1. ANDREW BERMAN
    ANDREW BERMAN Junior Member
    Killbuck, OH, United States
    My 08 base is driving me absolutely insane and I want to get rid of it..
    Haven’t had heat for while replaced the thermostat still nothing, found I had a plugged auxiliary pump cleaned that out and also changed another pump as I had a P1121 code. I drained the system bled all the air out and still no hot air lower and upper lines are hot, lines going to the auxiliary pump are hot, from the auxiliary pump to the car and return are cool , multi metered the pump and it’s showing voltage so I’m guessing the pump still works.
    I switched through the heat locations and all are moving fine just no heat.
    Scan tool shows car getting to 205 then fan kicks on and drops to 190’s but no heat
    Anyone with suggestions on what do check next so I can try to get my car back on the road?
  2. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    Third planet from the Sun
    You say that the pipes to the heater radiator in the car are both hot. Is the heater radiator hot to the touch?
    If there is a plug inside the radiator, then the hot coolant will not circulate through it and it is necessary to eliminate the cause of the plug, flush the heater radiator.
  3. dolj
    dolj Senior Member
    8,546
    4,341
    Wellington, New Zealand
    ... and when MAX2 says plug, he means blockage. This was my thought, too. Either that or the air blend door under the dash is not working. That should give a B14xx error code, I believe, if that was the problem.
    MAX2 likes this.
  4. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    There may be an airlock in the heater radiator, or debris from hoses or leak-eliminators may have accumulated. Channels with impaired circulation inside the heater may not allow coolant to pass through. But it may also be that the dampers are jammed. Then the heater heating is localized and does not reach the consumer.
  5. Tombukt2
    13,336
    2,401
    So you're saying the hoses that go from the top of the thermostat housing across the transmission right up alongside the inverter pump and up to the water pump that's in between the two brake parts that pushes water into the heater core and then the other line coming from the heater core goes back to the cooling system if those two hoses are hot the one going to the pump and the one going from the pump to the heater core then the heater core is hot inside of the car because you're not feeling the heat only means that a door or something isn't bobbing up and down to try to produce the heat in the car that you're trying to get on your feet or your face. You should also be able to make all of this happen with the radiator cap off of the car just sitting in the driveway the car should sit there and run with the ice engine running as long as there's a call for heat meaning the heat is on high and the fan is on whatever when the engine stops running that's when you feel the hoses that run up to that little pump that shoots the water over to the heater core at that time because the engine shut off the system believes that enough hot water has been made that should start satisfying the consumer if you will so if you know those hoses are hot then that means the heater core inside of the heater box is in fact hot and air is not getting across it to produce heat inside the car that's another problem that's not related to the red stuff in the radiator at all for that you'll be taking off the little square looking motors right next to your gas pedal foot when you're sitting in the car and then you'll be able to move the door that goes from outside cold air and moves the air so that it all goes across the heater for and comes out at any of the vents you selected .
  6. pasadena_commut
    pasadena_commut Senior Member
    2,787
    832
    Southern California
    Has anybody ever poured a stop leak or gasket sealer into the car? Those products are notorious for jamming up cooling systems. If it is just a "simple" blockage, like from a hose that is disintegrating, then it should be possible to flush it. There are kits with adapters for attaching a garden hose to one side of the heater core, and a drain to the other. Blast it out with water.
    If some piece of rubber or other similar macroscopic blockage comes out, the OP's next task will be figuring out where that came from, and it may come down to replacing all of the rubber hoses since inspecting their innards is not really practical.
  7. ANDREW BERMAN
    Radiator itself is hot, lower and upper radiator hose are hot.
    The red circled hoses are hot, the blue ones are cold when the others are hot. When I switch from face to feet I don’t hear any noises from the blended door moving.
    I have not personally used stop leak or gasket maker on anything and I’ve owned the vehicle for many yrs now, the second picture is what clogged the heat water pump blowing in the lines air moves freely though the system
  8. pasadena_commut
    2,787
    832
    Southern California
    Sounds like a blockage somewhere between the electric water pump (inside the blue circle) and the T intersection of hoses in front of the engine. It wouldn't matter where in that section was blocked, any position would stop coolant flow through the entire section, and heat wouldn't move either, except a little by diffusion from the ends. Perhaps try flushing water through that entire section. Clamp the coolant hose upstream of the water pump and the two other hoses at the T intersection, then detach the 3rd hose at the T intersection and the hose downstream at the water pump. Maybe best to flush it in the opposite direction first - in at the T hose and out at the water pump hose.
