Tyre pressure warning
Discussion in 'Gen 5 Prius Main Forum' started by chris johnson 2, Feb 3, 2025.
  1. rjparker
    9,886
    6,093
    Getting a proper patch is either free from the tire shop where bought or $15 at a local used tire shop. The free shop includes inside tire inspection and balance. The v has a spare which has been used twice in 14 years for less than a day.
    Gokhan likes this.
  2. Gokhan
    Gokhan Senior Member
    5,923
    2,339
    Paramount CA
    Here, tire repairs (with a combined patch and plug) and rebalancing are free at the American Tire Depot locations, even if you didn’t buy the tire from them.
  3. mva
    mva Member
    120
    72
    B.C. Canada
    2024 Prius Prime
    SE
    I have had good success using plugs over many years. This Project Farm video gives me confidence that they are pretty good - especially for a vehicle that alarms if the tire pressure drops below an acceptable level. He repairs a tire with 100 plugs at 12:07 in the video:
  4. Gokhan
    5,923
    2,339
    Paramount CA
    So, only after six weeks, I got a nail in the same right rear tire. Since it had a two-year warranty, I took it to Downey Toyota again today and had it replaced with a brand-new one free of charge under warranty. (They don’t repair tires at Toyota dealers.) In hindsight, I was very lucky that Priority Tire had sent me the wrong tire and I had got it from the Toyota dealer instead. From now on, I will only get them from the Toyota dealer, considering the nail/screw issues and warranty.
    @Mendel Leisk, why do I keep getting these nails/screws in my tire? This is the third one in six months in the same tire. Have you had a similar problem? During the first four years, I had no nails/screws.
  5. Mendel Leisk
    40,987
    Remember that chain-mail letter you shredded…
  6. rjparker
    9,886
    6,093
    Why does the chicken cross the road? The answer is literal and straightforward. Same with nails. Generally construction areas have them on the road. Some garages have stuff lying around as well.
    Trollbait likes this.
  7. Mendel Leisk
    40,987
    There's one corner of a nearby Rona parking lot (lumber/hardware place up here) I stay clear of: it's where they sometimes stack bundled lumber. The bundles are typically wrapped with thin-plastic tarp material, secured with long staples shot through little plastic disks. The workers there have a propensity to pull the covers off right there in the parking lot, and those staples-disk combos fly all over the place, and more-often-than-not end up with staple tips pointing skyward. Besides car tires, an unpleasant surprise if you're wearing thin-sole shoes...
  8. BiomedO1
    3,156
    1,670
    SacTown, Ca
    OR you've pissed someone off and they're taking it out on your tires.:sleep::cry:
  9. priusdriver223
    82
    31
    Lala Land
    2023 Prius
    XLE AWD-e
    Hey there, same thing happened to me and after I realize these factory tires just get flats due to the nature of their low profile, I decided to just switch my entire wheel setup and use 235/45 for my tires, never had an issue since, cross my fingers. Cheers!
