1. Prius2006GuitarGuy
    Prius2006GuitarGuy Junior Member
    Sweden
    A bit confused here, I know the pinch welds to jack up the car (I'm doing the front two tires) but where do I put the jack stands?
    If possible please reply with a graphic or image, thanks in advance!
  2. Mendel Leisk
    41,640
    This is gen 3, but I believe gen 2 is VERY similar. The front points I actually borrowed from priuschat member Hobbit (IIRC). This is what I use all the time for jackstand placement:
    The front points are at the leading edge of longitudinal "rails", just beyond the zone covered by plastic (on gen 3). The rear points I turn the cradles 90 degree, they're on these reinforced, heavy-gauge "humps", that have the oblong slots (used for locking pins when shipping?).
    Twice yearly for the last 15 years ownership I've had the whole car up on these points, for swap between all-season and snow tires. Also at least 30 times lifting the front only, for oil changes and the like.
    I put a floor jack at either the front or rear central jacking point, and whichever end I'm raising, I place heavy, rubber wheel chocks fore and aft of each wheel at the other end. Typically raise the front first, and release rear parking brake (after chocking wheels), so car can "hinge" at rear axle.
    #2 Mendel Leisk, May 7, 2025
  3. PriusCamper
    PriusCamper Senior Member
    12,844
    5,204
    Pacific Northwest, USA
    Depends on how much clearance you need under the car... If not much clearance is needed I've found putting jack stands where the front wheels control arms bolt to the frame to be one of the easier spots that's higher up. And if I need to get the car way high up in the air with multiple stages of jacking it up then I usually use jack stands on the outer part of the control arms close to the wheels.
  4. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,476
    2,444
    Taylors, SC
    If you are changing tires or doing brakes and never be going under the car to work o n anything, I'd buy two of those $35 Hyper Tough 2 ton hydraulic floor Jack's from Walmart and get two pinch weld adapters to do the job.
    If you are working under the car, I'd get a pair of ramps.
  5. Prius2006GuitarGuy
    Sweden
    Thanks PC!
    Thanks GR.
    To be honest, I'm torn between buying a floor jack or ramps.
    Right now my needs are:
    Replace O2 sensor, then a little later doing an oil change and a full car service. What would you recommend?
  6. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    Third planet from the Sun
  7. Prius2006GuitarGuy
    Sweden
    Thanks! Will look those up!
  8. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    464
    Leawood, KS
    I
    My pinch welds have been messed up from rocks. I went to a play it again sports and bought 2 hockey pucks for $1. Cut slits in them with a hack saw and use them on top of my floor jack and jack stands. Working well after 9 years
    MAX2 likes this.
  9. priumium
    priumium Member
    314
    77
    Sweden
    2013 Prius Plug-in
  10. Prius2006GuitarGuy
    Sweden
    That looks really good!
    It is a pity it's out of stock :(
    Have you bought it and used it? If yes, what's your experience so far?
    It also says "impact wrench", what's that about?
    #10 Prius2006GuitarGuy, May 15, 2025
  11. pasadena_commut
    pasadena_commut Senior Member
    2,697
    806
    Southern California
    I don't get a warm and fuzzy feeling looking at that thing. Actually more of a sense of dread. The center of the lifting pillar appears to be about 1 inch from one of the edges, which means it will be very unstable when force is applied in that direction at the top of that pillar. Is there a way to solidly bolt this thing to a large square steel plate, to make it more tip resistant?
