Question-2025 Prius in EV Mode: Reply quickly!
Discussion in 'Gen 5 Prius Technical Discussion' started by iRun26.2, Jun 13, 2025 at 6:28 PM.
Tags:
  1. iRun26.2
    iRun26.2 Active Member
    718
    125
    United States
    I have grown to love how they look. I guess I want efficiency and good looks. A small sacrifice. I’m not quite as serious about saving energy as I thought.
    When I drive, though, I’m back to my old driving habits of driving for efficiency. Now that I have a car that can report EV efficiency directly, I’m trying to do my best there (as I used to be for gas mileage).
    #61 iRun26.2, Jun 17, 2025 at 8:08 PM
  2. iRun26.2
    718
    125
    United States
    What do you guys have your tire pressures set at? In the app, mine measure 44psi in the back and 45psi and 46psi in the front. That seems rather high, doesn’t it?
  3. iRun26.2
    718
    125
    United States
    I went out for an EV drive tonight (just for the sake of measuring efficiency). I drove on roads with about 55mph speed limits yet with many stop lights (1/4 mile apart). Overall, without the a/c on, I got about 5.0 miles/kWh. I know I could have done better if it weren’t for those stupid stop lights. When the upcoming light was red, I tried to coast in to maintain kinetic energy.
    As expected, this isn’t as good as other people have reported. I guess that’s the penalty for buying the upper trim with all of the bells and whistles.
    I’ll be taking the first trip to work tomorrow when the stop lights are further part (but with higher speeds of 65mph…I may not drive that fast, though).
    #63 iRun26.2, Jun 17, 2025 at 10:53 PM
  4. Gokhan
    Gokhan Senior Member
    5,636
    2,225
    Paramount CA
    That is a tad bit high but OK. I use 43 psi front and 42 psi rear in my Gen 4 PHEV, which is I think just about optimal for fuel economy and tire wear 51-psi tires. I have accumulated zero tire wear in 50,000 miles on my Dunlop Enasave 01 A/S 91S OEM tires.
    iRun26.2 likes this.
  5. iRun26.2
    718
    125
    United States
    The dealer who sold me the car never asked me what I wanted. I think I would have asked for something similar, though. I think they must have been very helpful in allowing me to get 56mpg (after EV was gone) on the trip from Milwaukee to Minneapolis (at speeds of 65mph to 70mph).
    I’ve never driven a car with the thinner tires on larger wheels. I just assumed that they were supposed to be set to the higher psi values.
  6. Trollbait
    12,313
    The app might be reporting a couple psi high.
  7. iRun26.2
    718
    125
    United States
    Quick question: Do you open the windows to keep it from getting so hot on the inside? I’m worried about overheating the EV battery.
  8. bisco
    51,027
    do you have a tyre gauge? what pessures did you run your gen 3 at? mine were 42/40
  9. iRun26.2
    718
    125
    United States
    I guess until I hear differently, I’m going to be cracking my windows open so the EV battery doesn’t get as hot.
  10. Gokhan
    5,636
    2,225
    Paramount CA
    Actually, the tire-pressure monitoring systems (TMPSs) in general have an accuracy of about 1%, which is better than any cheap tire gauge, which could be as bad as worse than 10%.
    Don’t let your tire-pressure monitoring system leave you feeling flat | AAA newsroom
    The only caveat is that they don’t update when the vehicle is stopped, and they update infrequently when the vehicle is being driven. This is to save their battery cells. Therefore, you cannot use them when putting air and adjusting the tire pressure—you would need a good tire gauge or rely on the pressure gauge on the pump for that. The pressure gauge on my digital pump is fairly accurate, about within 0.5 psi if not better.
    #70 Gokhan, Jun 18, 2025 at 4:02 PM
  11. Hammersmith
    Hammersmith Senior Member
    1,965
    1,970
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Your HV battery is not air cooled, and it's not inside the car. Yours is mounted underneath the car, is cooled by the heat pump, and is warmed in the winter by electric heating elements. Having your windows cracked will make no difference to the HV battery.
  12. Julio_E
    Julio_E Junior Member
    26
    Michigan
    2024 Prius Prime
    XSE Premium
    Like others have said (and I also have a 2024 Prius PHEV), your PHEV Hybrid battery is different in key ways than the HEV hybrid battery. Check out these two Weber Auto videos to better see and understand this:
  13. iRun26.2
    718
    125
    United States
    Yes. I just measured the tire pressure with an accurate gauge. They are correct 45’s in front a little less in back. That’s exactly what I’d want to help improve efficiency!
    When my wife got her Rav4 hybrid, her tires were also pumped up rather high
  14. bisco
    51,027
    they pump them up for shipment, and part of the dealer checklist is to set them properly. unfortunately, some dealers...
  15. KMO
    KMO Senior Member
    1,807
    585
    Finland
    2023 Prius Prime
    Even the most useless dealer should be letting the tyres down a bit at least, as that's what activates the TPMS sensor transmitters - first sudden deflation. They're off from the factory and during shipping. (Partly due to not being legal RF devices in Japan!)
  16. iRun26.2
    718
    125
    United States
    Yesterday, driving about 55mph, I was to get to work (21 miles) and back with 15% of the battery remaining. I ended up having a 4.4 miles/kWh efficiency.
    Today I’m driving at 60mph. I’ll see if I get home without gas.
    Hey, does anyone have Toyota app working correctly? Mine (iPhone) never shows my correct current charge levels. I also wish it would update solar roof statistics.
