WARNING: Extension Cords
Discussion in 'Prime Plug-in Charging' started by Rob43, Oct 15, 2019.
  1. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    Right! Or, more formally, I=E/R.
    If the load could command a certain wattage, then current would rise as voltage drops, but it can't. So that formula is P=Esquared/R. Either way, as resistance goes up, voltage drops and so does power.
    Doug McC likes this.
  2. fuzzy1
    10,588
    Do note that with the widespread use of switch mode power supplies today, there are lots of loads that can command a certain wattage, or a certain current, regardless (almost) of the line resistance. These can make mincemeat of the old resistance rules, so some devices really do appear to have negative resistance, i.e. load current increases when input terminal voltage drops.
    jerrymildred likes this.
  3. jerrymildred
    11,517
    14,157
    Tampa, FL
    I haven't actually studied them much. I assume that's because of the feedback used to regulate them?
  4. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Correct.
    You can design the controls in a switching power supply to regulate almost anything you want. Voltage is the most common but some regulate current and every battery charger does both depending on where you are in the charge cycle (current at the beginning, voltage at the end).
  5. chuckiechan
    chuckiechan Member
    172
    53
    Roseville
    2020 Prius
    Good point. In California you are asked to charge at night because the grid is too weak.
    Also, you are used to spending when you buy a new car, so cough up a few bucks for a “dedicated” extension cord.
    BTW, is there such a thing as an in line thermal breaker, in stead of relying on the breaker in the box?
  6. Elektroingenieur
    2,515
    3,287
    Three Touring
    The Toyota charging cable has a temperature sensor in the plug (also linked in #23 above).
    Commercially-available, in-line GFCI devices typically provide only ground-fault protection, not overcurrent protection (thermal, thermal-magnetic, electro-synthe-magnetic, or otherwise) but I suppose one could put a miniature circuit breaker or supplementary protector into a small enclosure with cable glands.
    To be clear, I don’t recommend using extension cords for EV charging at all. (EV operation is fine, of course.)
  7. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Southwire E-238 Heavy Duty Power Station Cord reel, with 6 Grounded Outlets, 12/3 50-Foot Extension Cord, Built In 15-Amp Circuit Breaker, Green/Black https://a.co/d/j57pf8g
  8. Primacus
    Primacus New Member
    Hello,
    Looking for safety confirmation on the following charging config:
    Apartment detached garage using a GFCI outlet, unknown amp rating of circuit and gauge of wiring to outlet.
    From outlet I am using a 14 AWG 50ft 15A all copper extension cord. Purchased from Lowe's at about $37
    See cord details below:
    primewirecable /collections/general-purpose/products/ec50173050ft-14-3-sjtw-orange-outdoor-extension-cord
    Weirdly the copper statement is on a different page:
    primewirecable /blogs/news/ten-quality-reasons-to-buy-prime
    I believe I fall within the safety margins but have not taken temperature readings at the connector housing.
    Any and all feedback appreciated.
  9. vvillovv
    vvillovv Senior Member
    4,324
    1,511
    NY
    Do you have insurance that covers electrical fire?
    Did you read the owners manual that came with the car about using extension cords and EVSE safety?
    You already know where the visual signs of trouble will show up, but you are also missing key information about the circuit between the service drop and the GFCI outlet, were the issue(s) you can't see can occur.
    Use at your own risk !
  10. BiomedO1
    4,019
    2,109
    SacTown, Ca
    IMHO; 14-3 is too small!!! People here stating that there's only 14G in the walls as an excuse, obviously aren't electrician or engineers. 14G in the walls are solid copper core; NOT stranded questionable material cheap extension cords! Vendor's tend to exaggerate their specifications and that cable is going to draw 12A @ the end of that charge cable. You need to find out what other appliances are plugged into that circuit, because your likely to blow it. Your only 2-3A from blowing that breaker because that extension cord is drawing more current at the wall outlet than coming out at the other end.
    You need to go down to a 12-3 yellow construction extension cord at 25 feet max.. That along with your 20+ feet charge cable should be more than enough. The shorter cord will lower voltage and current drops across the entire length. Safer to operate and check for connection heat-ups 0.5 to a hour into charging - They shouldn't be warm; otherwise you have a problem brewing!!!
    Hope this helps...
    FWIW; I had to replace the ends on my construction extension cord because it was heating up - bad connections = high resistance = heat. Those cheap extension cords need to be checked on a regular basis, otherwise best case you just pop a breaker - worse case you burn down your garage/home.
  11. vvillovv
    4,324
    1,511
    NY
    @bio it's an apartment detached garage. who knows what's in the walls or why a 50 ft ext is needed?
    ed: heat where the extension plugs into the GFCI (probably a 15 Amper e) is an eventual certainty, exactly when and from which external conditions is any ones guess.
    @jerrymildred if you see this please correct any of my assumptions above.
    #111 vvillovv, Mar 12, 2025
    BiomedO1 likes this.
  12. BiomedO1
    4,019
    2,109
    SacTown, Ca
    You DO NOT fall within safety margins; because the Toyota OM specifically states not to do that. You may also want to limit your charging to 8A max; within your car's charging sub-menu. It'll take twice as long to recharge, but your less likely to be popping circuit breakers too.
    Yea, I saw that. If he didn't get permission from property management and something happens - he'll be liable.
    vvillovv likes this.
  13. vvillovv
    4,324
    1,511
    NY
    The poster could also be the property owner. There are just to many things left out of the post that should be answered by a licensed electrician that can check on site. ( non free firmware) $
    Read some of these questions and answers by Dave
    https://ask-the-electrician.com/dave-rongey.htm
    #113 vvillovv, Mar 12, 2025
  14. bisco
    52,286
    I’m not an electrician, and many electricians are unqualified to answer your question.
    I have read that extension cords cannot carry the same capacity as house wiring because of the braided wire and connections.
    Even house wiring often has inadequate connections for the constant high draw of an evse
    So the safest thing to do is to get an extension cord size equivalent to house wiring code for 50’, and research the cord brand with the safest connectors.
    I would also check the connectors for warmth
    on a regular basis
  15. Mr.Vanvandenburg
    1,357
    579
    2020 Prius Prime
    I use a kill a watt meter sometimes to check outlets. Check the outlet voltage, then plug charging cord in, check voltage drop and watts under load. Check voltage drop on your extension cord too.
