2010 Prius - P0401 after EGR & manifold cleaning
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by faneprius10, May 18, 2025.
  1. faneprius10
    faneprius10 New Member
    Romania
    Hi guys,
    Long post ahead - sorry in advance!!
    I have only just created an account but have been lurking on this forum for a while. I recently bought a 2010 Prius with 250k kms (~150k miles) that was parked for almost 3 years outside for a very low price. I was extremely lucky with it, got it up and running just by changing the oil and hooking up a new 12v (it still had the original one, obviously toast after 3 years of sitting) HEV battery also looks good at 80% health according to Dr. Prius (most likely it was refurbished just before it was parked - the owner was a company that went bankrupt so the car was auctioned off) Car drives fine, no power issues, fuel consumption is around 4,5 liters / 100km (~52 mpg)
    Anyway, it seemed to only have one code stored - P0401, the dreaded EGR insufficient flow code. I went ahead and took it to a mechanic that knows his stuff around hybrids and of course, the EGR, cooler, fuel injectors and intake manifold were full of junk :
    WhatsApp Image 2025-05-14 at 12.38.31_3fd892bd.jpg WhatsApp Image 2025-05-14 at 12.38.31_23270f87.jpg WhatsApp Image 2025-05-14 at 12.38.31_a1978ea9.jpg WhatsApp Image 2025-05-14 at 12.38.31_fd1dbc2d.jpg WhatsApp Image 2025-05-14 at 13.24.10_3707a4f1.jpg WhatsApp Image 2025-05-14 at 13.24.11_b5dd69e8.jpg WhatsApp Image 2025-05-14 at 13.24.11_f39cebe7.jpg
    But not a worry, the mechanic took care of it : (uploading pics just in case somebody wants to see a before and after)
    WhatsApp Image 2025-05-14 at 15.03.27_42d43dd5.jpg WhatsApp Image 2025-05-14 at 15.03.27_42089b03.jpg WhatsApp Image 2025-05-14 at 15.03.28_700ac7fe.jpg WhatsApp Image 2025-05-14 at 15.03.28_f60af247.jpg
    Paid the man, drove the car home. No check engine lights; Car was performing very similar (didn't notice any performance issues even with the code) - maybe just a tiny bit smoother and less noisy.
    200 kms later, the code pops up again! Very upset with that. Went on this forum and saw that the car does a certain test for the egr flow - mine was total crap. 0.17 kPa! Honestly looks like a full obstruction.
    I read the huge thread that found the "ski jump" plastic bit inside the valve rotor to be the culprit. Went ahead and took it apart :
    It looks fine to me! It certainly is not as smashed as in some pics I have seen on that thread. The valve itself also operates smoothly by hand.
    I have also checked MAP values, 35 kPa at idle seems to be in line with what other guys were getting, so I'm assuming the MAP's fine as well...
    So what else could it be? The only other suspect I have would be that the mechanic somehow messed up some gasket installation:
    I'm refering to the gray - black gasket between the valve and the cooler itself. I'm thinking that shouldn't sit like that - maybe that's what's obstructing the flow! But then on watching some YT videos... it looks the same there.. And also, I don't see how you could screw that up, looks like it can only be installed in one position since it's held in by 2 bolts...
    I've no idea what to do next. Can the stepper motor be bad ? As in, not functioning at all? I'm assuming that would've caused other problems.. like rough idle, rattling..
    Thanks a lot guys and really appreciate all the knowledge sharing on here!
  2. wukong sun
    wukong sun Junior Member
    66
    Someone did say that the EGR valve has plastic threads that are easy to damage after a long time. He said that it was fixed with screws and washers, but I don't know how he did it specifically, and there are no photos.
    faneprius10 likes this.
  3. Mendel Leisk
    41,824
    ^ I'd say that's not fine. Optimum would be to replace with new EGR valve. I've a hunch that the more clogged the system is, the more that valve mechanism has to work, exacerbating the wear. That damage "may" be the cause of the ongoing P0401.
    ^ While commendably cleaner than the "before" disaster, you can goet those like-new clean. What cleaner or technique was used. Corking one end and pouring in a caustic solution and letting it soak, rinse and repeat, will get the stubborn remnants.Low intensity would be Oxi-Clean Versatile Statin Remover (powdered laundry additive), as concentrated as you can make it. Or lye. I've not used the latter but suspect it's very effective and fast.
    ^ The condition of those EGR orifices is very telling. Any exahust gas that managed to get through the cooler/valve/pipe would have hit the wall at that final hurdle.
    All-in-all your guy did a pretty commendable job: if you don't mind, what did he charge?
