Might have rodent damage to wires. a question
Discussion in 'Gen 2 Prius Main Forum' started by Steve Howey, Mar 9, 2025.
  1. Steve Howey
    Steve Howey New Member
    17
    2009 Prius. I am looking up from under the car, the oil filter is to my right. On the left there are two coolant lines going into the transmission. There is a black electrical conduit going from left to right, it has a junction above the coolant lines...that junction is crumby, looks like it has been chewed on, and I see white, probably white wires. This junction goes to a gray plastic part (sensor??) that is bolted to the trans. What is this sensor and has anyone had experience trying to fix a damaged junction like this? Years ago the protective shield under the car engine was lost. Any help is appreciated. I can try to get a pic. thanks.
    rjparker likes this.
  2. Steve Howey
    17
    posted jpg
  3. Steve Howey
    17
    Does anyone know what the part/sensor is that is shown in the pic? The view of he pic is looking up. The gray plastic part that is show in the pic, can you tell me what it is? 2009 Prius.
  4. bisco
    52,307
    any trouble lites? i would slit the plastic tubing back to assess the damage
  5. mr_guy_mann
    mr_guy_mann Senior Member
    4,083
    1,995
    NJ-USA
    A six wire connection - is likely wiring for a "resolver". That's a fancy position sensor for one of the hybrid drive motors. The sensor is mounted inside the transmission. The gray part with the bolt is just the mating connector (and wires) that goes through the trans case.
    I would (carefully) unlatch the connector and inspect the wiring harness. To me it definitely looks nibbled. If the wires are ok, then wrap it in electrical tape and put it back. If there's "minor" damage to the wire insulation, you can use "liquid electrical tape" then regular electrical tape. If the copper conductors are damaged, then you have to repair things (somehow).
  6. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    Third planet from the Sun
    Yes, that's right. The color coding on the visible part of the connector matches the hybrid wiring diagram.
    Problems can arise due to wire breakage or short circuits, then such error codes will appear.
    https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/repair%20manual/04pruisr/05/21bpm/0a4b253.pdf
  7. Steve Howey
    17
    thank you so much. This is making sense...the codes were POA4C, POA4D.....generator position sensor. This 2009 Prius was working fine in the city, but was parked in a rural farm site for a few days (possible mice/rodent source) and then the car would not move. Warning lights are the red triangle, a red brake light on the left side of dash that won't go off. and, display screen has the red outline of car with the ! sign in red. Will follow up carefully and report back. I hope this is the problem! Much appreciated!
  8. Steve Howey
    17
    Warning lights are the red triangle, a red brake light on the left side of dash that won't go off. and, display screen has the red outline of car with the ! sign in red. problem codes were POA4C and POA4D, generator sensor.
  9. Steve Howey
    17
    I posted this around March 9. car won't move. I have attached updated pics. Review: it appears there was rodent nibbling damage on the wrap (electrical tape?) on bundle of wires that goes to the sensor (see pic). I carefully stripped back conduit, and inner insulation to inspect wires. There are 3 bundles of wires with 2 wires each (six total wires). Black/white, Red/green, and looks like pink/yellow in the three bundles, respectively, that go to sensor. I see minimal damage to the insulation on white wire, I can see some copper. The thing that is puzzling me is these 2-wire bundles also had an additional bare wire (looks like aluminum wire). I only opened two bundles, each one has bare wire going to nowhere. I have not opened pink/yellow bundle, looks ok. The pics are looking up under the car, near the front...the oil filter is to my right. Can anyone tell me what these additional bare wires are? They look like they are the same length...maybe they are just extra wires left in there? The insulation on all the other wires seems ok. THANK YOU for following up. POA4C, POA4D error codes, red triangle, red brake light, and red outline of car on display with ! exclamation. questions welcome generator sensor 1.jpg generator sensor 2.jpg generator sensor 1.jpg generator sensor 2.jpg
  10. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    Visual inspection and photos are good, but did you take measurements as indicated in manual in post #6?
  11. Steve Howey
    17
    response to post #10, MAX2. Short answer is no, have not checked resistance (ohms) or volts on any of these components. I am still puzzled about the bare wires, they seem to go nowhere but were wrapped in the bundle along with the two other wires (for example one bundle is white and black wires, plus this bare wire.) the bare wire does not continue on, it just stops abruptly. I will try to do some measuring. thanks, any questions are welcome from anyone or additional guidance. thank u
  12. Steve Howey
    17
    I can't locate the H17 HV control ECU connector in Prius. Any guidance, where is it? thank you
  13. ChapmanF
    18,472
    You are looking at shielded cables. The shields are shown with dotted lines in the diagram here.
