"EGR DELETE" Instructions
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Paladain55, Jun 17, 2023.
  1. johnHRP
    johnHRP Active Member
    645
    189
    KA, DE
    Excel
    The EGR delete is intriguing because in many countries like Brazil, they do not have EGR in Prius 3. EGR is one of the biggest enemy in Diesel engine after DPF fuel dilution problems because the shoot from Diesel is much more and become abbrasive to the engine. Many folks delete it completely in states that do not require it.
  2. Mendel Leisk
    41,791
    Toyota may make other changes in the Prius they make without EGR, say run the engine a little richer.
  3. johnHRP
    645
    189
    KA, DE
    Excel
    I doubt that, it will increase fuel consumption. The old fashioned way, just opened the exhaust valve during the intake cycle works fine in Older Corolla and Camry did it that way, it is just not cooled and maybe not as efficient in reducing NOx.
    NOx is pollutant for human but food for plants. It becomes Nitrate when reacts with water. Newer cars also start having GPF, shoot filter. Not sure if the 5th gen has one.
    EGR is one of the source of engine wear because soot got sucked in and it is abrasive. Routing it after the catalytic converter is a smart move. Reduce the sludgy oil, carbon soot, and radicals.
    #63 johnHRP, Jun 12, 2025
  4. MPGS-LOL
    MPGS-LOL Junior Member
    Somewhere sperical, with lots of v8's
    Revisiting this bit, looking for words of wisdom.
    I had the "water sloshing" sound most of last year during engine restarts that I attributed to a waterpump slowing going out.
    P261B
    DIY'd waterpump and thermostat.
    "water slosh" on engine startup disappeared.
    I spent the required time with fronts on jackstands to fully cycle the heating system a few times to purge any air out of the system.
    Just started hearing it again after 6'ish months.
    No obvious leaks down low, engine coolant reservoir not reading (measurably) low.
    I'll try bleeding it again after the heatwave.
    Zero codes on dr prius.
    Possible headgasket leak? (JDM engine replacement about 80,000miles ago)
    Any recommendations to pre-emptively unplug the EGR? (no history of cleaning, don't plan to either).
    Penny for your thoughts.
  5. johnHRP
    645
    189
    KA, DE
    Excel
    If the coolant level is still the same, than you only need to bleed the air. The sloshing noise can be caused by the mechanics who rebuild the engine forgot to install the plastic filler on the water jacket on the short block.
  6. Mendel Leisk
    41,791
    Third gen's, including Prius v, don't have the plastic filler?
  7. Bill Norton
    Bill Norton Senior Member
    2,208
    744
    MONW, Ks.
    2019 Prius
    L Eco
    A few thoughts:
    The early Gen3's had a bleeder valve at the high point of the coolant system. If yours doesn't have that fitting maybe you could loosen a hose in that same area and try to get air and coolant to come out. But it may require that the coolant has a bit of pressure. You don't want to open a hose connection only to have it suck in air because everything is downhill from that spot. You could try while it's still warm after a drive, but not hot and scary.....
    If you're not loosing coolant the mystery head gasket is hanging in there, but it's still a clicking clock, correct?
    EGR disconnect can be done easily, if you're willing to drive around with the check light on.
  8. ChapmanF
    18,426
    At the same time that Toyota revised that fitting to no longer have a valve you could open, they revised the coolant fill instructions in the repair manual to no longer have any mention of fiddling with that valve while filling. They did not replace them with new instructions to loosen hoses or fiddle with anything else. They just took out the instructions to fiddle with anything there, leaving the basic procedure of filling the degas bottle to B, capping it, running the engine for several minutes past operating temperature, and letting the air get circulated back to the headspace in the bottle.
    It seems sometimes we get so attached to a certain ritual that even if the manufacturer figures out it isn't needed to get a successful refill, years later we still want it back.
  9. Bill Norton
    2,208
    744
    MONW, Ks.
    2019 Prius
    L Eco
    That sounds good. But what do you make of his 'sloshing sounds'?
  10. Paladain55
    Paladain55 Active Member
    408
    167
    The South
    I just fill at the bleed valve until it pours out the resevoir and then let it run for a while. It blows out the extra coolant and sits at whatever level it wants. I wouldn't pay attention to a sloshing sound.
    Bill Norton likes this.
  11. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    Hi buddy! Long time no see!
    We finally, finally sold our 2012 Prius Plug-in, and my son is going to buy either a Gen V Prius or a Subaru Crosstrek.
    This has me contemplating an EGR Delete. There are two approaches: Removing the electric connector, and installing a plate to block the EGR gases before it hits the valve. I like the second approach because it is stealthy and it will cause no CEL.
    But the problem I foresee is that when the computer opens the valve, it will think the Fuel/Air ratio is different than it really is.
  12. rjparker
    10,386
    6,504
    You will get a code after the system tests the egr flow and measures intake pressure.
    However the code is not as quick as an electrical disconnect (P0403).
    Rebound and Brian1954 like this.
  13. ChapmanF
    18,426
  14. Paladain55
    408
    167
    The South
    Update: Still going strong. EGR delete from 2021 to now.
    Between the piston soak ,EGR delete, and the pcv system converted to a open crankcase vent system, the only maintenance the car needs now is 5000 mile syn oil changes, blow out the air filter, and to grease the sliding pins on the calipers every year or two along with tires and gas. Car consumes less than half a quart of oil between oil changes. Car built in May 2009 still drives like new. All original HV battery, suspension, etc...
    These are fantastic cars if you do the bulletproofing/maintenance.
  15. AzusaPrius
    AzusaPrius Senior Member
    2,220
    929
    @Paladain55
    Can you post pictures of your open crankcase vent system.
    I been wanting to do this too.
  16. Paladain55
    408
    167
    The South
  17. Bill Norton
    2,208
    744
    MONW, Ks.
    2019 Prius
    L Eco
    Open Crank Case Venting.....
    Straight out of the 50's. It stunk then. It stinks now.
    No thank you. :mad:
  18. Mendel Leisk
    41,791
    Yeah, I'm keep it zipped, but agree with you, for once. ;)
  19. Paladain55
    408
    167
    The South
    Intake must be sealed off from the engine bay. No smells. Its actually in a tray behind the engine bay outside of the hood.
  20. Bill Norton
    2,208
    744
    MONW, Ks.
    2019 Prius
    L Eco
    It smells. Just because you don't smell it doesn't mean anything.
    There's a reason that PCV was one of the first emission controls that became law.
