2007 Prius won't light up
Discussion in 'Gen 2 Prius Technical Discussion' started by SBP Mike, Apr 24, 2025.
  1. SBP Mike
    SBP Mike Junior Member
    51
    Chehalis WA
    I think your suggestion on the SKS key button was for the other person. Toggling the SKS key button did not change anything on my "light up" issue. Thanks anyway for reminder to consider that button.
  2. pasadena_commut
    pasadena_commut Senior Member
    2,694
    804
    Southern California
    11.something under load is normal. There is a pretty substantial current draw, and any battery's voltage will decrease more the greater the current outflow. In our car if the start button is pressed once without a foot on the brake the voltmeter will show a number somewhere in the high eleven range, like 11.7 volts. And that isn't even really starting up the car fully. <10 under load is voltage collapse, in this or especially an ICE vehicle with a starter. Between 10 and 11 is a bit of a grey zone, the car might or might not start.
    SBP Mike likes this.
  3. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    Third planet from the Sun
    Could you take a video of what's going on in the car during startup?
    It is necessary to understand at what stage you have a problem.
    Starting a hybrid car is quite a complicated thing, it does not happen like in a regular car (insert the key, turn the key and the starter starts to spin the engine).
  4. SBP Mike
    51
    Chehalis WA
    Thanks for this reminder. My other daily driver prius had suddenly stopped having smart key functions. My wife and I thought it was just getting older, but the smart key functions returned when I toggled this button. I have to conclude that my wife and I are the ones that are getting older and losing some functions.
    Skiddmore likes this.
  5. SBP Mike
    51
    Chehalis WA
    Will do.
    thanks
  6. SBP Mike
    51
    Chehalis WA
  7. SBP Mike
    51
    Chehalis WA
    I have two prius vehicles right now. A blue 2005 and a silver 2007. Blue is my daily driver. The Silver prius is that one that won't boot up and show dash lights.
    I bought a new battery for the 2005. I tried it in the silver prius first and it gave same results as before. The car won't boot up and show any dash lights.
    I pulled that battery and tried it in the blue prius, the blue prius started right up. I took the relatively old battery out of my blue prius that was starting blue prius just fine, it did nothing for the silver prius.
    I have concluded that the problem is not with the 12v battery.
  8. SBP Mike
    51
    Chehalis WA
    I pulled the cover off the traction battery and checked the voltage and it showed about 7.70v on all 28 modules. That was after a charge.
    The car has been sitting for a few days waiting for me to get back to it, so it got a chance to discharge a bit. It's now showing about 7.62v across all the modules.
    Based on this, I conclude the issue is not with the big traction battery. It looks pretty decent.
  9. SBP Mike
    51
    Chehalis WA
    I have brake lights and I have emergency flashers. Nothing else lights up in any way. I was able to get it to run dash lights when I picked it up. It would not go into "Ready" mode, but it went into the mode where P and N are available. That was helpful in getting the car loaded up on a dolly for ride home.
  10. pasadena_commut
    2,694
    804
    Southern California
    From the video, the car sees the power button push, else the voltage wouldn't drop like that. The dash lit up once when the OP first took possession (first post). Was that both the combination meter (dashboard) and the MFD? Failure of the combination meter to light up is a very common problem on these cars, but it is separate from the MFD not working. There is a very long thread on it here:
    combination meter repair - DIY | PriusChat
    Combination meter failure doesn't normally keep the car from starting, but it often makes turning it off difficult. (Rather than a single push to turn off, one must hold down the start button for several seconds. Like a forced power off on a PC.)
    The OP reported having checked the AM2 fuse, but not the status of the others. It would make sense to check all of the fuses. That said, I'm wondering if rather than a bad fuse this isn't a bad relay. I don't have the electrical diagram for this car handy but in most vehicles there are one or more relays which need to click in to connect power from the battery to the various other electrical systems. If those relays fail, the car will have problems, usually big ones, very much like what is seen here.
    Is it possible to read codes, preferably with Techstream or an equivalent?
    After the car is started, is there 12V at the power outlet under the glove box? If not, perhaps start by working that problem. It should be a relatively simple circuit, and if that starts working perhaps some of the other problems will be resolved too.
  11. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    There is no hybrid part connection and the "ready" sign - the socket will have 12V battery voltage.
    There is a connection and the "ready" sign, then the socket will have about 14V.
  12. SBP Mike
    51
    Chehalis WA
    Thank you. I am going to read and re-read this response a few times and work through some of these questions. I think the first thing I will do is check all the fuses.
    As I recall, the one time I got dash lights, I only got dash lights, nothing on the MFD.
    I think your idea about relay issues feels right on.
    After fuse check, I will move on to looking at power at the power outlet under the glove box.
    Thank you
  13. pasadena_commut
    2,694
    804
    Southern California
    Car completely off - 0V.
  14. SBP Mike
    51
    Chehalis WA
    Ok, making some progress. I now have a light on the dash that indicates a door is open. I also get the little key in a red rectangle that indicates no key in place, or system is locked or whatever that one means. The key fob also unlocks the doors, but it does not lock them. I just get a long beep. I figure that maybe that has something to do with the system thinking there a door open.
    Started on this late today, it's pretty warm, so I am taking a little progress and calling that good for today. There were no blown fuses under the hood. I scraped a little oxidation off a few of them. Think I will shoot them all with electric contact cleaner.
    No voltage reading from the socket under the glove box.
    I am mulling the Open Door light. I will close up the hood tomorrow, but I don't think there is a sensor on that "door."
    Then, I think I have to lay down on the pavement and pull and check fuses under the dash.
    Thanks
    Mike
  15. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    When you try to start the car and press the start button, is your key fob in your pocket or in the key fob slot?
  16. SBP Mike
    51
    Chehalis WA
    slot, but have tried it both ways
  17. pasadena_commut
    2,694
    804
    Southern California
  18. Mike SBP
    Mike SBP New Member
    Chehalis WA
    This was the solution. Even a fully charged 12v battery would not power up the car until I put more charge into the traction battery. Thanks to PriiusCamper. Good advice as usual
    PriusCamper likes this.
  19. bisco
    52,070
    how did your handle get reversed?
  20. Brian1954
    Brian1954 Senior Member
    2,302
    915
    South Central PA, USA
    He created a new account yesterday. He probably could not log into his original account, maybe lost his password?
