CAN Bus Analog - Digital?
Discussion in 'Gen 2 Prius Technical Discussion' started by tkc100, May 5, 2025.
  1. tkc100
    tkc100 Member
    89
    25
    Arizona
    I want to replace my original head unit with an upgraded Android unit. The question that has arisen in the purchasing process is the CAN Bus in a Gen. 2 Prius analog or digital? I was unaware that there were two different means of communicating over the CAN Bus. If you could assist me with an answer to this question I would appreciate it very much.
  2. ChapmanF
    18,430
    I'm still unaware of that. :)
    Though it's a truism that every digital transmission link is all analog wizardry if you look closely enough.
  3. pasadena_commut
    pasadena_commut Senior Member
    2,759
    825
    Southern California
    There are devices around for capturing analog data and converting it into CAN bus frames. Otherwise, it is a digital system, logically. That said, it works by comparing the voltage on two wires, both of which go up and down. As opposed to a single wire which goes up and down and is compared to a fixed ground. See the article on Wikipedia:
    CAN bus - Wikipedia
    and this illustration is particularly helpful, with Can H and Can L being the two data wires which are compared:
  4. tkc100
    tkc100 Member
    89
    25
    Arizona
    Thanks for the rapid response!
    The details for the Android head unit I am considering has this statement.
    "Steering Wheel Controls: Control your double din android car stereo while keeping your hands on the steering wheel. * The unit supports analog SWC signal. If your car is controlled by digital signal, then a SWC adapter cable(not included) is needed to transfer the digital signal to analog signal."
    How should I respond?
  5. ChapmanF
    18,430
    That's probably not talking about a CAN bus at all. A gen 2 uses multiple network technologies: AVC-LAN, BEAN, and CAN, as you see in this manual excerpt.
    And then there are things that aren't network connections at all. The steering wheel buttons are nothing but an arrangement of pushbuttons and resistors that pull two analog lines down toward ground by different amounts:
    Nothing there but wires straight from the buttons to the radio/player.
    I would call those analog steering wheel controls. Nothing to do with CAN or any other network though.
    In gen 3 there were two ways it could work. Some gen 3s have what Toyota calls a "touch tracer" display, where pictures of the steering wheel buttons show up in the instrument cluster to show what you're about to push, so you can be sure without looking down. They do it using the same number of wires from the steering wheel (even though it needs all the original signals plus the "where is my finger" signal). They did that by building a little microcontroller into the steering wheel, and redesignating two of the "button" wires to be power and ground for the microcontroller, and redesignated another to carry a digital signal saying what button is being touched or pushed. And they're still just private wires between the wheel and radio/player, not any kind of network.
    And in the models without "touch tracer", just the old familiar analog connections are used.
    But I don't think any of that microcontroller wheel-button magic was used in any gen 2 (in the US anyway).
    Brian1954 likes this.
  6. Tombukt2
    13,258
    2,393
    Need the cable ..
  7. ChapmanF
    18,430
    Given that the car's steering wheel controls are analog, that would surprise me.
    Unless the Android gadget vendor has mixed up the terminology, or something.
  8. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    Third planet from the Sun
    Read in relation to Gen2 up to this point.
    Further not for Gen2.
    Addition. Modern Android radios, in addition to supporting the main purpose of the installed buttons, allow you to assign a number of other functions when holding the existing buttons for a certain time. For example, you can program the "volume down" button so that when pressed for a long time (3-4 seconds), the sound is completely turned off.
  9. tkc100
    tkc100 Member
    89
    25
    Arizona
    Thanks to one and all.
    I am learning with your assistance :)
    I think that to hedge my bet I will purchase from a vendor with a good and proven return policy.
