2010 Prius still shakes after head gasket job and EGR + intake cleaning
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by infinitepub, May 7, 2025.
  1. wukong sun
    wukong sun Junior Member
    66
    I'm not throwing out my questions
    His cylinder head gasket has been replaced
    There is still a problem
    I asked him to look at his EGR_ERR data
    Troubleshooting the EGR valve
  2. infinitepub
    infinitepub New Member
    Sorry it's been a few days. Finally got a hold of the borescope and a coolant system pressure tester. In the video I attached you can find the main issue I'm facing (the violent shaking). Like previously mentioned, the shaking is continuous and doesn't go away as seen at 0:10-0:16 seconds at the start of the video.
    I went ahead and plugged the EGR pipe completely off with a flat spade I had. This resulted in a smooth engine idle which I experienced after doing the headgasket and prior to doing the EGR/intake cleaning. There is an intermittent shake that is minor that can be heard at 0:54 seconds. This intermittent shake was the same shaking which lead me to do a deep clean of the EGR system and intake.
    My thoughts as of now... I think there might be an issue with my EGR valve. Plugging the EGR pipe with the spade has replicated the condition of the car prior to my deep clean. Could the reason why my car is now violently shaking after the deep clean be due to some exhaust gas being let back, but a blockage somewhere is causing issues b/c inadequate exhaust gas is being sent back to all 4 cylinders? For example, before the deep clean there was so much blockage that no exhaust gas was coming back which is the same as plugging the EGR pipe completely with a spade. Now that it's clean, some gas is able to pass, but not equally in all 4 cylinders?
    From the 1:00 mark to the end of the video I show the condition of my cylinders and check for leaking coolant. I pressurized the coolant reservoir with 15 psi which is about the same as 108 kPa which is suggested on the cap. All four cylinders seem to not be leaking any coolant after 30 minutes of pressure. As of writing this reply, it has been about 2 hours since I pressurized the coolant system. The pressure still holds at 15psi and there is no indication of leaks.
    tldr: Car doesn't shake when EGR pipe is blocked with spade & runs exactly as it did before doing an EGR & intake deep clean. Coolant system pressure tested for 2 hours and borescope showed no leaks in headgasket.
    Should an EGR valve solve my issue? Please offer your expert opinion before I splurge on a new EGR valve.
    Thank you so much for your time!!!
  3. Brian1954
    Brian1954 Senior Member
    2,371
    954
    South Central PA, USA
    By using the putty knife to block the EGR valve off from the intake manifold, you have proven that your EGR valve is stuck partially open when it should be closed. At idle and full open throttle, the valve should be closed, and no exhaust gases should be flowing into the intake manifold.
    Your options are to try to get your existing EGR valve functioning properly or replace it with a used or new valve.
  4. wukong sun
    66
    If you have disassembled the EGR valve, please confirm whether there were any errors in the assembly.
    After I disassembled it, I pressed the valve and it went in and out smoothly. After installing the rotor, it was not smooth when pressed. In the end, I installed it. But I can't tell what's going on.
  5. infinitepub
    Thanks! Will be taking it apart to see if it's salvageable.
  6. infinitepub
    Thank you, I'm hoping the EGR valve is salvageable bc a new one is about $180. Do you happen to know the part number of the E8 torx stud that runs through the EGR valve? I accidentally stripped the top of it.
    Screenshot 2025-05-13 at 7.12.29 PM.png Screenshot 2025-05-13 at 7.13.04 PM.png
    wukong sun likes this.
  7. ASRDogman
    ASRDogman Senior Member
    7,758
    3,967
    You don't need to replace the stud. Screw it in all the way until it bottoms out, then back it
    out a full turn. The nut will provide the tension to keep it in place.
    Then next time you remove the nut, either it or then will come out loosely.
  8. Brian1954
    2,371
    954
    ^ +1. I do not think you need to buy a new stud. I would screw it in finger tight. Then use the nut to tighten up on the valve.
  9. wukong sun
    66
    It's not a big deal if this screw is missing, as the EGR is already fixed with many screws.
    I haven't had this screw since I bought a second-hand car.
  10. Mendel Leisk
    41,824
    #30 Mendel Leisk, May 15, 2025
    Kromis and Brian1954 like this.
  11. infinitepub
    I ordered a new EGR valve assembly straight from toyota and put it in today. The problem still persists and I'm not sure what else it could be. Blocking the EGR pipe still remedies the issue. Anyone know of something else I could try?
  12. rjparker
    10,411
    6,521
    I would look for a bad or missing gasket either where you are blocking egr flow or on the valve or cooler.
    There is also a specific direction for some of those gaskets.
  13. infinitepub
    All gaskets are new, fitted properly, and there's none missing.
  14. rjparker
    10,411
    6,521
    Then you have a hole in the cooler, pipes or valve. It makes better sense one of the gaskets are the problem or a bolt is loose if your flow blocking is solving the issue.
    When you have checked everything and the problem remains, one of the assumptions is false.
    Another test is the egr step test while monitoring map pressure with Techstream. It forces the egr open and close while in maintenance/inspection mode.
    #34 rjparker, May 23, 2025
  15. rjparker
    10,411
    6,521
    Does the new egr have this number embossed in it?
  16. wukong sun
    66
    I have a similar problem. The idle speed is stable and there is no shaking. Once the high-voltage battery starts to charge, it will start to shake.
    It is the same when driving at low speed. If you step on the accelerator, there will be no shaking. You can't feel it when driving at high speed.
    In the above shaking, as long as you step on the brake, it will return to normal. I suspect it is a circuit problem.
  17. infinitepub
    Yes, my new EGR has the same number
  18. infinitepub
    Hmmm, I'll triple check again if it's the gaskets, but I swear they're on right and not blocking. There certainly isn't a hole anywhere and I torque all the nuts to spec. Will check gaskets in the morning b/c I don't have the energy to clamp the hoses and pull that EGR out again
    Will look into egr step test too
  19. infinitepub
    My prius does the shaking when the engine is idling. I'll try to pump the breaks like you say. I don't feel comfortable driving just yet because I don't want to keep the car in a prolonged shaking state.
  20. infinitepub
    Is there such a thing as a faulty EGR valve command. For example, is the computer telling the EGR valve to remain open when it shouldn't be during idle which is the cause of my issue? If so, how can I test for this?
