Featured New (?) Chinese Lithium Prius Battery Conversion
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Pd30242, May 19, 2025.
  1. Pd30242
    Pd30242 Junior Member
    26
    Chicago
    I just saw a new lithium conversion kit for the old NIMH Prius cells the other day and was wondering if anyone here has heard of it before.
    They’re only asking $1400 and I’m considering buying it but the lack of BMS makes me a little weary. I don’t know battery technology that well but I’m hoping someone here does.
    The company is called MTG
    BMW i3 Battery Replacement & Upgrade | Volkswagen E-glof/Renult Zoe/Nissan Leaf |MTG – Upgrade Your BMW i3/E-glof/Renult Zoe/Nissan Leaf Battery – More Power, Longer Range
  2. jacktheripper
    jacktheripper Senior Member
    275
    548
    Are you guys kidding right? this is NCM lithium chemistry, it is literally a disaster waiting to happen on a Prius...
    mudder and Brian1954 like this.
  3. ChapmanF
    18,499
    Yeah, the subject of changing out NiMH modules for lithium in a car that still thinks it is managing NiMH has generated discussion here before.
    douglasjre, Pd30242 and Brian1954 like this.
  4. Brian1954
    Brian1954 Senior Member
    2,387
    959
    South Central PA, USA
  5. PriusCamper
    PriusCamper Senior Member
    13,015
    5,289
    Pacific Northwest, USA
    I think some of the finer points of this discussion rarely get enough attention... As in each battery chemistry has its own specific types of safety risks.
    For example high density cells like Lithium-Ion require the highest level of safety with every cell needing to be monitored and the whole system shutting down when a cell starts giving bad readings because if a Lithium-Ion cell catches fire the odds of putting that fire out before the whole car burns to the ground are slim to none unless it happens in front of a fire department or you can push your car into a swimming pool.
    On the other end of the safety spectrum are Nickel Metal Hydride (NiMH) batteries that Toyota uses in most of their hybrid cars. These are low enough density that if they fail you'll get smoke, blown covers and melting plastic, but your car won't turn into a raging inferno. This is why Prius' battery system doesn't monitor every single cell in the pack but block of 12 cells because it reduces costs, complexity and is safe enough. Another thing that's great about NiMH is they can handle being overcharged much better than Lithium which will fail if they are overcharged.
    Somewhere between the two extremes is Sodium-Ion (closer to NiMH) and Lithium Iron Phosphate (closer to Lithium-Ion). Both of these chemistries are also considered low density so a pack could fail and smoke and melt plastic, but no risk of a catastrophic fire unless maybe if you're a gasoline smuggler.
    In a perfect world we'd simply design a BMS that is specific to needs of each chemistry. But in the proprietary corporate world we live in where we can't re-write Toyota BMS code and most types of hacking with a different battery monitoring system will trigger warning lights and system shut down, makers of these types of after market packs have had to do lots design changes to keep all the sensors and computers happy in a Prius.
    All that being said, in a decade or so the aftermarket hybrid and EV battery business is going to advance enough that the safety risks we face today won't be as challenging, nor will the pricing.
    #5 PriusCamper, May 19, 2025
    jacktheripper and RX808 like this.
  6. bisco
    52,350
    hard pass
  7. Pd30242
    26
    Chicago
  8. AzusaPrius
    AzusaPrius Senior Member
    2,224
    930
    First time seeing this but I must say I like the build quality, looks as if the whole case is a heatsink.
    Just change the chemistry to sodium and all should be good.
    jacktheripper likes this.
  9. mudder
    mudder Active Member
    280
    384
    Chattanooga, TN
    Yes, the whole case is a heatsink. Unfortunately, I do NOT recommend this product for several reasons. I can film a video if people are interested.
    NT Ram, douglasjre and Pd30242 like this.
  10. ChapmanF
    18,499
    only if it's organized and succinct
    douglasjre likes this.
  11. mudder
    280
    384
    Chattanooga, TN
    No promises, but I'll try. We'll see where my mind takes me.
  12. mudder
    280
    384
    Chattanooga, TN
  13. BuckleSpring
    BuckleSpring Member
    64
    32
    United States
    I'm not as disappointed as I thought I'd be. Based on your capacity/load test, the cells seem decent enough. The housing is nice, and the overall construction seems at least halfway decent. With a few mechanical/electrical refinements like those you outlined in your video, they might be onto something... If you pair it with a proper BECM replacement for obvious reasons.
    $1,400 for a full set of modules ($1,200 in a couple of places I've seen), realistically even lower if/when they swap to cheaper injection molding for the main body, is quite appealing. I'd still consider it cost-effective even adding at least a few hundred for a BECM replacement if/when someone designs one.
    rjparker and mudder like this.
  14. mudder
    280
    384
    Chattanooga, TN
    Yes, the cells performed well electrically in my testing. The cells themselves are quality except for the peeling insulation around each cell. I strongly suspect they are second-sourcing cells from another existing project. Blade manufacturer wouldn't answer questions regarding who they source their cells from².
    Yes, these blades would be a stellar value if you fixed the safety issues shown in my video, including adding a proper BMS with supervisory control (e.g. my pending 'LiBSU' product). This would of course require the manufacturer to safely route out the center voltage tap.
    ²But they did send me their radiated emissions testing for some reason, which isn't required for a product like this for several reasons, but hey they passed so whatever.
    #14 mudder, Jun 5, 2025
    BuckleSpring and rjparker like this.
  15. InnRGPower
    InnRGPower New Member
    Hey Mudder,
    I've been a big fan of your work for a while now, especially since your Honda LiBCM project – that was truly impressive! I also really appreciate your in-depth and unbiased battery reviews, like the ones on Jack's Li-ion and the sodium-ion cells. Your insights are always spot on and incredibly helpful to the community.
    My company has developed an OEM drop-in Li-ion battery, and we believe it's a significant step forward. In fact, many of the current Li-ion batteries on the market are based on our earlier designs.
    Given your expertise and thorough testing methodology, we would be honored if you'd be interested in reviewing our battery. We're confident it will meet your high standards, and we'd be happy to send you a few free demo samples for testing.
    Please let me know if this is something that might pique your interest. We'd love to connect!
    Best regards,
    Eric Zheng
    mudder likes this.
  16. mudder
    280
    384
    Chattanooga, TN
    Hey Eric, I am certainly interested in reviewing your product. I sent you a private message with contact information. Please respond to that PM with any additional information. If possible, please send me your schematic for review. It can be abstracted as needed to preserve trade secrets that I wouldn't be able to deduce on my own during inspection.
  17. Roco1993
    Roco1993 New Member
    Hong Kong
    Hi mudder, I left the comment on your youtube video by the username CharSiu. I know the designer of this kind of battery. As you said in the video, he did aware the insulation problem on terminals, so he used plastics in later versions.
    But Huilian and some other manufacturers are not aware on this. I can even show his patent certificate to you and can even share more details on it. I am new to PriusChat and I am not sure how to send a private message. Please contact me.
    regard,
    Roco.
  18. mudder
    280
    384
    Chattanooga, TN
    He Roco, PM sent to discuss this further. Is the 'PHEVE' blade in your picture your engineer buddy's original design? Regardless, I'd love to review it if the innards are different from the Huilian module I reviewed last month.
