What are the forum's thoughts on salvage/junkyard 12V batteries?
Discussion in 'Gen 2 Prius Main Forum' started by priuslyfe, Jun 11, 2025.
  1. priuslyfe
    priuslyfe Member
    233
    57
    I'd like to get a 12V battery before I might need one next Winter.
    I've seen some Summer deals in my emails but new 12V batteries but the costs typically are still pretty high (around $250+ but really more if you want over 500CCA).
    I'm convinced there is a battery-price cartel because every major chain has the same prices for their batteries. Decided to call a reputable salvage yard that I alway get parts from and turns out they have a Prius battery which isn't pulled off a car but is pulled out sent to a reconditioning company and given back to them to sell.
    They're all, allegedly, rated to 750 cold-cranking amps!!! when the yard gets them back. Is that even possible?
    That's overkill for a Prius but for $50 seems like a good deal to gamble on.
    Thoughts?
  2. Rmay635703
    Rmay635703 Senior Member
    2,669
    1,690
    Somewhere in Wisconsin
    2013 Chevy Volt
    Recon batteries make more sense the battery mart typically sells them for $35 which is less than the wrecker and they actually are in some cases “new” but with a re-flowed terminal or repaired casing.
    Many wreckers test, float and clean up junk batteries but they usually aren’t as good of a deal as a recon from an independent battery retailer
    priuslyfe likes this.
  3. priuslyfe
    priuslyfe Member
    233
    57
    what store please? is there a chain that sells reconditioned batteries? I've just never heard of one.
  4. BiomedO1
    3,888
    2,033
    SacTown, Ca
    Sorry; I'm going to have to raise the BS flag on that one. How do they get a 500CCA battery up to 750CCA. Those reconditioned/refurbishers usually just clean up, recharge and test those batteries. That's how they can offer them for $50. Now a salvage yard sending them out, getting them refurbished, then bringing them back to sell is kinda unheard of here. Most yards around here are glad to get rid of them for pennies, so they don't have to deal with the proper LEGAL disposition of them. Those junk yards are not in the business of paying someone to legally and properly dispose of them.
    I know of a few auto parts store that actually carry refurbished batteries, behind the back counter. You'll need to ask for them, so they don't compete with the new ones on the shelf. Those are usually the most common battery sizes (ie. 24 and 24F), a weird AGM battery for a Prius may take a few days; if they can even get their hands on one. Only standard 30 days taillight warranties applies to them.
    YMMV
  5. priuslyfe
    priuslyfe Member
    233
    57
    I asked him twice and he said they're all rated to 750. Of course, he could just be a misinformed employee so who knows? might go check it out as he didn't have the time to check it out for me over the phone (bad sign I know).
    BiomedO1 likes this.
  6. Tombukt2
    13,155
    2,369
    In our group size you will not get over 500cca in AGM now lifpo maybe different . 750 to 1000 those group sizes are huge like my volt and Volkswagen Passat v6 or such.
  7. priuslyfe
    priuslyfe Member
    233
    57
    yeah. if he has the Prius battery at all most likely he was saying something that he was wrong about. Hopefully its at least 500cca.
    @Tombukt2
    do you know if this is a resuscitatable battery?
    I've had it sitting for several years so I know its dead not to mention the post is broken. Always wanted to tinker with it but have so many other things to tinker with I forgot about it.
  8. BiomedO1
    3,888
    2,033
    SacTown, Ca
    No but it's a good core. You'll avoid the core charge and won't have to return to get a refund.:D
  9. pasadena_commut
    pasadena_commut Senior Member
    2,724
    813
    Southern California
    In theory traditional 12V batteries can be fully restored if the case can be opened so that the lead plates can be chemically treated. Or I guess mechanically if a thinner plate is acceptable. The trick is resealing the case so that it never, ever leaks. When the top is off the battery posts can be replaced. After all that work it will be as good as new - but not better. To make it better (more capacity) the plates would have to be made larger. That might just be possible with an optima battery since the plate is rolled, but I have never heard of anybody actually doing it.
  10. priuslyfe
    priuslyfe Member
    233
    57
    UPDATE:
    called salvage yard again. employee insisted they are 750cca but not AGM. Maybe that has something to do with whether or not the battery is 750cca. I don't know. The reconditioner is a local person and apparently what he does is take the existing salvage battery, restore it, remove any identifying stickers and puts his new label on it. Not sure what to make of this tbh.
  11. pasadena_commut
    2,724
    813
    Southern California
    Never seen a chain, some independents do this sort of work. For instance, my son once bought some used batteries for an RV from this fellow:
    Lee's Batteries | Battery Shop | Baldwin Park, CA
    Used batteries aren't their only business, they also sell new. I would expect any shop in this business would sell both old and new.
  12. eljefino
    eljefino Junior Member
    43
    25
    Maine
    I used the (controversial) HF solar AGM battery, $76 before discounts. 12V, 35 Ah Sealed Lead-Acid Battery
    back when I had a 2nd gen.
    There's no vent tube to the outside so hydrogen gas could build up and go boom.
  13. dolj
    dolj Senior Member
    8,462
    4,297
    Wellington, New Zealand
    A 35 Ah flooded battery won't last as long as the spec'd battery nor tolerate deep discharges like an AGM would, but I guess at $75, you could change it every year or two and still come out ahead.
  14. priuslyfe
    priuslyfe Member
    233
    57
    Who says Prius drivers aren't risk-takers?
    There's probably more risk with that battery than driving a 1000hp Lambo. LOL.
  15. eljefino
    43
    25
    Maine
    The stock battery is 40-42 Amp-hours, FWIW.
  16. priuslyfe
    priuslyfe Member
    233
    57
    UPDATE:
    Got a reconditioned-battery today from Interstate Batteries (national chain) who recondition batteries. The AGM with 410cca was around $85 with your old core battery exchanged. I think the warranty is 6mos but better than buying a new battery for around 250.
    gdanner and ColoradoBoo like this.
  17. pasadena_commut
    2,724
    813
    Southern California
    Not sure how "refurbished" these actually are. Read the description here:
    Certified Refurbished Interstate Batters | Interstate Batteries of New England
    In my book that isn't refurbished at all, it is just cleaned and charged. Sounds like they go through the returns and find ones which were good but maybe fully discharged because of problems elsewhere in the car, and were then returned. So rather than refurbished, maybe a more accurate term would be "slightly abused"?
  18. Stevewoods
    Stevewoods Senior Member
    662
    1,171
    Seattle, WA
    I just looked on my Toyota dealer website, clipped the 10 percent off coupon and bought a new toyota battery for $195 USD. A bit pricey, but the original Toyota battery lasted eight years
  19. Paul Gregory
    Paul Gregory Senior Member
    2,192
    578
    Alberta
    2024 Prius Prime
    XSE
    Based on the way so many people replace car batteries they way they do flashlight batteries,
    I'd say the chances of finding a perfectly serviceable junkyard battery are pretty good.
    #19 Paul Gregory, Jun 28, 2025
  20. qmanqman
    qmanqman Active Member
    433
    150
    CO
    I would buy a junkyard battery without a second thought
