2006 Prius - P0171 & P0302 while hot?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by KitsuneVoss, May 2, 2025.
  1. KitsuneVoss
    KitsuneVoss Member
    371
    55
    Virginia
    I have a 2006 Prius where I just replaced the fuel injectors last Sunday. Was really rough at first when I first tried to drive the car after I replaced the injectors, then seemed okay.
    I had been getting the code P0420 prior to this. I have a new catalytic converter to replace the new one but not had a chance to get it installed.
    I drove today to a medical appointment and I decided to drive to an old shop I knew to see if he could put the new cat in. Drive to the medical appointment was fine and my MPG shown actually increased a hair. Was there a couple of hours. Drove to the shop, which was a long distance (30+ miles) and talked to the guy for maybe ten minutes. He was way to busy to try to do the car although he is cheaper than anyone else. Do it for $90 to $150 but is cash only. He is a good at exhaust systems however. When I drove home, the car shuttered and got flashing engine light. Something similar happened yesterday but not exactly the same but I was only a short distance from home. It was also after I stopped. I stopped at the public library to get my A+ certificate printed out and was there for maybe 10 to 15 minutes as well.
    It seems as if this is something that happens when the car has been running for a while, stops for a comparatively only a few minutes, and then start up and go. Seems to also be in warm weather. Been around 80 recently.
    I understand that P0171 is often the MAF sensor, which I can clean. That is what one discussion suggested at least. Plugs are new, wires are new, and was not getting either of these codes before. I on occasion got I believe P0301 but very infrequently (Cylinder 1.)
    I am half guessing here and could be all wrong so please no attacks for bad guessing.
    Could the catalytic converter be clogged where when it gets hot, it creates issues?
    Could it be just cleaning the MAF sensor?
    Something wrong with when I put the fuel injectors in? Other than being fiddly, I don't see that but shrug.
    Something else I am not thinking of at all?
  2. ChapmanF
    18,567
    P0171, being a lean-mixture code, can also often turn out to involve leaks in the intake system that allow extra air to enter someplace downstream of the MAF sensor (so-called unmetered air) so that the MAF reading doesn't account for it.
    Brian1954 likes this.
  3. KitsuneVoss
    KitsuneVoss Member
    371
    55
    Virginia
    I did the three things I could do easily
    Removed the air box because I could not get the lower screw out of the MAF sensor. Going to have to use a special tool to remove it. Want to get replacement screws first.
    Used CRC MAF cleaner on the inside of the sensor with the box off.
    Used throttle body cleaner to clean the throttle body.
    Put new hose clamps on the upper an lower areas on the air box so that they will be a tight seal. Was very gentle with the lower one and maybe not as tight as it could but want to be cautious.
    Where else should I be concerned with unmetered air other than the seal of the air box?
  4. KitsuneVoss
    KitsuneVoss Member
    371
    55
    Virginia
    Updates:
    Question, does a Prius always freak out as far as codes when you spray down the throttle body with throttle body cleaner?
    Yesterday, when I started the car, I got the triangle of death but ran after I restarted the car and smoothed out.
    Unfortunately yesterday, when I drove to meet a friend to pick up some eggs, I was still getting the stuttering and flashing engine light when I drove home.
    This morning I took the air box from my wrecked 2009 and put it on the 2006. I also removed the wire to cylinder 2 fuel injector, blew out both the wires, and the fuel injector connector. Drove to get the new catalytic converter put on without stopping. On my way home, I did stop at 7-11 to stop for a few minutes to see if the problem would return if I stopped for a few minutes but did not seem to get the same problem. I am not saying it is solved yet but at least a good sign.
  5. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    Third planet from the Sun
    There are two pipes leading to the throttle valve that can cause additional air leaks. One comes from the PCV valve from the engine. The second one comes from the EVAP system. Check the tightness of the seals on these hoses.
  6. KitsuneVoss
    KitsuneVoss Member
    371
    55
    Virginia
    Are those the wrapped pipes that are right next to where MAF sensor is?
  7. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    You are confusing the mass air flow sensor and the throttle valve.
    Only the electrical connector is connected to the MAF sensor.
  8. KitsuneVoss
    KitsuneVoss Member
    371
    55
    Virginia
    In this picture, the MAF Sensor is circled in green while the pipe I am thinking about is circled in green. I think there is a second one next to it.
    It is 1 am, so not going out there now ;)
  9. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    You can leave this for breakfast.:)
    The mass air flow sensor is attached to the air filter housing. If you remove the clamps and fasteners of the air filter and fold it aside, you will see the throttle valve and all the hoses that connect to the valve housing. The PCV hose is described separately in the manual for checking the P0171 code.
  10. mr_guy_mann
    mr_guy_mann Senior Member
    4,094
    1,998
    NJ-USA
    Both screws on the MAF sensor are the same. Often the "X" in the lower one gets rusty and a screwdriver won't fit. I have to clear it out with a thin tool (such as tip of a razor knife) before I can remove it.
  11. KitsuneVoss
    KitsuneVoss Member
    371
    55
    Virginia
    One thing that might be nice is to show on a photo of the engine the exact pipes I am suppose to be looking for. This way I can find the pipes in questions and know which ones. This website at least allows for pictures and Windows paint allows for circling things.
    I ordered six screws from my local Toyota so that I can replace the screws completely.
  12. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    See manual. p.10
  13. KitsuneVoss
    KitsuneVoss Member
    371
    55
    Virginia
    I have not checked the hoses and have driven 170 or so miles since I got my muffler replaced and likely about 240 since putting the 2009 Prius air box on her. No codes so far at least. Don't know if it will stay that way but at least looks good right now.
    I will likely get a new MAF sensor just to be safe in the next few weeks. Likely get one from O'Reilly Auto Parts because they have limited lifetime warranty there.
    #13 KitsuneVoss, May 8, 2025
