram_read_pagezram_removezram_remove_cbzram_reset_devicezram_slot_free_notifyzram_submit_biozstd_compresszstd_createzstd_custom_alloczstd_custom_freezstd_decompresszstd_destroyzstd_release_paramszstd_setup_params
    It took both sides of a sheet of paper to hand write that single line of text out.
    Progress on this journey is slow and steady. :D
    black_jmyntrn likes this.
  11. black_jmyntrn
    1,728
    409
    2013 Prius Plug-in
    you complete me!
    vvillovv likes this.
  12. black_jmyntrn
    1,728
    409
    2013 Prius Plug-in
    what does your canbus box look like? the climate controls are triggered by the snow flake.
  13. ALCRO
    ALCRO Junior Member
    31
    Croatia
    I did drive for a while without real ac controls, just button on the steering wheel. :whistle:
    Now i wanted to try once more.
    I attachment is .y canbus but im not sure i have the right wiring loom for prius with navigation and jbl system.
    Could use help. :)
  14. ALCRO
    ALCRO Junior Member
    31
    Croatia
    I did try different settings of canbus but seems like its not connected to the canbus box the proper way or i need to use 68ohm resistor on all white pink wires on connector that is not connected to close the canbus circle
