2003 upstream Air Fuel sensors Part #
Discussion in 'Generation 1 Prius Discussion' started by Dale Royer, Mar 30, 2025.
  1. Dale Royer
    Dale Royer New Member
    Maxton NC
    2003 Prius
    New hope I put this in the right place:
    I looked and got different part numbers the dealer gave me part # 89465-47050 which is discontinue.
    One post used part # 89467-47010 for a 2004 anyone have a part # that worked for the 2003?
    Thanks in advance, Dale
  2. MAX2
    MAX2 Senior Member
    1,436
    483
    101
    Third planet from the Sun
  3. Dale Royer
    Maxton NC
    2003 Prius
    That looks like it, you referred to it as rear. I need the Front or some call it upstream.
  4. MAX2
    MAX2 Senior Member
    1,436
    483
    101
  5. Dale Royer
    Maxton NC
    2003 Prius
    Thank you so verry much!
  6. Dale Royer
    Maxton NC
    2003 Prius
    89465-47060 is nowhere to be found, anyone know of a replacement?
  7. dolj
    dolj Senior Member
    8,217
    4,187
    Wellington, New Zealand
    The eBay link in post #2 seems to still link to an active auction. 2002 should be okay for your 2003 car, but a question on the auction will confirm that for sure.
    What diagnostic procedure led you to conclude you need to replace this sensor?
  8. Dale Royer
    Maxton NC
    2003 Prius
    I used Toyota Techstream don't remember the code bank 1 excessive flow. I went to double check and the 12V battery was low gave all kinds of codes. I charged the battery and disconnected the ground to erase the codes waiting for it to come back. I purchased one on Ebay after a week I asked about when it will ship, replied checking warehouses, replied not available sent a refunded.
  9. ronlewis
    ronlewis Active Member
    971
    194
    texas
    2001 Prius
    Check that your VAV on the cat isn't stuck open or closed. That'll mess with your air/fuel mix, although you should get that code. You might be losing vacuum in the tank from a rusted filler tube, which happens on these cars in you drive through snow often. Reach up inside your rear passenger-side wheel well to feel around the top of the filler tube, close to the quarterpanel. Snow wedges up there and rusts the tube.
  10. ChapmanF
    17,352
    How?
  11. ronlewis
    971
    194
    texas
    2001 Prius
    I guess just crawl under the car and try to move it by hand. But IDK.
  12. ChapmanF
    17,352
    I meant "how will the HCAC valve stuck open or closed mess with your air/fuel mix?".
