Adding ambient light to lower trims
Discussion in 'Gen 5 Prius Accessories and Modifications' started by purplePriii, Jan 21, 2024.
  1. VirginiaLeePrius
    VirginiaLeePrius Junior Member
    39
    Space Coast, FL
    2024 Prius Prime
    SE
    I believe that was the whole point of this thread. I ordered with excitement items which I thought were according to what was indicated, but when I tested them, they were dim. Measuring voltage I saw only 1v. That's way too low to really illuminate the LEDs. I was considering installing a DC-DC voltage regulator that might take in 1v and possibly output 5v. That might light up the LED strip but I won't get the variability that is associated with the lights (dimming under various conditions). I think all I'd get would be a steady state brightness that might be too much. I was really hoping someone whom had already performed this modification might comment. I know it's an older thread .... sigh.
    Perfectpacman likes this.
  2. Perfectpacman
    Perfectpacman Junior Member
    84
    23
    United Kingdom
    2024 Prius
    ----UK----
    Has someone actually completed the modification before?
  3. purplePriii
    purplePriii Active Member
    275
    122
    Are your connector pins properly set? 1v is way too low. You should be around 5-6V. 1V would definitely make it near impossible to see even at night.
    My setup is brighter than the OG Toyota system. It does depend slightly on the LED strip quality you get (I had to replace my passenger strip as it died once and the new one isn't as bright but it was a different seller).
    You should be able to run an EL wire but I had the same idea but the noise was going to drive me crazy (high pitch whining).
    Any chance you can check your led strip with another power source? Or even measure the connector in the car directly to see what voltage it gives you?
  4. soft_r
    soft_r Active Member
    183
    151
    Beverly Hills
    2024 Prius
    What'd you plug into?
    Show pics.
    I have door handle LEDs that connect with the default LED power to the switches. If the vehicle button leds are dimmed too low it causes issues with the aftermarket door leds i have. Could be similar if you're tapping the button led power.
  5. AddMoreGas
    AddMoreGas Junior Member
    87
    52
    57
    Dallas
    2024 Prius Prime
    XSE
    24 prime xse here. We have had the car about a month and just noticed yesterday that the ambient lighting blinks at you to catch drivers attention. At a stoplight when car ahead leaves, while trying to change lanes when blind spot monitor is illuminated etc.
    Pretty neat feature.
  6. Perfectpacman
    84
    23
    United Kingdom
    2024 Prius
    ----UK----
    Yes. It's in the owner manual.
  7. VirginiaLeePrius
    39
    Space Coast, FL
    2024 Prius Prime
    SE
    I've attached a few pictures. I'm having problems getting a good measurement with the VOM because I don't have leads with gator clips (I'm going to fix that). BUT .... I tested both the leds and the EL wire by connecting them to a stripped back USB A connector, both light up perfectly when I tried. I verified the polarity of the connections both. The connector I bought online has a red and black wire at the edges which are opposite in polarity to the normal color convention (black -, red +). No matter which way I connected it up the leds did not light up. Took them inside to make sure I hadn't fried anything and they still worked. At one point I did actually measure 4.99 volts. Still they did not work. This is WAY to easy of a thing so I'm flummoxed. Had to give up and come inside because the wife was hungry. I'll try again later.
  8. VirginiaLeePrius
    39
    Space Coast, FL
    2024 Prius Prime
    SE
  9. VirginiaLeePrius
    39
    Space Coast, FL
    2024 Prius Prime
    SE
  10. purplePriii
    275
    122
    What are your other cables coming out of your connector? The ones I got are 2 pins only. Do you mind putting some more pics of the connector itself? Did you buy it like this or crimped the pins and put them in the connector yourself?
    If the LED itself works on USB and you're getting 5v from the connector in the car, it seems like a connection problem between the two or the connector itself not always having a good connection. Did you try both sides of the car with the same results or maybe by wiggling your connector around?
  11. VirginiaLeePrius
    39
    Space Coast, FL
    2024 Prius Prime
    SE
    The connectors with the multiple wires I found online I think after going through a Reddit post. Extra wires, I just ignore them. I understand about it working on USB and the fact that I'm seeing 5V. I just got new meter leads so I'll try again this coming Sunday. Thanks for your comments.
  12. Deathcommand
    Deathcommand New Member
    2023 Prius Prime
    SE
    I know it's a dead thread but the original post (from reddit) is mine so I think I'm allowed to.
    In response to the notification not working on the right, the passenger side does not pulse for notifications. Only the driver and middle lights do. If you want it to pulse, you will have to connect an LED strip to the middle.
    Now the more interesting part.
    I just finished the modification. I managed to source a dashboard from a really cool guy on facebook market place for 150 dollars who was parting out a very totalled XLE. He was really cool. I think meeting him was my favorite part of the conversion because in the meanwhile I managed to cut my finger, and hurt myself while finding out that toyota technicians are truly wizards of their craft because the driver side trim is SO HARD to put back together.
    Anyways. I got a normal Prime XLE trim Dash board including the notification light, which if you didn't know is blue instead of red and the dash is a kind of silver and patterned instead of burgundy. I think I might wrap the silver in something like white or something, and I'll be on the look out for red LEDs. If anyone with an XSE wants their LEDs to be blue, let me know and we can set up a trade. it isn't too difficult to swap them out.
    The passenger dashboard is pretty easy. Maybe 3/10. Driver dash is like 7 or 8 out of ten. There are so many tabs that needs to engage upon closing it up. it's pretty hard and if you miss one you have to start from the beginning. It took me like 40 minutes.
    The last one is a comparison between the two. One is the SE trim and the one with the white bar is the XLE trim. I'd imagine the XSE trim looks similar but has burgundy color instead of the silver. (The hole is where the AC Controls go)
    I'm happy with the result, but like I said, I might have to wrap it or find someone who wants blue instead of red LEDs so I can trade.
    Accidentally doxxed myself. I'll upload a picture tomorrow.
    #32 Deathcommand, Nov 3, 2025
    soft_r and otatrant like this.
  13. Deathcommand
    2023 Prius Prime
    SE
    soft_r likes this.
