Window tinting?
Discussion in 'Gen 5 Prius Main Forum' started by reservoirblue, Jun 7, 2025.
  1. reservoirblue
    reservoirblue Member
    95
    73
    Woodacre, CA
    2024 Prius Prime
    SE
    I live in sunny California, and with summer approaching, I have been wondering if window tinting on the prius would contribute significantly to keeping the interior cooler, especially when parked in the full sun. I know the windshield and fron side windows (?) have some inbuilt UV protection, but can I improve on that with tinting? And if so, which windows? And does tinting the windshield interfere with night vision? And, and...
    Any insight born from experience appreciated.
  2. Paul Gregory
    Paul Gregory Senior Member
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    One question: Why would you want to keep your windows closed in the hot sun?
    RandyPete likes this.
  3. frodoz737
    frodoz737 Top Wrench
    4,694
    2,495
    33
    ..."especially when parked"...
  4. Paul Gregory
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    That's what I meant to say.
  5. BiomedO1
    3,560
    1,846
    SacTown, Ca
    I'm pretty sure windshield tinting it technically illegal and would need replacement if you chip and had to replace your windshield.
    If the goal is to keep the interior cooler; you'll need to leave at least a quarter inch gap in your windows to let the hot air out of your cabin. I've installed window visors so water doesn't get in.
    You should have it ceramic tinted, that'll reject the most heat from the sun. I did limo tint on the rear doors and go with the lightest tint they have for the front doors. The rear hatch should be around 70% because of the angle. IMHO any darker, it'll be difficult to see out of your rear hatch at night.
    Hope this helps....
    #5 BiomedO1, Jun 7, 2025
    Perfectpacman and reservoirblue like this.
  6. reservoirblue
    95
    73
    Woodacre, CA
    2024 Prius Prime
    SE
    Thank you. The first and only helpful response so far.
  7. rjparker
    10,131
    6,293
    You can get clear windshield "tint" that blocks almost all uv. It is installed on the inside of the windshield. I have it on our 2022 Rav4 Hybrid.
    douglasjre and reservoirblue like this.
  8. Hammersmith
    Hammersmith Senior Member
    2,315
    2,340
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Pretty sure the car already comes with that from the factory. I think it's 99% UV blocking on the windshield, and 97% UV blocking on the rest of the glass.
    reservoirblue likes this.
  9. rjparker
    10,131
    6,293
    The window film was added after purchase. It is also legal here and in California (among others) for use on windshields.
  10. reservoirblue
    95
    73
    Woodacre, CA
    2024 Prius Prime
    SE
    I believe you are right. I have read, however, that it is the infrared (IR) that is responsible for the heat, and can be blocked/reduced by ceramic or carbon films.
    douglasjre likes this.
  11. reservoirblue
    95
    73
    Woodacre, CA
    2024 Prius Prime
    SE
    Do you happen to remember the kind and brand of film?
  12. Hammersmith
    2,315
    2,340
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Sure, but I'm saying the glass Toyota uses already blocks 97-99% of the UV. I don't know how much real effect adding any additional film will do to block UV.
    Toyota announced the UV blocking tempered glass(sides and rear glass) about 15 years ago. I assume they still use it today(I believe it has something about UV as part of the label). They were using a UV-blocking plastic in the laminated glass(windshield) for years before that.
    Toyota Glass Blocks UV Rays | Capitol Toyota
  13. Hammersmith
    2,315
    2,340
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Oh, absolutely it's the IR that heats up the interior. I agree that's what you'd need to be looking for. I was just trying to make it clear that additional UV protection was not needed.
    I'm not sure what system Toyota uses. Just that the press release said a film on the interior of the side and rear glass, and the UV protection is part of the laminated middle layer of the windshield(and front side windows if you have a Limited or XSE+).
  14. Hammersmith
    2,315
    2,340
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Also, you need to consider what will happen if you tint the interior of the windows and then have to remove the tint later. There are at least a few horror stories of owners of other Toyotas needing to replace all the windows because removing the tint film pulled away sections of the UV coating, leaving a patchy mess.
    I'd at least make sure you've got a good tint installer and that they're aware there might be a UV film on the inside of the glass(check the label on the different glass panels to see if there's anything UV related on them). Then they can advise you of the best choices for your particular car and situation. Maybe there are tint films that are more appropriate for coated glass, or maybe they've had experience with this particular type of glass and there won't be a problem. But I wouldn't trust randos like us on the internet for a big question like this. ;)
    reservoirblue and BiomedO1 like this.
