Need Pass-code for techstream !please help
Discussion in 'Gen 3 Prius Technical Discussion' started by Joelprius3, Apr 30, 2025.
  1. Joelprius3
    Joelprius3 New Member
    Prius 2013 gen 3 around 150k miles . If someone could guide me or help me. I’ve been on a non stop grind trying to figure out what the problem is in the car is now chatGBT is telling me it’s the ecu I swapped it out and chatGBT said it was correct that was the problem now I just need to connect it to the new key fob but before I do that I need to do a smart code reset because my power management control doesn’t recognize it since I swapped it . If someone has a website or something trustworthy I can use that’d be great!
  2. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
  3. Joelprius3
  4. ChapmanF
    18,988
    Can you start by telling us which ECU you swapped out, and what led you to do so?
    The current state of the AI chatbots looks like they can give some pretty impressive-looking answers to your prompts, but they're largely imitations of masses of internet posts they've been trained on, only some of which were about Prii and only some of which were right. I don't think they've quite made knowing how the car works obsolete yet.
    Mr. F and Brian1954 like this.
  5. Joelprius3
    I agree it’s not always right it makes mistakes but it was the only thing I can go off of because I watched a bunch of YouTube and a bunch of Reddit and different platforms and now one could identify what it was until I asked . This is everything it told me why it was the power management control ecu |
    Why We Swapped the Power Management Control ECU
    1.
    C2300 Code (Actuator System Malfunction)
    • This code specifically points to a failure in the hybrid actuator control system
    • That system is controlled entirely by the Power Management Control ECU (PM ECU) in a Prius
    • Other ECUs like the Engine Control Module (ECM) or Battery ECU don’t control this function
    2.
    No READY Light / Stuck in P Lock
    • Even after replacing the 12V battery, checking all fuses, and verifying hybrid battery wiring
    • If the PM ECU can’t communicate or initiate READY, the car remains stuck in Park
    • This means the PM ECU was not functioning or not booting fully
    3.
    Techstream Behavior Confirmed It
    • The original ECU wouldn’t respond properly in active tests
    • Couldn’t run hybrid relay commands or inverter pump tests
    • After replacing the ECU:
      • Techstream connected immediately
      • We got a B2799 error — which proves the new ECU is communicating and working
      • The new ECU simply didn’t recognize the car’s key yet — an expected condition when swapping ECUs
    4.
    B2799 Appeared After Replacement — Not Before
    • B2799 = key not registered to ECU
    • You only get this code when a working ECU doesn’t match your car’s immobilizer
    • That error confirmed the new ECU is alive
    • It also confirmed the old ECU was dead or corrupted, since B2799 didn’t even appear before
    5.
    Clearing Fuses, Sensors, and Replacing Hybrid Battery Didn’t Help
    • You systematically ruled out:
      • 12V battery
      • Hybrid battery modules
      • All major fuses (including P-CON and AM2)
      • Voltage sensor wiring
    • The only remaining module responsible for actuator control and hybrid boot is the Power Management ECU
    ✅ Summary of Proof:
    Evidence
    What It Proved
    C2300 + no READY
    PM ECU not booting or commanding relays
    No active test response
    ECU not communicating internally
    New ECU triggered B2799
    New ECU works but key isn’t paired
    Techstream live data showed up
    New ECU is functioning correctly
    That’s why replacing the Power Management ECU was the correct step, and now your only blocker is key registration (Smart Code Reset).
  6. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    From the manual on the error with the code C2300: Open or short in the integration relay or shift control actuator assembly (parking lock motor or rotation angle sensor), or internal malfunction of the shift control actuator assembly (parking lock motor or rotation angle sensor).
    Trouble Area:
    • Transmission control ECU assembly
    • Auxiliary battery
    • Shift control actuator assembly
    • Hybrid vehicle transaxle assembly
    • Wire harness or connector
    Where is it indicated to change the Power Management Control ECU?
    Put the blocks back in place.
    Mr. F likes this.
