2012 Prius V Skid Control Module
Discussion in 'Prius v Technical Discussion' started by James_B_Elam, Jun 19, 2025.
  1. James_B_Elam
    James_B_Elam Junior Member
    Ohio
    2012 Prius V...4 ways came on spontaneously the other day...pulled the fuse...only the hazards went off... still have clicking sound like hazards are still on...ABS lights and parking brake lights are on...no cruise control.
    Is it the skid control module and where is it located?
    Thank you.
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,053
    6,924
    Texas Hill Country
    It is part of the abs master cylinder known as the brake booster.
  3. ChapmanF
    18,994
    I would back out the HZRI terminal from position 10 of the skid ECU connector under the hood, tape off the pulled-out end, put the fuse back in, and see what happens.
    If that has solved the problem, you know the cause is in the skid ECU. If not, the cause has to be found someplace else.
    (I can't guarantee the v uses the same wire colors as the liftback, but I'd bet at least the pin positions are the same.)
    Brian1954 likes this.
  4. Gasketblower
    Gasketblower Junior Member
    58
    This exact thing happened to me and I did the solution where I cut the light blue wires sure did stop the hazards but 2 weeks later I lost all signals and no hazards seems like short in the signal circuit and few months later I get Inverter code P0a94 i think its all related their is no sub. Codes for it either and my car now in limo mode
  5. ChapmanF
    18,994
    P0A94 is a different problem. Now you have that one also. That's the first priority to fix, so the car can go places.
  6. Gasketblower
    58
    Yes, I dropped the car off at the dealership
    Today, they are covering the repair of my inverter and replacing bunch of parts , I had ordered Asian inverter pump from rockauto for 180 Cad and asked the dealer to put in for me and they quoted me 1.5 hours so I said why not total
    Cost will be 305$ cad out the door with car back in working condition thank god for good service advisor. Cause even the mechanic at the dealer was about to fight me on the warranty and the advisor told him just to get it done
