Gen 2 does not start after a breathalyzer was removed? No LED lit on Power Button.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by James Analytic, Jun 7, 2025.
  1. James Analytic
    289
    43
    Michigan
    Like the other half or side does, says she or we are going to do and only I wind up literally doing. Kind of like the rant pre syn I'm getting now.
  2. James Analytic
    289
    43
    Michigan
    Appears I found all the wire and am still wondering what the resistance and capacitance effects are on the digital signals if that's what those are for. Didn't ID the connectors and pins along with wire colors just yet. Only conductivity to see if open circuit or not. No voltage testing as well unfortunately.
    I did come to the conclusion, since troubleshooting would be check not the wiring harness first, the fuse box and all the fuses need replacing. AM2 was not conductive nor were any of the fuses for that matter. AM2 also pulled out as a crumbled mess where I am guessing formic acid from the ants is to play? Whether that was a situation from the ants or issues prior or from the ants after sitting a year.
    48018291-4b3e-41c7-808d-c895fc9cc8a4.jpeg 81a80859-9b1c-4756-9cf9-fd75a853695c.jpeg 984ea976-29e8-432b-9865-c14cacd6a1c5.jpeg 812bfc5b-b25f-4cdb-b740-448c814d5270.jpeg
    Amazingly, performing the conductivity testing only as time was limited, everything appears to be conductive connections albeit solder blobs that are not that pretty.
  3. Tombukt2
    11,985
    2,115
    So I'm to believe those red wires were separated and device inserted in between so to speak.if that's so. Then up by pwr distro box should be another probably white wire it's Fat in same condition as red here?
  4. Tombukt2
    11,985
    2,115
    Boy that's ugly fuse box .
  5. James Analytic
    289
    43
    Michigan
    Appears they spliced into the fat blue wires (11 1H and 1 1C) for switching PWR power and I guess HTR for power? At least I'm thinking if I'm reading correctly. (4 1J) was spliced as well, which appears to be the IGN ignition. Brake pedal was the blue wire and I still need to read what the green wire is going into, a tan-yellow thing. The green had the blue wires added and the blue had the red wires added.
    Appears the additional lengths of Blue wires and Red wires were for dropping down those circuits wires for easier access maybe later to more quickly remove or to run to the IID thingy. Those get me wondering if somehow they are adding additional resistance and or capacitance to cause digital signals to be wonky. Just random guessing, though seems like if worked with then probably logically not. Wondered if any of the mess of em jostled around before insulating if grounding could have blow a fuse or damaged something?
    Yes sir, amen to that. I should of taken a photo of the pulled fuse that crumbled into powder and the plastic piece more opaque than clear blue with no continuity even when pulled. Even in the yards and all the Priuses and vehicles I've pulled fuses out of, never witnessed anything like. Fumeric Acid from the ants is my best guess.
  6. Tombukt2
    11,985
    2,115
    So now you trim back the extension wires clean up connections and resistance change should be minimal.
  7. James Analytic
    289
    43
    Michigan
    I agree and prefer to splice so no so goobery blobs of solder. Ordered more shrink tube, so can seal nicely as well.
    Wound up grabbing the fuse box at the yard and swapping in the C block section for starters since AM2 was toast.
    That and solder temp rigged the thermos engine water pump harness at the connector that might have been shorting out in the harness since as was found missing a few inch section with like 1" pigtail at the connector side. Still won't startup, i.e. go into ON (READY), however does go into the other two ON (ACC) and ON (IG) so was able to read codes. MFD and Dash came on as well.
    The codes are as follows after clearing them all: C0210, C0215, C1295, C1310, P0A9D, P0AFA, P3000, B1785 and B1650
    Technically, there were some more for the Air Conditioning and I forget what else though the above were saved after going through and clearing after trying to startup.
    Need to read into codes next since just got back from working on.
    #27 James Analytic, Jun 9, 2025 at 10:23 PM
  8. James Analytic
    289
    43
    Michigan
    From Monday after getting everything connected and praying I didn't need to splice the bottom fuse box section 14 something wires.
    - YouTube
    I made a video prior to this one with the one Power button press and only the MFD came on with the door open symbol. Seems more boring and I narrated noting I needed to maybe wire some more together being I hadn't spliced the one engine coolant pump pigtail to the harness. Still waiting to coordinate with the girl and the baby to get back up with a known working HV battery to swap in and hopefully drive away if the drivetrain seems good enough.
    Two hour road trip and thinking I can go and maybe do, though seems however the HV battery swap will get the car going. Any thoughts? I've never had those SKS codes before.
    #28 James Analytic, Jun 11, 2025 at 11:59 AM
  9. James Analytic
    289
    43
    Michigan
    Going into READY mode and moving, with some other issues I need to address, after HV battery swapped to replace this never in my life before seen mess:
    #29 James Analytic, Jun 12, 2025 at 2:15 PM
  10. ChapmanF
    17,170
    On top of whatever other effects that might have, I don't suppose it's great for cooling airflow.
  11. James Analytic
    289
    43
    Michigan
    That mod was removed and not well documented as of yet. Whomever engineered that knew to chew the sense wires of some sort, current I'm guessing as well as one of the temp. Thinking didn't want a mobile home. Stay tuned for further updates as I wonder if will be a unique HV battery wiring repair video, optimistically thinking ahead as the charge level on the MFD showed enough bars to start the car. Maybe current reading and not only temp reading was unsuitable?
    I did notice some lamp black above and wires chewed on. Didn't inspect enough to repair there since wanted to swap in a known working HV battery since in a rush to get it out from under the walnut trees and to someone who can use.