  4. ChapmanF
    18,454
    Yes, that right there is a ski jump with a rut right through the middle of it. So when closing the valve, the rotor goes right past the point where the valve is closed, and only stops when it is would up tight on the pintle threads. Then when the ECM wants to open the valve by so many steps, it counts rotor steps from there, and the valve will never be as open as it should be.
  5. wukong sun
    66
    Do you know how to fix it with nuts?
  6. ChapmanF
    18,454
    That could be something someone spuriously said. I've never seen or heard of a problem with the threads in the rotor.
    On the other hand, a rut gouged through the "ski jump" stop on the inside of the rotor is a common and definite problem, and the photo that you posted in #1 definitely shows that it's a problem you have.
    So, I would probably recommend to relax about possible worries somebody somewhere may have circulated about threads, and focus instead on the definite problem your own photo shows that you have.
  7. faneprius10
    Romania
    Hello guys! Yesterday was election day in Romania and waiting for the results kept us on our toes all night, so sorry for the late reply!
    Thanks for your input! I'm going to try to reply to you all in this post:
    @wukong sun that is an interesting point, but I don't really see any visual sort of issue with the valve's threads!
    @Mendel Leisk Thanks for the very very detailed reply! I thought just having the actual 'slope' there, even with the rut in the middle was enough for the stop to do its job. Seems like the next step would be to either go hunt for another stepper motor at the junkyard (there was some guy on the forum who replaced it with a 1.3 Urban Cruiser stepper motor which looked identical), if not, time to buy myself a new OEM EGR!
    As for what cleaning products were used, honestly, I have no idea; all I know is that the injectors were cleaned using ultrasounds. But I'll ask the mechanic anyway and report back if he provides an answer!
    As for the whole operation's price, if you ask me, it was really darn cheap! Since you're interested I'll defalcate all the costs. Car got a thorough cleaning (EGR Valve, EGR Cooler, all the piping related to that; Injectors cleaned with ultrasound, Throttle body, intake manifold); I also replaced the gearbox oil (it was pitch black!!!!) - I provided the oil since I wanted to change it by myself but something got in the way so it was left for the mechanic to do - and lastly, brake fluid change.
    Total costs (in US Dollars) : 330 $
    EGR + assemblies(Cleaning bit) : 155$
    Injector ultrasound clean : 45$
    A/T oil change : 22$ (just labour charged - oil was about 45$ maybe?)
    Brake fluid change : 78$
    @ChapmanF , thanks for the technical explanation and the reinforcement of Mendel's opinion. Seems like I've got to hunt for a new valve / rotor!
  8. Mendel Leisk
    41,824
    Those are good prices. Yeah I’d get new EGR valve, and keep in mind to clean EGR cooler next time with a caustic solution such as lye. It’s safe for stainless steel, but I would not use on anything else.
  9. faneprius10
    Romania
    Hi guys, a little bit of an update on the situation.
    I went to my mechanic again, he scanned the car and confirmed that the cause for the code is either the ski jump stop or the stepper motor altogether. He proposed 2 ways of dealing with this - either we order a new egr valve (~500$) or we install a second hand one taken off another crashed Prius (125$ labour included) - he also added that if the second hand egr doesn't fix the problem he won't take my money. So good to know my mechanic is a very nice person!
    I have also changed the spark plugs with original Denso Iridium plugs. This cost 70$ including labour. It was worth it, I had it on my agenda too but seeing the state that the old plugs were in, I'm happy I did it! Too bad I didn't take pictures.
    Mechanic also told me that he thinks the engine might be running a little hot. I told him I never saw the coolant temp go past 93C (199.4F), even when climbing steep hills at 3500-4000 rpm. He said these cars usually hover around 87-88C. What do you guys think? What's the optimal coolant temp on these cars?
    Brian1954 likes this.
  10. Mendel Leisk
    41,824
    Your mechanic should shop around:
    part no:
    25620-37120
    (Early years are 25620-37110, which shows on Amayama as out of production. The revision is compatible, I believe the insulation on the electrical connector just needs to be loosened, to afford slightly more reach)
    through Amayama:
    https://www.amayama.com/en/part/toyota/2562037120
    For me it comes to 240.56 CAD +26.46 (shipping), and from past experience that’s it, no extra taxes or duty.
    in summary: that’s on my doorstep, western Canada, for roughly $200 USD.
  11. ChapmanF
    18,454
    On PriusChat you have to be careful about calling someone a nice person.
  12. Mendel Leisk
    41,824
    Demo:
    getting to the spark plugs is a complete pain in the nice person.
    ^ not what I typed.
