Project Lithium Nexcell V2
Discussion in 'Gen 3 Prius Accessories and Modifications' started by AzusaPrius, Mar 27, 2023.
  1. Bill Norton
    Bill Norton Senior Member
    2,157
    734
    MONW, Ks.
    Don't know about any dyno testing....
    But testing anything is a good idea!
    I asked years ago about the 'affiliate link' to a 'Water Injection' system and some anodized aluminum valve that makes your prius so much 'better' than with the stock valve.......
    Testing this snake oil crap should be easy.
    And what do they all make from posting all their 'affiliate links'? A buck and a half? Is it a taxable income? (n)
    If someone is posting links to products, that they are making a few cents, even if the products are snake oil, ...........
    Now, a modern Li-ion cells to rebuild the stock battery pack.... That should be testable.
    Fortunately, my 13 year old Ni-Mh pack is hanging in there, so I just get to watch and learn....(y)
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
  3. Bill Norton
    2,157
    734
    MONW, Ks.
    Good Lorde.... A Fart Can.:whistle:
    I didn't read anything. I'm sure he's claiming many great things! That can't be proven.
    I hate the noises my prius makes now. I wouldn't want it louder....
  4. black_jmyntrn
    black_jmyntrn Senior Member
    1,728
    407
    2013 Prius Plug-in
    my thought is... why is everyone putting the same capacity batteries in their car when they replace them?
    So far, I've doubled the EV range on my 2013 Plug-in to replicate the 2017 Prime EV range... next, I'm going
    to hit my goal of 50kWh using the same space as my OEM cells.
    The new super capacitors look really promising, I just need to figure out the DC fast charging conversion without needing to add or remove electrical components.
    https://black.jmyntrn.com/2023/08/20/prius-plug-in-hv-battery-upgrade-from-4-4kwh-to-8-8kwh/
  5. GreenApp
    GreenApp Junior Member
    43
    I remember a thread where someone cut their cat out (or had it cut out/stolen), and gained a fair bit of MPG with a test-pipe - (not that I am recommending that) However I also recall there being a long-winded conversation about back-pressure being engineered into the system for either emissions reasons, efficiency, or both.
  6. zinzet
    zinzet Junior Member
    Federal Way
    Hi everyone. Does anybody know where I can buy a spare Nexcell? One cell in my pack went bad.
    ColoradoCrow likes this.
  7. black_jmyntrn
    1,728
    407
    2013 Prius Plug-in
    well.. considering its a DIY project if out of warranty and you dont upgrade to sodium... he tells me they arent for usage in a road vehicle and I am taking chances but so far swapping out the board from one blade to another has worked for me personally.
    https://sodiumhybrid.com/?ref=LwYWW
  8. ASRDogman
    ASRDogman Senior Member
    7,597
    3,916
    Have you tried contacting Jack?
    black_jmyntrn likes this.
  9. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Salt went bad already.
  10. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    463
    Leawood, KS
    I
    I have 12 available. PM me.
    black_jmyntrn and bisco like this.
  11. ColoradoCrow
    1,108
    463
    Leawood, KS
    I
    I have 12 of them. Send me a PM
