UFO and battery light but no p0a80
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Rafflesia, May 30, 2025.
  1. Rafflesia
    Rafflesia New Member
    Roanoke VA USA
    Hey!
    I have recently acquired a car that uses to be of my grandfather's who sadly got dementia and had to move to a retirement community. Its a generation two Prius and it has the very concerning UFO light and battery icon. It also has a coolant leak for sure which I am trying to find but coolant definitely leaks out, I can see it pooling under the car.
    Strangely, any OBD2 scanner I try using only gives two codes, P0505 and P1121, both related to the cooling system, but no hybrid system codes. The app I was using even mentioned that it was scanning the hybrid system but didn't find codes on it. I tried using Dr Prius but it just exists out with some error I can't quite remember, I'll be sure to screenshot it and post it next time I am near the car
    Car does move, brakes feel terrible and it overheated once before I figured out the coolant was leaking, but the engine still works. Any advice on getting this car properly running on the cheaper side?
  2. Rafflesia
    Roanoke VA USA
    picture of dashboard
  3. bisco
    52,696
    welcome!
    start by searching for the autel scanner. seems to be the best bang for the buck with prius.
    then post the codes again.
  4. bisco
    52,696
  5. Mendel Leisk
    42,200
    Googling "ufo light", OP is the one-and-only plausible result. Could this be something else??
  6. pasadena_commut
    pasadena_commut Senior Member
    2,980
    925
    Southern California
    P1121 is usually the 3 way valve which determines when coolant goes into the thermos bottle. Usually the car will work OK with that not functioning. I suppose it is possible that it has broken in such a way that it leaks. This is located near the thermos and is a common part to fail. There are numerous youtube videos showing how to replace it.
    P0505 is a dirty throttle body or MAF sensor. Try cleaning the throttle body and the MAF (they are in essentially the same place), then unhook the 12V battery for 30 seconds or so to force the car to relearn. Again, youtube is your friend. Do a little research on cleaning the MAF, both the bulb and a spot below it must be cleaned. Use MAF cleaner, don't touch it with anything but spray, and it is an easy job.
    Check the level of the coolant for the inverter (reservoir next to the inverter), in the overflow tank (behind the radiator), and in the radiator (remove the tray to access it, support the "neck" when opening as it is not very sturdy). Don't run the car unless there is adequate coolant in all 3 locations. High in the radiator neck, full at the inverter reservoir, half full in the overflow tank. At the same time check the oil (because who knows when that was last done). The transmission fluid is probably filthy too, but that can wait.
    If the OP can put the car up on jack stands finding an active coolant leak shouldn't be too hard.
    In what way do the brakes "feel terrible"? Are they just worn down, won't hold pressure, make grinding noises, or ...?
  7. Tombukt2
    13,765
    2,491
    It looks like he's using the car scanner app and no telling what car he has selected like whatever it was the last time or something the codes don't even line up with the car not even for a Corolla so. He'sgotvthe app setup for his VW and Jess plugged it into Prius or such. I've done this before.
  8. dolj
    dolj Senior Member
    8,631
    4,385
    Wellington, New Zealand
    The battery icon on the MFD relates the the 12 V battery, not the hybrid vehicle (HV) battery, as nobody has followed up on that point.
    Get the 12 V battery fully charged and then load tested. Replace if necessary.
    Mendel Leisk and Brian1954 like this.
  9. Rafflesia
    Roanoke VA USA
    Thanks so much for all the responses!
    The breaks feel pretty damn worn down to the point i feel nervous about it holding still on a drive way with a steep grade, but that may be my overreacting getting the best of me. I wonder if it's air that got into brake fluid lines over time, but it could be the actual brakes themselves, I'll check tomorrow to see which one it is, though I don't really know how to check for air in brake lines unfortunately
  10. bisco
    52,696
    check the fluid level. air should feel spongy i think. you'd probably have to bleed them, and might need a tool for that.
    low brake pedal could be pads, but there is a warning sound indicator when they are almost worn out.
  11. bisco
    52,696
    how many miles on her?
  12. ChapmanF
    18,894
    Prius brakes are funny. In the fail-safe mode, you can feel a spongy pedal if there is air in there.
    But in the normal mode you can't. The ECU just sends more fluid down the line to make up for the air and the pedal feels the same.
    Which is why it can be a bad surprise if there's air that you don't know about and you're driving along, and then something triggers the brakes to go into fail-safe mode, only in that case "fail-safe" isn't.
  13. Rafflesia
    Roanoke VA USA
    193k!
  14. bisco
    52,696
    i had a feeling that might be the case, but i couldn't remember the details
  15. bisco
    52,696
    just broken in :cool:
  16. Rafflesia
    Roanoke VA USA
    I think I figured out the overheating and charging... The belt is basically not even on there..........
  17. dolj
    dolj Senior Member
    8,631
    4,385
    You figured out the overheating, but not the charging. There is no alternator down there. Battery charging and running power duties are the purview of the DC/DC converter in the inverter assembly.
    There might not even be a problem with the charging. It is not uncommon for the 12 V battery to discharge to flat while sitting for long periods of non-use.
    So you have found the source of the coolant leak, then? Is it leaking from the pump?
    That belt must have only just come off, as you would have destroyed the engine within minutes with no engine cooling.
    Don't try and run the engine until you replace that belt. While the belt is off, spin the pump and the idler pulley to confirm they both spin freely and smoothly without any grinding noise/feel. If either the pump or the idler pulley does not spin smoothly, whichever one will need replacing – the belt doesn't just come off for no reason.
    #17 dolj, Jun 12, 2025
  18. Rafflesia
    Roanoke VA USA
    still not sure about the leak, the small wheel goes freely but the big wheel is fully locked up
  19. Rafflesia
    Roanoke VA USA
    this is what's not moving
  20. bisco
    52,696
    isn't the big wheel the crankshaft?
