NEW!!! Service Bulletin for Engine Knocking at Startup T-SB 0012-10
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by seilerts, Jan 12, 2012.
  1. wukong sun
    wukong sun Junior Member
    66
    I found that there was oil accumulation in the ERG pipe inside the intake manifold at the first cylinder position. I am still thinking about whether to open a hole and connect an oil collection tank.
    Who has a photo? I'll take a look
  2. Purrius
    Purrius Member
    164
    48
    Northeastern US
    What kind of block heater is it?
  3. Tombukt2
    13,289
    2,398
    That's wonderful that somebody's even bothering with tsbs on the car that's 12 years old or whatever. Most car folk would rather forget this stuff than Re live it. .
  4. Purrius
    Purrius Member
    164
    48
    Northeastern US
    I won't lie, when I first found this thread I thought the bulletin was new and got excited. ...Then I realized it was hecka old, and my car definitely doesn't qualify anymore. :(
  5. Mendel Leisk
    41,824
    The Toyota one. It’s pretty much THE choice as far as I know, since it’s a very specific application. Unlike traditional, coolant-immersed block heaters, it’s a smallish cylinder that fits into a tubular pocket in the block, employs heat-transfer grease. Really difficult access if you’re retrofitting, just doable.
    I actually just had it replaced by dealership: there was a recall due to fire hazard with the old one. New one appears to heat up less, judging from feel of adjacent coolant hoses after a couple of hours plugged in. Wiring seems a little more robust too.
    the part no, for that latest one;
    04007-08J05
  6. Purrius
    Purrius Member
    164
    48
    Northeastern US
    Oooh! I thought it was an aftermarket thing like what we use on our diesel equipment. :oops:
  7. MeatyPrius
    MeatyPrius Junior Member
    Norwalk
    What’s a DTC?
  8. Brian1954
    Brian1954 Senior Member
    2,371
    954
    South Central PA, USA
    Diagnostic Trouble Code
  9. ASRDogman
    ASRDogman Senior Member
    7,758
    3,967
  10. rjparker
    10,411
    6,521
    Now we get dups from different users.
  11. GlitterPsycho
    GlitterPsycho Junior Member
    Temple, GA
    2013 Prius v wagon
    Okay so i legit just had my intake manifold cleaned like a week ago and he replaced the seal. It was throwing this code with the check engine light. I’ve had knocking several times in the past with no one being able to replicate it. Do you think Toyota would fix mine then? Is that what I’m understanding?
  12. Mendel Leisk
    41,824
    see this
  13. ASRDogman
    7,758
    3,967
    Just because you get the "knock", it doesn't always mean it is the head gasket.
    Condensation can appear in the intake manifold and/or cylinders when it cold outside and the engine
    is hot, shut off, and cools down.
    Or it's been hot, and rains, and cools down quickly.
    If you are not loosing coolant, and it only happens under those similar conditions, it just might be condensation.
