2012 Prius V Skid Control Module
Discussion in 'Prius v Technical Discussion' started by James_B_Elam, Jun 19, 2025.
  1. James_B_Elam
    James_B_Elam Junior Member
    Ohio
    2012 Prius V...4 ways came on spontaneously the other day...pulled the fuse...only the hazards went off... still have clicking sound like hazards are still on...ABS lights and parking brake lights are on...no cruise control.
    Is it the skid control module and where is it located?
    Thank you.
  2. rjparker
    9,884
    6,092
    It is part of the abs master cylinder known as the brake booster.
  3. ChapmanF
    17,763
    I would back out the HZRI terminal from position 10 of the skid ECU connector under the hood, tape off the pulled-out end, put the fuse back in, and see what happens.
    If that has solved the problem, you know the cause is in the skid ECU. If not, the cause has to be found someplace else.
    (I can't guarantee the v uses the same wire colors as the liftback, but I'd bet at least the pin positions are the same.)
    Brian1954 likes this.
