Can anyone identify this.
Discussion in 'Gen 3 Prius Technical Discussion' started by Derp, May 8, 2025.
Tags:
  1. Derp
    Derp New Member
    Ca
    In the middle of a head gasket replacement and dropped a rocker behind the exhaust. Magnet tool came back with more than the rocker. Any idea where this came from?
  2. JC91006
    JC91006 Senior Member
    16,802
    8,591
    I found one of those in my exhaust, rattling around. Maybe that's something from a sensor
  3. Tombukt2
    13,218
    2,390
    Looks like a locating tube sometimes they're tapped into heads valve covers to locate the two pieces easily together some form of a spacer a sensor doesn't seem like it would have that at all sensors a lot of times on the end that screws in kind of looks like a spark plug or similar and has a flatter gasket sealing type of thanks similar to a spark plug but not exactly then others that are going in water sensing have o-rings
  4. ASRDogman
    ASRDogman Senior Member
    7,722
    3,960
    That's a guide pin to align the head on the block.
    Looking from the front of the car, there's one on the front right, and one of the left rear.
  5. Derp
    Derp New Member
    Ca
    That was it, thanks!
    Brian1954 and ASRDogman like this.
  6. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    Asrdogman comes thru again!
