Hybrid Battery module failures
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Shaun OBoyle, May 12, 2025.
  1. Shaun OBoyle
    Shaun OBoyle Junior Member
    MA
    I'm on my 3rd round of hybrid battery module failures in a month on my 2007 195K Prius. First time I relied on voltage and the computer to tell me which module was failing and replaced 1 module. After another red triangle I used a Viking battery tester on all the modules and replaced 3 modules (all I had), although the health on 7 other modules did not look great. The battery heath on these 7 was in the 80s%, showing higher resistence, although the voltage looked OK.
    I'm getting sick of playing whack-a-mole, debating if I should now replace these 7 modules for just over $200, or drop for a reconditioned battery for about $1300 from someone like Green Bean Battery.
    Any experience with Green Bean, or other recondtioned complete HV batteries?
    Am I going to do any better with a complete recondition battery vs replacing the modules myself?
  2. PriusCamper
    PriusCamper Senior Member
    12,844
    5,204
    Pacific Northwest, USA
    Well... A charge and balance of pack after replacing modules can make a big difference... But each rebuild of modules replaced DIY style lasts a shorter period of time and it seems like time for you to move on.
    The advantage with GreenBean and similar companies is they handle the install/swap and warranty stuff can sometime be to your advantage. Another option is Professor Joe sells rebuilt packs from Gen 4 Prius (2016-2022) and those are as close to brand new as you can get for OEM because brand new OEM prices have nearlly doubled: Prius | 2nd Life Battery
    Also check the link in my signature about Sodium-Ion, which I think is your best option.
  3. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    Third planet from the Sun
    If you plan to continue driving this car, think carefully about the amounts and reasonable investments in repairs.
    There may be a small investment associated with the purchase of one or two pairs of modules for a year. Then the problems with the battery will return. The new and old modules cannot work the same. Put an old nag and a young frisky horse in the same harness, make them run fast and soon one of them will die.
    Evaluate more expensive methods yourself.
    Food for thought.
    The original high-voltage Toyota battery has a warranty for 8-10 years, for a mileage of up to 150,000 miles. And it works for the entire warranty period and much more.
    The cost from the manufacturer Toyota of a new battery kit consisting of 28 modules for replacement, which will allow you to drive at least another 150,000 miles, can cost from $ 3,000 to $ 4,000.
    You can save some of this money or even half of the cost of a new original battery if you buy reconditioned batteries from a private company or non-standard "ersatz-replacement" batteries with different battery chemistry, but no one will give you a guarantee that in a year or two, after ten to twenty thousand miles, you will not have another problem with repairing such a battery. An extended warranty will cost even more than original batteries. Additional expenses may be required for replacement, delivery, testing and adjustment of non-OEM batteries. You can also be denied warranty under any far-fetched pretext. There are several topics on the Prius chat website where hybrid owners deceived in their hopes later faced a refusal to replace batteries and returned to the decision to buy and install a new original set.
    The choice is always yours.
    My Gen2 has original batteries installed from the factory, in a short period they will be 20 years old. And when they fail, I will replace them with original Toyota batteries of recent years of production.
    mudder likes this.
  4. Shaun OBoyle
    MA
    Replacement seems the way to go at this point. Thanks for the feedback.
  5. PriusCamper
    12,844
    5,204
    The other option is to get a couple packs on the cheap that need work because you already know to rebuild them and then you'll have a backup pack on your shelf ready to swap out with a rebuilt pack in your car at the first sign of trouble. Of course that's time consuming unless you enjoy that type of work...
  6. Carall
    Carall Active Member
    314
    104
    Harrisonburg, VA
    2007 battery with almost 200k miles is most likely dead, dried out. The modules will fail one by one until eventually all 28 modules are replaced.
    I would buy a used Corolla battery from a junk yard and restore the capacity using the Hybrid automotive method before using the modules.
    #6 Carall, May 13, 2025
