Wheel upgrades, need help
Discussion in 'Gen 5 Prius Main Forum' started by sam2day88, Jul 13, 2024.
  1. Cc103acs
    Cc103acs New Member
    28
    Connecticut
    2024 Prius Prime
    XSE
    I upgraded from the stock XSE wheel to a 17” wheel and, as you can see on the fitment chart, the new shoes exceed an 8” width with no rubbing issues. IMG_3790.jpeg IMG_3790.jpeg IMG_3790.jpeg
    #21 Cc103acs, Jul 16, 2024
  2. sam2day88
    sam2day88 New Member
    Annapolis, MD
    2023 Prius
    Pulled the trigger and got the TRD Camry rims and put 245x40x19 Dunlap tires on it. They are amazing no modification or spacers needed and the overall height is exactly the same as the stock rims. They are 9.37 inches wide and ride like a sports car.
    PhoS likes this.
  3. _flop
    _flop New Member
    2024 Prius
    That looks nice! Got any more pics, like whole profile/side shot?
    And then just to clarify, the stock Prius 19's are 195/50, did you mean 245/50/19, or are those Dunlaps wider but thinner sidewall?
  4. Hammersmith
    Hammersmith Senior Member
    2,495
    2,554
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    The middle number in a tire size is a ratio, not a fixed measurement. So a 195/50-19 has basically the same sidewall height as a 245/40-19.
    195mm x 0.5 = 97.5mm = 3.84"
    245mm x 0.4 = 98.0mm = 3.86"
    _flop likes this.
  5. purplePriii
    purplePriii Active Member
    275
    123
  6. Rugged_Rowan
    Rugged_Rowan Junior Member
    Southeast
    2025 Prius
    Yeah u have more pics ! Side profile shot of the car at least ? I’ve been looking into doing this to mine also. And did u notice a decent amount of mpg decrease and speedometer being off a little?
  7. Rugged_Rowan
    Southeast
    2025 Prius
    Any side profile shots? And speedometer affected too?
  8. Blackat
    Blackat Active Member
    488
    356
    Colorado
    2023 Prius
    Limited AWD-e
    I upgraded to Enkei 17 x 7.5 with Conti 225/55/17
