My traction battery discharges at night.
Discussion in 'Gen 3 Prius Technical Discussion' started by Seymour1, Jun 20, 2025.
  1. Seymour1
    Seymour1 Member
    266
    32
    I park it in the evening with the battery showing almost fully charged. Then in the morning, it is almost fully discharged. It also shows a low MPG reading for the first 10 minutes of morning driving (bar graph). What would partially discharge my battery overnight?
  2. Tombukt2
    12,931
    2,322
    Battery wearing out . My generation 2 with very new dealer batteries get parked green errynight in am at start green . But quickly to blue
    BiomedO1 likes this.
  3. Mendel Leisk
    41,386
    Maybe assess the battery with something like Dr Prius, phone app that works with bluetooth OBD dongle. Carista dongle works well. Just the static test will give some idea; here's a screenshot, in demo mode:
  4. bisco
    51,884
    how many miles on her?
  5. Seymour1
    Seymour1 Member
    266
    32
    It got worse. I parked the car for 1 hour and after starting, I noticed that it had only 2 lines showing on the battery icon. Will it leave me stranded?
  6. bisco
    51,884
    not likely, and if/when it does, just disconnect the 12v fro a minute and it will start and run until you shut it down again.
    what are the bars doing while you are driving?
  7. Seymour1
    Seymour1 Member
    266
    32
    It seemed to me that the motor was revving up faster when I left from a stop yesterday. The bars slowly when up on a 12 mile round trip last night and ended up 60% on the battery icon. But this A. M., I was surprised to see that it is still 60%. My Prius is a 2010 model with 225,000 miles and with the original traction battery. Two years ago I power cycled the modules with a Bguad charger which cycled 4 at a time. My recollection is that all was at least 50% capacity of new. I think it is time for a newer set of batteries. Most ebay batteries boast X number of volts-a poor specification to count on. I saw one with 80 to 90% capacity. If true, that is what I should buy. I should replace all of the modules, I think.
    Looking at the Dr Prius reading shown above in post #3, which modules should be replaced? Or which spec is most important, voltage, delta voltage or internal resistance?
  8. BiomedO1
    3,550
    1,840
    SacTown, Ca
    It sounds like you've got several "weak" modules in your traction pack. Whenever you stop, the other batteries in the chain tries to 'lift' the weak ones back up to their level (ie. discharging the other good modules in the pack). Your mileage is most likely taking a nose-dive and your going to see the red triangle very soon. You just haven't meet the ECU's criteria for tripping that error message yet.
    Sorry.....
  9. Brian1954
    Brian1954 Senior Member
    2,180
    854
    South Central PA, USA
    IMO, the two most important specs on the Dr Prius app are VOLTAGE DIFF and DELTA SOC. VOLTAGE DIFF should be less than 0.30 volts. For a balanced battery, DELTA SOC should be 0.00%.
    Just drive the car until the P0A80 code occurs, then replace the hybrid battery.
  10. Seymour1
    Seymour1 Member
    266
    32
    I don't have Dr Prius, but I have Creader Elite Launch. It only lists one problem; my XM radio does not work. The Creader allowed me to set up my regenerative brakes after I replaced the booster and pump.
  11. Carall
    Carall Active Member
    308
    104
    Harrisonburg, VA
    Your battery has lost its capacity. The hybridautomotive method will restore the lost capacity and the charge level in the morning will be the same as it was in the evening, but with such mileage on a 15-year-old battery, this procedure will most likely need to be done every 7-12 months. Also, some of the modules may already be on the verge of its life.
  12. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    What’s the link and did you get a code for us to save 5% off?!
  13. Carall
    308
    104
    Harrisonburg, VA
    The HybridAutomotive method was used long before... in aviation. You can even build a single charger yourself that will work with three types of batteries: Prius (28 modules), Prius C (20 modules) and Camry (34 modules).
    My purpose is to help owners not to waste over $1,000 buying a junk battery from some magical battery repair company that uses modules manufactured in 2003. Even on a 2010 Prius with 200k miles, you can restore the battery capacity once a year, without disassembling it, by installing a cable into the battery, purchased or made yourself.
    Brian1954 likes this.
  14. Seymour1
    Seymour1 Member
    266
    32
    Today, the yellow triangle light came on, as expected. I traveled across Afton Mountain more often recently. It is a 1362 foot ride to the bottom (and the top).
    I charged/discharged my batteries with a Bguad 4-channel charger about a year ago. I was able to get a 5.0 amp-hour or better on all modules except one, which I replaced. The car had 220K miles on the original batteries then. Now it has 241K miles.
    It is time to replace the battery modules or some of the modules. Ebay has some sellers only stating the voltage. No thank you. Some others state that they reconditioned the batteries to have 5 amp-hours of capacity. My batteries passed that condition a year ago and now my yellow light is on. No thanks.
    I never used the Dr Prius app. Perhaps if I bought the wireless plug-in device and the app, I could learn that replacing all modules is not needed and which ones to replace. (I have a laptop and a USB to under-dash connector cable) If I view the Dr Prius results of my modules, there are 3 different parameters; voltage, cumulative delta voltage and internal resistance. I assume that if any of the 3 parameters are drastically worse than most of the other modules, I should replace the weakest ones.
    When shopping for new modules or a whole new battery, what else should I look for?
    I asked a seller what does he mean by "Grade B" module. He answered that grade B is not as good.