    Is that black thing in the second picture squishy? It looks like a ripped up chunk of coolant hose. If that is what it is changing all of the cooling hoses may be in your future.
  9. Tombukt2
    13,336
    2,401
    Just disconnect a few hoses and blow through gently with the diagram in the direction that flow should be happening you don't want to reverse everything and be blowing in the wrong direction of flow generally speaking I've never seen anything in any of these systems other than stop leak that was put in by a human to stop the flow of coolant in these systems usually it's human-induced Flow restriction by adding stuff to generally try and stop a leak that maybe they should just replace the part that's leaking or something along those lines. Like I said I have an 09 doing this right now but mine is more of a consumption problem than it is of a blend door or something not moving properly.
  10. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    The internal channels of the heater radiator are relatively thin. When such a piece of rubber gets into the heater radiator, it will clog the hole and the movement of liquid will stop. It is necessary to disconnect the tubes from the heater core at the top in the picture and try to flush them.
    P1121 - was this error checked or did they just replace the first part that came along?
    https://attachments.priuschat.com/attachment-files/2025/03/264910_TSBCodeP1121.pdf
    #10 MAX2, May 3, 2025
  11. ANDREW BERMAN
    I didn’t actually check the part to see if it was working properly I had assumed it was the problem until I did more looking online and found there could be a clog in the system.
    I didn’t do a flush of the heater core but when I blew in the hose air moved thru it freely so I figured there wasn’t a clog in that area. I checked the driver side blend door and it’s moving so I don’t think that’s the issue
  12. BiomedO1
    4,058
    2,136
    SacTown, Ca
    Well it seems pretty darn obvious to me!!! According to your attachments - the coolant hoses going to and from your heater core are COLD; why would you get cabin heat; if they're cold - magic???? Stop troubleshooting blend door issues and get hot coolant flowing through those hoses.
  13. ANDREW BERMAN
    Well that’s what I’m trying to figure out here why I’m not getting hot coolant through the firewall hoses.
    I’m trouble shooting what people have suggested
  14. Tombukt2
    13,336
    2,401
    If the cooling system is empty you should be able to blow like 5 PSI through most of the hoses with adapters or whatever and it should blow through and come out somewhere I doubt seriously there's a clog big enough to keep water flowing through 5/8 heater hose so that you have absolutely no heat highly unlikely it's possible it's just highly unlikely but I guess it's the car sat for a few years with half a full coolant system and the stuff got nice and crusty and what have you it it's possible just highly unlikely if air blows around through the system then water should flow around through the system enough to at least get something to come out of the vents complete zero nothing I mean that's a real stretch but if you don't have any water coming from that hose it goes from the thermostat housing the black plastic thing all the way up past the inverter pump up to the pump between the brake parts and then that goes from that pump over to the heater core you will never have any heat that hose should be hot where you want to move your hand after the car is not been running very long to boot no puns intended you may not have heat in the car but that hose should be getting smartly warm and then the hose that comes out of that pump and over to the heater core should be having warm water going to hit and the heater cores other hose should have a little bit cooler water coming out of it going back into the system until you have that you can never in any kind of way have any heat in the Prius that you're driving and I doubt it's a clog if anything it's an air pocket this is a very hard car to fill even if you have one of those fancy air filling devices you might have to do it twice to get it right I usually just do it the slow way and fill it up to the top of the neck and walk away from the car for a while and come back and it'll be dropped and I'll fill it back up and continue to do that about 12 times until it stands at the neck for at least 5 minutes without moving you can't make that happen you're never going to have heat
  15. pasadena_commut
    2,787
    832
    Southern California
    If it is air in the heater core follow these instructions:
  16. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    Blowing out a channel does not do as much as flushing a channel.
  17. ANDREW BERMAN
    right and I didn’t think of flushing the heater core prior to filling the system back up, however I did unhook the two heater hoses last night and I’ll be buying the parts to flush the heater core today
  18. pasadena_commut
    2,787
    832
    Southern California
    Give some thought to how coolant will be reintroduced after the core is flushed. The core is likely to be holding a lot of tap water after being flushed with a hose, and the volume of the core is fairly large, as a I recall, something like 2/9 of the total in the ICE coolant system. It would help to know where the inlet and outlet are attached to the core with respect to height - bottom, middle, or top.
  19. ANDREW BERMAN
    Flushed the heater core yesterday and got some chunks of black foam out then used an air hose and blew the water out, then filled the heater core with antifreeze and attached the hoses again added more coolant and switched from heat to cold ac then back to heat. I know have cold ac and hot heat
    Brian1954 and BiomedO1 like this.
  20. ChapmanF
    18,484
