Battery Struggling at only 50k Miles??
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by fishandwhistle, Apr 21, 2025.
  1. Mendel Leisk
    41,315
    @fishandwhistle can you be more specific about the car’s hiatus; how often on average do you drive, how long are those drives, are there occasional, long downtimes (months), or no.
    we’ve got similar miles on our ‘10, but the car invariably is driven about once weekly, and goodly, long drives (50+ kms) as oft as naught.
    I suspect it’s long, multi-month downtimes that are the hardest on these batteries, there’s mention of this in Owner’s Manual.
  2. fishandwhistle
    fishandwhistle New Member
    Southeast US
    It's driven around once a week, with downtimes up to a month sometimes over the past few weeks. All drives are under 3 miles. It's a family members car, so once I get this fixed I'll definitely be taking it out on longer rides.
  3. fishandwhistle
    Southeast US
    Gotcha. So, based on that would you recommend doing a full battery replacement instead of a straight recharge?
  4. fishandwhistle
    Southeast US
    Hahah! We have differences of opinion on geography. Lived here all my life and only ever heard it referred to as south east. To us, there is no such thing as south central! That said, I hear you, I'll update my location info for clarity's sake, didn't realize it'd come so into play.
    Interesting point on a weak 12v battery. Will look into that today.
    ASRDogman likes this.
  5. ASRDogman
    ASRDogman Senior Member
    7,541
    3,893
    No biggie. People say they live in the south, Can't get anymore south than Florida! (y)
  6. ASRDogman
    7,541
    3,893
    Also, How old is the 12v battery? If it's 6+ years, it might be time for a new one.
    But, either way, you might want to consider a battery maintainer, since you don't drive much or far
  7. Mendel Leisk
    41,315
    Ours LIVES on one, necessity with low use.
  8. Leadfoot J. McCoalroller
    8,069
    7,552
    Pennsylvania
    2018 Prius c
    Charging and balancing can help, but everything I've read on the topic suggests that doing that in the first few years of the car's life gives you some more time on the back end. Once you're already 10 years deep, there's less of a recovery to be made.
    I think you should do more to shore up the overall diagnosis. It sounded like the 12v battery was really quite discharged, so get that settled first I think.
  9. DirkAshburn
    DirkAshburn Member
    143
    58
    Virginia
    I could just be one cell that went bad, who knows. You should be able to check with the Dr Prius app and an ODB2 reader.
  10. Hayslayer
    Hayslayer Active Member
    387
    216
    You can't possibly be this ignorant and still breathe.............
  11. Carall
    Carall Active Member
    306
    102
    Harrisonburg, VA
    The biggest mistake a prius owner can make is to replace a hybrid battery with only 50k miles for something questionable.
    These error codes may not mean anything after using the Hybrid Automotive charger and my fluorescent bulbs discharger.
    Here is an example of how a battery with 3 weak modules and trouble codes turned into a completely working one.
    2011 Prius with 156k miles.
    Delta SOC 39.5%
    3 weak modules with exclamation marks. The voltage was lower than on the other modules in the pack.
    The voltage of these 3 modules after discharging the battery pack in the car to 40%, after using the Hybrid Automotive equipment. The whole battery was discharged 3 times to 3.8, 78 and 13.9 volts. The order of these voltages is not important. This is how I managed to discharge that battery. The most important voltage here, for this battery is 3.8 volts. Discharging it to 80 volts, as stated in the instructions from Hybrid Automotive, would not have fixed this battery.
    I saw that prius today (a month later) and MPG was 46.1.
