Ridiculous Front Lift Point
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by scotched, Mar 9, 2025.
  1. frodoz737
    frodoz737 Top Wrench
    4,502
    2,425
    33
    My lowest (ever) vehicle to jack is my ZR1 and the highest was the custom lifted Tacoma I bought my Son for graduating college. You need different tools for different jobs.
  2. dagaph
    dagaph Junior Member
    46
    Montreal
    2024 Prius Prime
    XSE
    the regular ramps will not work, only the ones specific for low rise cars will work.
  3. Hammersmith
    Hammersmith Senior Member
    1,955
    1,962
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    17 degrees works and has a little buffer. I'd guess the limit is around 19 or 20 degrees. The old-style metal ramps might not work, but most plastic ramps should work fine. I have a standard set of RhinoRamps that I probably got at Home Depot several years ago.
    dagaph likes this.
  4. Mendel Leisk
    40,445
    Maybe just experiment with some 2x lumber, cobble something that works. 3~4" lift might be enough. Jack design may be a factor too: some jacks can roll under just fine, but when it's so far back the handle's under the car, handle swing range can become problematic: there's not enough clearance to raise/lower handle, get the jack started.
  5. dagaph
    46
    Montreal
    2024 Prius Prime
    XSE
  6. dagaph
    46
    Montreal
    2024 Prius Prime
    XSE
    yes the problem is the handle. the the 3 ton low jack from costco fits under the car but it is the handle that has no space to be pumped - it is like 1-2 cm.
  7. Mendel Leisk
    40,445
    I have an older Sonoma 3 ton jack. Bought it clueless, on boxing day, for $69 CDN. Dumb luck: the handle on it starts pumping with just a slight amount of lift.
    Maybe 2 years back bought another 3 ton jack at Canadian Tire, and it's handle needed a lot more lift to get started. Also had a crazy-strong spring on the handle. First time used, under the car and raised, the handle pulled out, and it's socket snapped up to vertical. Now what...
    We survived, I returned it.
  8. mva
    mva Member
    108
    63
    B.C. Canada
    2024 Prius Prime
    SE
    The manual clearly calls for Front to Rear tire rotation - no cross rotation. IMG_1296.jpeg
  9. mva
    mva Member
    108
    63
    B.C. Canada
    2024 Prius Prime
    SE
    I have been putting 2 jacks on one side and doing the tire rotation per the manual. I also have ramps for the oil change.
  10. KMO
    KMO Senior Member
    1,803
    585
    Finland
    2023 Prius Prime
    The US manual, yes. The European one shows cross rotation.
    I don't think there's any deep significance there - I'm going to guess that they don't want liability if a US person does a cross rotation with directional-tread tyres.
    I've been cross rotating the original summer set, and front-to-back on the directional studded winter set.
  11. scotched
    scotched Junior Member
    48
    65
    Encino, CA
    2023 Prius
  12. Mendel Leisk
    40,445
    Interesting. I’d always cross-rotated our Honda, per manual, then didn’t, with our previous, again per manual. Googled the following:
    why does toyota not recommend tire cross rotation in north america
    Yields some explanations. Think I’ll just carry on per manual.
  13. Xse
    Xse Junior Member
    53
    Brighton Ontario Canada
    2024 Prius Prime
    XSE Premium
    https://mprtools.com/cdn/shop/files/712nUIy58-L._AC_SL1500_140x.jpg?v=1744992408 This jack is similar to the one I have
    I always frt to back tire rotation
    With similar Jack as above both wheels are clearly off the ground
    Chassis on new cars are very stiff
    Oil change Jack goes under to the frame no problem
    Even my Miata being low slightly under 3” no problem with this jack
  14. mva
    mva Member
    108
    63
    B.C. Canada
    2024 Prius Prime
    SE
    Okay, interesting information. I will consider crossing mine too. The wear rate on my Toyos, so far, has been pretty low.
  15. KMO
    KMO Senior Member
    1,803
    585
    Finland
    2023 Prius Prime
    Found myself wondering, so just checked - "original" Japanese manual also shows cross rotation. US is the odd one out.
