Adding ambient light to lower trims
Discussion in 'Gen 5 Prius Accessories and Modifications' started by purplePriii, Jan 21, 2024.
  1. VirginiaLeePrius
    VirginiaLeePrius Junior Member
    34
    Space Coast, FL
    2024 Prius Prime
    SE
    I believe that was the whole point of this thread. I ordered with excitement items which I thought were according to what was indicated, but when I tested them, they were dim. Measuring voltage I saw only 1v. That's way too low to really illuminate the LEDs. I was considering installing a DC-DC voltage regulator that might take in 1v and possibly output 5v. That might light up the LED strip but I won't get the variability that is associated with the lights (dimming under various conditions). I think all I'd get would be a steady state brightness that might be too much. I was really hoping someone whom had already performed this modification might comment. I know it's an older thread .... sigh.
    Perfectpacman likes this.
  2. Perfectpacman
    Perfectpacman Junior Member
    81
    22
    United Kingdom
    2024 Prius
    ----UK----
    Has someone actually completed the modification before?
  3. purplePriii
    purplePriii Active Member
    275
    122
    Are your connector pins properly set? 1v is way too low. You should be around 5-6V. 1V would definitely make it near impossible to see even at night.
    My setup is brighter than the OG Toyota system. It does depend slightly on the LED strip quality you get (I had to replace my passenger strip as it died once and the new one isn't as bright but it was a different seller).
    You should be able to run an EL wire but I had the same idea but the noise was going to drive me crazy (high pitch whining).
    Any chance you can check your led strip with another power source? Or even measure the connector in the car directly to see what voltage it gives you?
  4. soft_r
    soft_r Active Member
    169
    132
    Beverly Hills
    2024 Prius
    What'd you plug into?
    Show pics.
    I have door handle LEDs that connect with the default LED power to the switches. If the vehicle button leds are dimmed too low it causes issues with the aftermarket door leds i have. Could be similar if you're tapping the button led power.
  5. AddMoreGas
    AddMoreGas Junior Member
    87
    51
    57
    Dallas
    2024 Prius Prime
    XSE
    24 prime xse here. We have had the car about a month and just noticed yesterday that the ambient lighting blinks at you to catch drivers attention. At a stoplight when car ahead leaves, while trying to change lanes when blind spot monitor is illuminated etc.
    Pretty neat feature.
  6. Perfectpacman
    81
    22
    United Kingdom
    2024 Prius
    ----UK----
    Yes. It's in the owner manual.
  7. VirginiaLeePrius
    34
    Space Coast, FL
    2024 Prius Prime
    SE
    I've attached a few pictures. I'm having problems getting a good measurement with the VOM because I don't have leads with gator clips (I'm going to fix that). BUT .... I tested both the leds and the EL wire by connecting them to a stripped back USB A connector, both light up perfectly when I tried. I verified the polarity of the connections both. The connector I bought online has a red and black wire at the edges which are opposite in polarity to the normal color convention (black -, red +). No matter which way I connected it up the leds did not light up. Took them inside to make sure I hadn't fried anything and they still worked. At one point I did actually measure 4.99 volts. Still they did not work. This is WAY to easy of a thing so I'm flummoxed. Had to give up and come inside because the wife was hungry. I'll try again later.
  8. VirginiaLeePrius
    34
    Space Coast, FL
    2024 Prius Prime
    SE
  9. VirginiaLeePrius
    34
    Space Coast, FL
    2024 Prius Prime
    SE
  10. purplePriii
    275
    122
    What are your other cables coming out of your connector? The ones I got are 2 pins only. Do you mind putting some more pics of the connector itself? Did you buy it like this or crimped the pins and put them in the connector yourself?
    If the LED itself works on USB and you're getting 5v from the connector in the car, it seems like a connection problem between the two or the connector itself not always having a good connection. Did you try both sides of the car with the same results or maybe by wiggling your connector around?
  11. VirginiaLeePrius
    34
    Space Coast, FL
    2024 Prius Prime
    SE
    The connectors with the multiple wires I found online I think after going through a Reddit post. Extra wires, I just ignore them. I understand about it working on USB and the fact that I'm seeing 5V. I just got new meter leads so I'll try again this coming Sunday. Thanks for your comments.
