Multiple warning lights and no shift to D on my Gen 3 after battery switch
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ELODublin, May 11, 2025.
  1. ELODublin
    ELODublin Junior Member
    Gonna take awhile to get to my question. Please be patient. Figured it best to describe what's been happening in case its relevant.
    The car has 245,000 miles on it. The engine was replaced 3 years and about 15,000 miles ago by my shop, after head gasket failure of the original. I don't know the age of the new engine. It was not a rebuild. Car has been operating okay since. It did use a quart of oil every 1,000 miles on freeway travel, but my freeway travel dropped to almost zero about 2 years ago, and the car stopped burning oil. For about two years now, I've done mostly local travel (still getting 45 mpg) though I did put 400 interstate miles on it a few days ago. Car behaved well this last long trip, but again burned oil.
    Check engine light turned on a day or two after the 400 mile trip. My shop, which does good work but may be straining a bit with a hybrid system, texted:
    "cylinder 2 is a persistent misfire, but did not follow a coil or a plug swap. Tried pressurizing the system and scoping the cylinders, and it looked alright. Need more diag time to pull the EGR cooler, since there is a code for insufficient EGR flow, which may be the source problem."
    The shop estimated $600 plus part to hang a new EGR. Given the EGR code, the known problems with EGR, and the oil burn history, I told the shop I would just bring the car back to my garage and DIY the EGR, hoping that would fix the check engine problem. I'm not close to a mechanic, but I can usually put things together after taking them apart, and there are good resources on this forum to help me take off, clean, and reinstall.
    However, here's the problem: when I went to bring the car back from the shop lot, it would not go into Drive. It did go from Park to Neutral. Plus, multiple lights on the right side dash lit up - charging system, brake, check engine, open door, ABS, and power steering warning lights on the right side, and traction control on the left.
    The 12v was last replaced 7 years ago. It was indeed failing - it would unlock the doors but didn't have enough juice to unlock the hatch. So, thinking the failing battery was likely the reason for the christmas tree dash, I swapped in a year old battery from my son's Gen 3 Prius. Nothing changed. Car would leave P for N but not go to D. Same warning lights. I turned it off and on a few times and kept trying. No luck.
    Disappointed, I put the battery back into my son's Prius- and got the same warning lights and refusal to go to D. However, when I turned it off and back on again, everything worked the way it should on his car.
    Any guesses as to going on with mine? Appeared to be a 12v problem, but the new battery didn't fix it. Is there some special step or sequence I missed when replacing the battery? Some magic digital code I can reset? Is the EGR failure code somehow related? Given the mileage, I don't want to put a lot into the car, but now is not the time to be buying another. Fortunately I do have another vehicle I can use until the Prius gets fixed or takes its last trip. But the AC still works! I can't just give up.
    Any thoughts or suggestions? Thanks
    Ed
  2. rjparker
    11,117
    6,975
    Your profile say a 2012 Prius c but you are asking in a gen3 forum without defining the car further. What year and model?
    There is an egr update for some gen3 years.
  3. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Bam!!! Sub forums are just a suggestion
  4. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    A 12V battery is checked with special devices to ensure it is charged and ready for operation. A discharged or faulty battery can cause many incomprehensible problems in various vehicle systems. The first thing you need to make sure is that the battery really has 12.4-12.6V. This voltage should also be on the fuse box under the hood.
  5. rjparker
    11,117
    6,975
    While no guarantee your battery is at fault, having a battery tester available can help.
    This is the one I have, it has a 40% coupon on Amazon making it $16 which is a deal. I find it to work well.
    The following unit is the number 1 seller and was the winner on Project Farm's testing video yesterday. It is $37. The previous unit tested just as well in the important areas.
    MAX2 likes this.
  6. ELODublin
    I had no idea my profile was incorrect. Did not realize I had one. My car is a 2011 Prius Model Two. Sorry about that.
  7. ELODublin
    I just ordered m own $17 battery tester. Thanks for the suggestion!
  8. ELODublin
    My shop put their jump pack on it, and the car worked. I don't know why swapping the other Prius battery did not work. Oh well. Turns out a new battery fixed the problem. Now onto the EGR.
    Thanks again for the assistance.
    Brian1954 likes this.
