P Lock Malfunction C2300 C2304 C2305 C2306
Discussion in 'Gen 3 Prius Main Forum' started by gus1203, May 9, 2025.
  1. gus1203
    gus1203 Junior Member
    34
    Cicero, IL
    Hello,
    I have a 2011 Prius with P Lock Malfunction
    I replaced the head gasket and as I’m ready to start up the car now I get the codes mentioned above. Only other thing I did is I kind of used it as a parts car before. I borrowed the Integrated Relay, Integration relay and Hybrid Battery. I put everything back from a running car and now I get the P lock Malfunction.
    Any suggestions where to start the troubleshooting procedure.
    Thank you
  2. Brian1954
    Brian1954 Senior Member
    2,408
    964
    South Central PA, USA
    Use a meter and measure the voltage of the 12v battery.
  3. gus1203
    34
    Cicero, IL
    12v battery is good and charged.
    Already tried another battery also. I believe the problem might be a wiring issue.
    Brian1954 likes this.
  4. Tombukt2
    13,430
    2,418
    Sounds like you may have some wiring issues or some squished wires or something so you have to go over that very finely and make certain that's what happens when you swipe parts off of a car and then try to come back and put it back into service again it can get really tricky hopefully you were very careful when you remove things and so on so you just have to go back over it there's no special science to it to be honest you just have to go over your work look at your work carefully I mean the car was running when you parked it I'm assuming or something similar so it should be doing the same when you put it back in service if you put the parts back in like they're supposed to be I would hope.
  5. gus1203
    34
    Cicero, IL
    I'm going to trace everything back. It is very odd to see this problem. I've done at least 5 engine rebuilds and about 50 heads and about 10 gen4 to gen3 engine swaps.
  6. Tombukt2
    13,430
    2,418
    Yeah then I guess you should be very familiar with the wiring and also maybe there's just something squashed that slipped your eye or something I mean I had a bunch of problems on startup of a gen 3 with a JDM swap but actually now that I think about it it was actually pretty normal the JDM throttle body didn't work the battery in the car was functional but it was more or less on his last leg the traction battery so on and so forth the air conditioning would run and drain the battery just sitting in the parking lot disconnecting some of this stuff getting everything running and then reattaching it a week later all the problems are gone in the car was running fine till the engine started doing the same thing again as the twozies do oh well
    gus1203 likes this.
  7. bisco
    52,393
    sometimes it is corrosion at the ecu connection
    gus1203 likes this.
  8. gus1203
    34
    Cicero, IL
    Looking at the shift control actuator it is missing 12v coming from the integration relay.
    I need to trace the wire and see if there is a short somewhere.
    anyone know where A50 A51 junction connector is located?
  9. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    Third planet from the Sun
    The codes are visible, but that's not all. Where are the freeze frames of the frozen errors?
    Post information on the system state at the time the error codes appeared.
    gus1203 likes this.
  10. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    To check the circuit in the error code C2300, this diagram is used. The A50/A51 connector is not here.
    To check the circuit in the error code C2304, this diagram is used. The A50/A51 connector is not here.
    gus1203 likes this.
  11. gus1203
    34
    Cicero, IL
    yes thank you.
    from my findings so far I have an open wire at BMA 2 - 8 at PCNT integration relay. I will trace wire later today and post update.
    and you are correct A50/51 connector is not is this circuit.
    Thank you
    #11 gus1203, May 12, 2025
  12. gus1203
    34
    Cicero, IL
    Hello all.
    after going through the troubleshooting procedure and checking everything was good. I finally figured out the issue. When I swapped the integration relay to another car I never put back the original integration relay back on this car. The other car worked fine but this one the integration relay is a different part number and would not work. After checking part numbers and obtaining the right part number for this 2010 Prius car started and P Lock malfunction is fixed.
    Just thought I’d share this information with you guys.
    Part number:
    82641-47040 for 2010 Prius
    82641-47090 for 2013 Prius
    Not interchangeable….
    47040 worked with a 2013 Prius,
    But 47090 didn’t work at all with a 2010 Prius.
    thank you…
    ASRDogman, bisco and Brian1954 like this.
  13. bisco
    52,393
    congrats!
  14. Nsmscnfnedsnsmdsddndssne
    Remote
    I think you might have the parts numbers transposed for this....
    My 2010 had the 82641-7090 stock and a junkyard one I pulled was a 82641-47040 from a 2011.