  15. BiomedO1
    3,560
    1,846
    SacTown, Ca
    All I know after ceramic tinting, passengers in the rear seats no longer complain about the sun burning the back of their necks. It did seem to lower the amount of heat coming through the glass. I throw up sun shades on my windshield and do notice more heat coming through the windshield than the side windows.
    Just my observations......
    I've got 3M ceramic tint on mine.
  16. BiomedO1
    3,560
    1,846
    SacTown, Ca
    Yes, definitely make sure the shop does quality work and uses quality materials for the job! Make sure it's not a fly by night, here today, gone tomorrow shop. You may pay a little more, but it'll be done correctly. Almost all tint shops around here will give you a life-time warranty on the tint and workmanship. If they're a fly-by-night, you won't be able to collect on that warranty.
    The shop had to redo one of my rear doors, developed a bubble in the corner. They probably didn't clean it or missed a finger print in that corner.
    Good Luck
  17. Hammersmith
    2,315
    2,340
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Sorry, I should shut up, but I'm going to try and make one last post to clear things up(pun partially intended).
    What we're dealing with is the electromagnetic spectrum(EM). On one end, we've got gamma radiation. It's incredibly high energy and has extremely short wavelengths. Like a billionth of a millimeter. Unless you're Bruce Banner or getting extremely delicate brain surgery, you don't want to be anywhere near gamma radiation. On the other end, we've got radio waves. Radio starts at around a millimeter wavelength and goes up to hundreds of kilometers. Being low energy, it's pretty darn safe.
    In the middle of the spectrum, we've got the three types of radiation that we deal with car tinting: ultraviolet, visible light, and infrared.
    UV: The highest energy and shortest wavelength of the three. These wavelengths will do damage to the car and your body. They will bleach out fabrics, cause plastics to become brittle and/or get hazy, kill your skin cells(sunburn), hurt your eyes, and possibly give you cancer. Broken down into UVA(closest to visible light - not great but not insanely bad - 95-ish% of UV we see), UVB(much worse - skin cancer lives here - 5-ish%) & UVC(very, very bad, but the atmosphere blocks virtually all of it).
    Visible Light: Middle of the three. It allows us to see.
    IR: Lowest energy and longest wavelengths of the three. Transmits heat. If you feel your skin getting warm from the sun, it's IR. If the seat get hot from being in the sun, that's IR. It can make you uncomfortable from the heat, but it's not really going to harm you like UV.
    If the car's glass already has UV blocking applied as part of the glass making, then you can ignore that and focus on the the other two spectrums. How much visible light is it going to block, and how good is it at blocking IR(if you live in a climate where that's important to you). So if you're shopping different film products and one spends all its time marketing it's UV-blocking properties, that might be a waste of money if the glass is already doing that.
    I hope that was at least a little bit helpful to someone.
    #17 Hammersmith, Jun 7, 2025
  18. Paul Gregory
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    Same.
  19. VirginiaLeePrius
    VirginiaLeePrius Junior Member
    34
    Space Coast, FL
    2024 Prius Prime
    SE
    I'm in Florida where it's not only legal but a God send. I had Llumar IRX ceramic tint applied (hadn't been done yet for my profile pic) on the back glass, and side windows. I kept it within FL legal limits which say that front side windows must allow 28% visible light transmission (VLT) and rear windows 15% VLT. I can say it ABSOLUTELY makes a difference in the amount of heat transferred into the car. On the front window I had Llumar Air Blue 80 applied with a 28% "sun visor" across the top, the claim is a 40+% reduction in heat. It still feels pretty darn hot when it's 90+ degrees and there are no clouds! I have however noticed that on the side windows if I roll them down so the "shade" of the tinting is not keeping the sun out - it IS noticeably hotter.
    I've never tinted a vehicle before, and I've lived my whole life in FL. I'm impressed at the difference it has made. It's only subjective, I have not IR or heat readings to share.
    I went with and installer who'd been in business over 30 years and selected a manufacturer with a great reputation in the tint business. I picked the ceramic film they've had in production the longest. You probably can't go wrong with 3M either.
  20. rjparker
    10,131
    6,293
    Guys in Canada and North Dakota are not up on windshield heat rejection films applied from the inside and the amazing difference it makes to uv and infrared in the southern tropics of the US.
    otatrant and douglasjre like this.
