P3190 code "Poor Engine Power" after replacing timming chain
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jefferson Santos, May 12, 2025.
  1. Jefferson Santos
    Jefferson Santos New Member
    Hamilton
    Hi everyone,
    I replaced the timing chain on my 2008 Prius this weekend because I was getting the P0016 Crankshaft Position/Camshaft Position error. After reading the manual, I decided to replace it. With 300,000 km on the odometer, it seemed like the right time to do it before encountering any other issues.
    Everything went smoothly, but I couldn't start the car again after replacing the timing chain, and now I'm getting the P3190 code for "Poor Engine Power."
    I believe I made a mistake while aligning the cam sprocket/pulley with the crankshaft. If I did indeed mess up the synchronization between them, what would be the best way to adjust it?
    After replacing the timing chain, everything was aligned with the marks, and I was able to move the crank without any friction between the pistons and the valves.
    What I did so far?
    • The mass air flow sensor is working well (as it was before the change).
    • The fuel injection system is working well (as it was before the change).
    • The crankshaft sensor is working well (as it was before the change).
    • The hybrid battery was discharged after multiple unsuccessful attempts to start the car, but I was able to recharge it with my external power supply.
    Thanks for your help, guys.
  2. Tombukt2
    11,994
    2,119
    Seems to me if your timing is off you're having this code I would think the freeze frame data will show some alarming timing numbers whatever that would be I don't really know but I'm sure it's something that's searchable as far as the numbers to be looking for they even be lit up in Orange who knows if you have that Toyota software however you get it then any good scanner bi directional type of thing should be able to talk with the Prius and get you everything you need to get including some freeze frame data which if there was a serious timing problem I imagine that might show up.
    Jefferson Santos likes this.
  3. mr_guy_mann
    mr_guy_mann Senior Member
    3,939
    1,900
    NJ-USA
    Go back "to the scene of the crime". Remove the valve cover, then use a wrench to turn the engine clockwise until the notch on the crankshaft balancer lines up with the "0" timing marker on the front cover. This is TDC (top dead center) for cylinders 1 & 4.
    Both marks on the cam sprockets should be visible, (that means you are at TDC for cylinder 1 on the compression stroke). If not, rotate the crankshaft 360° and try again.
    Both sprocket marks should be 90° from the valve cover gasket surface (ie, the cylinder head surface is "9 and 3 o'clock", the marks should point exactly to "12".)
    You may have to reset camshaft timing. Hopefully nothing is so far off that valves hit the pistons.
    Jefferson Santos and Brian1954 like this.
  4. Jefferson Santos
    Hamilton
    Thanks for your help.
    I am back to the crime scene.
    My pulley is a bit different than the one in the manual. I am assuming the mark is the one that aligns with the keyway.
    I will setup as per instructions and send more photos.
    If any adjustment needs to be made?
    Is there any problem to rotate the camshaft manually?
  5. Jefferson Santos
    Hamilton
    Found the problem!
    The previous owner did not install the crank shaft sprokets at the right position.
    That is why it was not working as per manual instructions.
    I thought the chain had slept 1 or 2 teeth but not.
    Brian1954 likes this.