    The idea is to enclose some sensitive signal-carrying wire pair in a kind of Faraday cage (so the shield has to be grounded somehow) so that the signals on those wires don't interfere with signals on others nearby and vice versa.
    The actual shield can be made in a few different ways, like braiding very fine wires into a braid that goes all the way around the shielded wires, or just by wrapping some conductive metal foil around them. The shield still has to be grounded somehow; for a metal foil shield that usually means just running a bare wire all along it, so it's in good electrical contact with the shield all along, and then you just ground the bare wire at one end or the other or both.
    Here they have shown the black/white pair that carries the resolver field excitation signal to the sensor, the red/green pair carrying the sine signal back, and the yellow/brown pair carrying the cosine signal back, all in their own shields. For all those shields, the drain wires look connected to ground on one end, at splices where they turn into white/black-stripe wires and then ending up at the J12(A) junction connector.
    It's generally good enough to ground a shield at one end and not both, and in fact that saves you from ever having the shield turn into an unplanned current-carrying conductor if the ground potentials aren't exactly the same at the two ends. So yes, that drain wire probably just ends at the sensor ends without connecting to anything.
    MAX2 likes this.
  14. Steve Howey
    17
    ChapmanF: Wow, thanks for taking the time to explain that, makes sense. There was a thin brown/golden color "foil?" around these bundles. I certainly learned something here. Much appreciated.
    #14 Steve Howey, May 3, 2025
  15. mr_guy_mann
    4,083
    1,995
    NJ-USA
    The bare wire and foil tape are there for shielding. They connect to chassis ground and surround the insulated wires, reducing electromagnetic interference in the circuit signals.
    You'll want repair the wires and use foil to rewrap the harness as best you can before insulating the entire bundle. (maybe it'll be ok without that, maybe not).
    The shields are shown as dotted lines on the diagrams here. wire_shielding.jpeg
  16. pasadena_commut
    pasadena_commut Senior Member
    2,778
    831
    Southern California
    Repairing shielded wire well is hard. Really hard. Is the damaged section maybe on a reasonably small piece of cable with a single plug at each end (no forks)? Because getting a good cable from the junk yard and replacing it is likely to turn out better than a repair on the damaged cable. On the other hand, if it is part of some massive loom which forks and runs all over the car replacing that could be nearly as difficult as repairing the shielded wire.
  17. ChapmanF
    18,472
    It is, and would be much more work to replace than just repairing the damage. The other ends are at the HV control ECU under the passenger side of the dash.
    If it is foil shield with a drain wire, fold the foil back down over your repairs when you're done.
    If you tore some of the foil away, and you want to be fussy about it, wrap some kitchen foil over the repairs, make sure the bare drain wire touches it, and tape it up nice.
    The shielding already isn't continuous all the way to the ends; the signal wires are outside of any shield for several cm or so on each end, and terminate in unshielded connectors.
    The amount of worry I would dedicate to how the shield repair might be imperfect is: zero, unless I get it put back together and the ECU actually doesn't like the signals.
    mr_guy_mann likes this.
  18. mr_guy_mann
    4,083
    1,995
    NJ-USA
    This isn't "coaxial" cable - that has braided or woven conductors that are part of the signal path. This is just foil tape and an "earth drain" wire - not much to it.
  19. Steve Howey
    17
    Continuing to work on this. Pic attached. On this resolver, the black wire (one of six wires) was barely hanging on, and when working on this it has broken away. There is a tiny stub of wire coming out of the resolver , if I make a good connection and hold it, the gas engine in the Prius started up. This is a good sign I think and when off the jack stands I will see if the car moves. The rror code was PO4AC. My question is, I see there are little gray "plug-like" leads into the resolver. Do these pull out so I could try a splice (temporarily) with a good connection to the resolver? Right now there is no way to keep the black wires held together. thank you.
  20. Steve Howey
    17
    Motor revolver sensor..... I mean. Need to replace wires in a new sensor. Any questions let me know.....
    #20 Steve Howey, May 24, 2025
